FORUMS
- 5
| 12-30-2012, 04:32 PM | #1 |
![]() ![]() ![]() ![]() Drives: 2009 335i (RIP) - 2006 Z4MR Join Date: Jan 2010
Damaged weather strip
I'm not even sure what to search for to find out if there are any diy on how to replace this peice of weather strip. Looks like it might be a pita to replace.
| 12-30-2012, 04:57 PM | #2 | |
Car Geek
| 12-30-2012, 07:10 PM | #3 |
Retired Paratrooper
It's easy to replace. 5 - 10 minute job.
Carefully pull up the plastic interior piece (part A on pic) that overlaps it and simply pull off the weatherstripping. Start at the middle and work your way to the ends (B and C on the pic). It's just tucked under the other pieces of weatherstrip at the top of the pillars. (labeled B&C on pic) Tuck one end and work your way to the other snapping it firmly in place and tuck the other end in before snapping the last few inches then put the plastic interior trim back on. The hardest part is tucking the last end and if you don't tuck the first end you do far enough you need to pull it back off and start over.
Retired US Army 82nd Airborne Division.
- There's no such thing as a perfectly good aircraft. I have the option to get out while you have the pleasure of riding it in. ![]() |
| 12-30-2012, 09:17 PM | #5 |
![]() Drives: 2008 Z4MC & 2003 Z4 Roadster Join Date: Oct 2007
Yes, it is very easy. Does this picture help at all:
| 12-31-2012, 06:41 AM | #6 | |
![]() Python Smart Start /// LED Lighting /// 20% Tint /// Reflector Decals /// Gloss Black Roof /// Aero Sides Tekarbon Spoiler /// Mstache /// Rear Diffuser /// Stubby Antenna /// LeatherZ Armrests 18" M5 Replica Wheels /// 15mm RS Technik Spacers /// Akebono Ceramic Pads /// Michelin PSS Tires |
| 12-31-2012, 10:08 AM | #7 |
Thanks guys I will definitely be giving this a shot as soon as I get the parts in. Seems simple enough now that I've seen how its installed. Slowly but surely I am restoring her back to brand new condition.
The next thing I have to replace is the rubber trim around the windshield since mine is cracking and falling apart. Already did the windshield cover as that was all worn and cracking also. Thanks again! |
| 12-31-2012, 10:56 AM | #8 |
Sweet! Good info in case any of the door seal by the window starts cracking/crumbing again. Had to get the passenger side seal replaced just before the warranty was up. I'm figuring the driver's side will go at some point.
- Jeff
bosstones' flickr |
| 01-03-2013, 01:58 PM | #9 |
My driver's side is already gone and has been since shortly after I bought the car. The first thing I noticed is about the weather stripping is that it is virtually identical to the stuff that put in MGB's. I've got an MGB and have had to replace them several times. Not terribly expensive.
By the way, the MGB parts people have an "upmarket" version of the stuff that has a black velvety cloth cover where the rubber part is that looks much nicer than the rubber. One day I will investigate to see if it would be a replacement for ours. |
| 03-21-2013, 07:03 PM | #10 |
Funny,
Couple days ago just noticed my weather stripping that covers the windshield to the roof is cracking.. Car is a 07, garaged for 4 years. Park outside SOCAL sun for my work and thats it. Part #1 http://realoem.com/bmw/showparts.do?...12&hg=51&fg=20 Anyone have a DIY? Or could it be just peel and stick?
![]() 2007 Z4MC |
| 03-21-2013, 07:18 PM | #11 |
That is a very common issue as well as the plastic at the base of the windshield. Seems to be very cheap plastic. The strip you asked about is easy to DIY from what I have read. I know there are write ups as well. You have to take the old one out, use a non marring tool to remove glue residue from the channel and replace with a new one by pressing into place.
| 03-22-2013, 09:53 AM | #12 |
The strip around the windshield gets replaced with new glass. If your insurance has a glass replacement option like mine does, get new glass and kill 2 birds with one stone.
| 03-22-2013, 11:08 AM | #13 |
Did some research for people that will inevitably run into this problem:
BMW windshield glass is held to the body via urethane, the stripping or the "windshield cover" as bmw states it is simply there to block excess weather out of the grooves. Windshield does NOT have to be removed for my trim job. I'm sure dealers will tell you otherwise. There is also no adhesive, just a snug fit. What causes the accelerated cracking could be wax exposure to the rubber pieces which causes it to be more sensitive to weather changes. 303 aerospace protectant will help protect / elongate its life. Part #1 51317210011 costs 30$ from my online searches. Will reply when i do attempt this diy. Seems easy enough. http://blog.bavauto.com/6971/bmw-win...n-windshields/
![]() 2007 Z4MC |
| 03-23-2013, 09:19 AM | #14 |
I did the windshield trim a couple of weeks ago. Honestly I actually liked the way it looked without it better but didn't want to risk causing any weather damage to the windshield seal or something. My old one just pretty much pealed off and the new one was squeezed in. My friend did his but failed to remove the old one cleanly so he has pieces of it still in the grooves and now cant get the new on in. So make sure to take your time removing the old one.
| Bookmarks |
