Reply
      12-30-2012, 07:21 AM   #1
dean911
Drives: '07 Z4 M Coupe
US Mill Works front plate holder
SOLD
Installed but never used. Excellent quality front plate holder for MZ4's, but I just don't like the look. Brand new, $85 delivered from US Mill Works.
This one, $70.00 Delivered anywhere in the 48. Will ship outside the country but need to check shipping first.
Link; http://www.usmillworks.com/
dean911 is offline
      01-02-2013, 03:50 PM   #2
midn12ght
gearhead goddess
midn12ght's Avatar
Drives: '08 e86 3.0si
wish this fit my non-m. my rho plate just sheered off on the back and my plate is a tad bent. free bump.
Originally Posted by Roffle Waffle:
I think a sack of fluid is pressing on the part of my brain responsible for common sense and fiscal responsibility
midn12ght is offline   United_States
      01-02-2013, 03:57 PM   #3
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
i didnt know the tow hook is different in M's and non M's. You sure this wouldnt fit your car?
The Raspinator
SCHMOUPE is offline   United_States
      01-02-2013, 04:11 PM   #4
midn12ght
gearhead goddess
midn12ght's Avatar
not really sure. but the website made a point to refer M owners to a different drop down. anyone care to chime in?
      01-02-2013, 04:39 PM   #5
GammaZeta
Drives: 1
How did your rho plate fail?
GammaZeta is offline   Reply With Quote
      01-02-2013, 05:46 PM   #6
nadaclue
Drives: Urban Green 2003 3.0
I don't know for sure, but it's possible the bolt is longer for the M cars in order to clear the fang on the bumper. Non-M cars could have a shorter bolt to mount the plate closer to the bumper.
Just a guess since I'm pretty sure the thread size/pitch is the same.
nadaclue is offline   Reply With Quote
      01-02-2013, 07:37 PM   #7
dean911
The dimension from the frame to the face of the bumper at the center of the hole is 2-3/4". The threads are countersunk so measure from the hard flat arouind the threaded hole.
If this helps, Greg
dean911 is offline   Reply With Quote
      01-03-2013, 01:16 AM   #8
midn12ght
gearhead goddess
midn12ght's Avatar
the === corner slot on the backside i was using has pretty much opened up like a tulip. the plate hasn't gone through anything more than sitting on the front of the car facing oncoming wind. i can turn it over and use the other corner, but i'm concerned for the day i use up all the corners...and the backplate is not the same length as the standard CA plate, so it has a tendency to bend.
      01-03-2013, 02:57 AM   #9
itdnwiwbp
Drives: Z4MC, 330iZHP
I had an Rho on my 3.0si coupe that was just a hair to short to be swapped over to my M coupe. From talking to Rho it sounds like there were a couple of different configurations under the front bumper. I've heard of people putting the non-M on their M and it working fine but I'd get the slightly longer one. I did and it fits perfectly, just like the non-M did on my 3.0si.
Edit: Yes, this should fit the non-M no problem. It may stick out a few millimeters further if it's anything like the Rho but I don't think it would be significant.
itdnwiwbp is offline   Reply With Quote
      01-03-2013, 06:25 AM   #10
dean911
      01-03-2013, 11:27 AM   #11
SCHMOUPE
SCHMOUPE's Avatar
That happened to my old one. I thought it was a cheaply made piece. Not worth the 70 bucks they charge for
The Raspinator
Reply
Forum Jump
