Reply
      01-05-2013, 04:21 AM   #1
Beedub
ESS VT2-575!!!
its about to drop.......
http://www.m3forum.net/m3forum/showthread.php?t=430966
Beedub is offline   United Kingdom
      01-05-2013, 11:59 AM   #2
22022
22022's Avatar
Drives: VT2-500 ZM4 roadster
575!! New pulley and software...sign me up
22022 is offline   Canada
      01-05-2013, 01:09 PM   #3
ZStig
Drives: VT2-500 M Roadster
minor detail :
FOR E46 M3 GUYS
ZStig is offline   Reply With Quote
      01-05-2013, 01:18 PM   #4
ZStig
plus 530whp and you're VERY close to the engine exploding, from what JAWS says
      01-05-2013, 02:13 PM   #5
Beedub
Originally Posted by ZStig
minor detail :
FOR E46 M3 GUYS
S54. Same engine , job done.
I agree tho, think we're taking this too far on stock internals. I feel comfortable at 8lbs, ill work with catless, cams, meth, and evolve custom tune and leave it Thier until I build the motor.
      01-06-2013, 12:51 AM   #6
ZStig
lol, I know its the same engine bro, its the tuning thats always been the question
      01-06-2013, 04:08 AM   #7
Beedub
No it hasn't been a tuning issue. Not with ess, its been a fuelling issue ;-)
Maybe with this kit they will look at supplying a proper fuel upgrade. Then again looking over the system, it's easy to done without a tuners help.
      01-06-2013, 08:32 PM   #8
22022
22022's Avatar
What would we need? Better fuel pump? More volume?
      01-07-2013, 01:02 AM   #9
pandusr
pandusr's Avatar
Drives: BMW Z4M Roadster ESS CFR 525
M3 E46 also has problems with the fuel pump.
In this kit is a clear need to upgrade the fuel pump.
http://store.activeautowerke.com/act...vel-2-p44.aspx
With the kit CFR525 cold weather i carburation problems.
pandusr is offline   Italy
      01-07-2013, 01:09 AM   #10
pandusr
pandusr's Avatar
A friend mechanic has tested on the engine test bench S54 engine designed to drift with Vortech V3 Si, Motec M600, decompressed pistons (8,5:1), connecting rods reinforced, camshafts schrick 288/280, 13 psi, 110 octane race fuel .
Result reliability: 650 hp motor at 8000 rev / min.
They bought the kit VT1 450 to use the compressor bracket and Intake Manifold. Obviously the injectors of the kit were small and were replaced.
As used two fuel pumps Walbro 255 and pressure regulator on the return. It goes without saying fuel rail modified.
To maintain its reliability, have been content. They had achieved more than 700 hp at 17 psi.
my mechanic friend is Gozzoli (http://www.gozzoli.it).
Don't get me wrong, I don't want to advertise. Only information.
      01-07-2013, 03:25 AM   #11
Beedub
great info, any pics of this motor??? and yours for that matter!!! CFR kits were awesome!!
      01-07-2013, 03:27 AM   #12
Beedub
fuel pump, injectors-660cc, FPR, mayber large lines.... that would do nicely...
The aeromotive 340lph intank can support 650whp easily... so that would be my choice.
      01-07-2013, 09:22 AM   #13
ZStig
Key point being the low compression build
      01-07-2013, 09:25 AM   #14
ZStig
Hmm those walbro 255 fuel pumps are only $80 on ebay. Thought it would be more
      01-08-2013, 08:11 PM   #15
dubsesd
dubsesd's Avatar
Drives: M coupe / 328xi LCI
Get a veryron fuel pump. The Audi guys have been using them and solved the problem
2006 ///M Coupe TiAg / IR -- H&R coilovers/RPI exhaust/ZHP knob/19" Morr vs8.2 hand brushed/Stoptech 355mm 6/4 BBK/Turner strut bar/polished diagonal braces/m tower caps/tekarbon 2x2 coil cover/Michelin PSS/gloss black kidneys/painted gloss black roof/mstache 2 front lip/AFE dry intake/RPI forced induction/colormatch corners/black chrome //M badges/rear diffuser/aeroskirts/rogue mounts/DKF adjustable hangers/22%tint/euromode lighting/LED interior & plate lighting
dubsesd is online now   Reply With Quote
      01-08-2013, 08:19 PM   #16
ZStig
Ure joking, right?
      01-08-2013, 08:27 PM   #17
dubsesd
dubsesd's Avatar
No.
http://www.audizine.com/forum/showth...-from-a-Veyron!
Reply
Forum Jump
