Reply
      01-01-2013, 06:11 PM   #1
ANUSTART
ANUSTART's Avatar
Drives: 2005 BMW Z4 2.5i
Spring Compressor Recommendations
I'm putting on an Eibach Pro Kit soon and wondered if anyone had a recommendation for a spring compressor tool. I am leaning toward the Craftsman tool for $55. Anyone use it? Reviews seem good. Thanks in advance!
Mods: APEX EC-7 | Michelin PSS | Koni Yellow | Eibach Pro-Kit Springs | Rogue RSM | Z4M Sport Seats | ZHP Shift Knob | Mangowalk 2.4" Antenna
ANUSTART is online now
      01-02-2013, 02:34 AM   #2
SD Z4MR
(formerly SD 335is)
SD Z4MR's Avatar
Drives: '06 Z4 M Rdstr | '11 335is E92
My past experiences with the screw type spring compressors finally led to the decision to take the strut along with the new springs and shocks to a professional and let them do it. The last time I used a spring compressor, after having used one successfully several times prior, the spring shot all the way across the garage and smashed into the garage door.
It's not worth a potential injury and the cost was minimal.
Mine: 2006 Z4 Roadster | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Premium | Navigation | Heated Seats | iPod Adapter | Purchased 7/19/12
Hers: 2011 335is Coupe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | Premium | Convenience | Heated Seats | Navigation | Harmon Kardon | iPod/USB | European Delivery 5/12/11
SD Z4MR is offline   United_States
      01-02-2013, 04:00 AM   #3
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
Spring compressors are completely safe as long as you use a little common sense.. There's no reason why the spring should come out and shoot across your garage.. You only need to compress it enough to get the top nut off, which won't give it even close to enough energy to fly into something.
2008 Interlagos Blue M Coupe
DKF Catless Spipe, X-pipe, Race Mufflers//Michelin PSS 235/265//Apex ARC-8 Satin Black//H&R Springs//40% tint//Blackout Kidney Grilles//CDV delete//ZHP Knob//RE Trans Mounts//RE Clutch Stop//Stubby Antenna//Vanity Plate "ZGERMNZ"
mgwatson48 is online now   Canada
      01-02-2013, 07:34 AM   #4
Shipkiller
Shipkiller's Avatar
Drives: 2008 Z4MC & 2003 Z4 Roadster
Unless you just want to spend $55.00 or have a lot more suspension work to do, go to Advance and rent one. It cost me less than $3.00 to use theirs. These compressors are a two piece type which compress's the spring in a uniform manner.
Additionally, the one I rented has 'keeper tabs' that prohibit the compressors from coming (flying) off the spring. If you use a tool properly, it is very safe.
Shipkiller is offline   United_States
      01-02-2013, 09:16 AM   #5
elwesso
elwesso's Avatar
Drives: Z4 M Coupe
I tried using one of those spring compressors, and I ended up just paying $20/strut to have a shop install the springs. Then just R/R the struts yourself.
elwesso is offline   Reply With Quote
      01-02-2013, 10:44 AM   #6
ANUSTART
ANUSTART's Avatar
After writing this last night did some hunting and Pep Boys (and I believe other auto parts shops) will loan the tool for a deposit, recoverable when it's returned. The unit they show online has the safety pins to hold the spring in place. Looks like a winner to me. No need to spend the money on something I'll use very rarely. Will need it one more time when I upgrade the shocks.
Also, did the spring change on a Honda Prelude I had back in 2001 and it went fine. It's time consuming if you're careful, but never had any dangerous situations. Just have to be methodical and patient.
Thanks!
ANUSTART is online now   Reply With Quote
      01-02-2013, 10:47 AM   #7
fercho
fercho's Avatar
Drives: 2005 z4 2.5
if you go to auto zone they loan one for free, they just need your id
2005 z4 2.5i/// Aero front bumper, m rear bumper,08 rear lights, custom quad exhaust, matte black front grill, OEM alarm, llumar security film,m wheels, HID lights, LED interior and trunk light,Ipod integration, stubby antenna,tein s-tech springsx
fercho is offline   United_States
      01-02-2013, 11:44 AM   #8
ANUSTART
ANUSTART's Avatar
Was going to check AZ next. There's one very close to the house. Thanks for the tip!
Reply
Forum Jump
