Reply
      12-27-2012, 04:58 PM   #1
dazed^
dazed^'s Avatar
Drives: '07 Z4 M Roadster
Trouble finding part number rear wheel arch trim
Hi all,
I seem to have lost a small piece of plastic trim from my passenger side rear wheel arch. It looks like a small mudflap but it's plastic and small. It's #10 here:
http://www.realoem.com/bmw/showparts...52&hg=51&fg=75
However, although it appears in the schematic, RealOEM does not list the part associated with the number. Can anyone help me out and identify this part for me? TIA!
dazed^ is offline   Netherlands
      12-27-2012, 05:38 PM   #2
Jstic
Drives: 06 Z4 3.0i
Jstic is offline   Reply With Quote
      12-27-2012, 10:59 PM   #3
SD Z4MR
(formerly SD 335is)
SD Z4MR's Avatar
Drives: '06 Z4 M Rdstr | '11 335is E92
I just ordered part #51717012729, Wheel-house inner panel, rear left, #3 in the diagram. My left rear wheel well liner needs to be replaced because of the previous owner's too-aggressive 19" wheels and tire setup rubbed through the outside edge.
Has anyone replaced a rear wheel well liner before? I had to replace the right front wheel well in my wife's 335is and it was pretty straightforward. Any tips or tricks I need to know about?
Mine: 2006 Z4 Roadster | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Premium | Navigation | Heated Seats | iPod Adapter | Purchased 7/19/12
Hers: 2011 335is Coupe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | Premium | Convenience | Heated Seats | Navigation | Harmon Kardon | iPod/USB | European Delivery 5/12/11
SD Z4MR is offline   United_States
      12-28-2012, 11:01 AM   #4
Jstic
Drives: 06 Z4 3.0i
Nothing really difficult or no special knowledge needed. The holes in the liner line up with posts or female threads on the car. Remember to look closely as to how the liner fits around the outside edge, I took a picture before I took mine off. It can be done with the wheel on, but lots easier with it off.
      12-28-2012, 01:56 PM   #5
dazed^
dazed^'s Avatar
Thanks Jstic!
May I ask where you found this info? So that next time I won't need to ask for help again...
      12-28-2012, 02:02 PM   #6
Jstic
Drives: 06 Z4 3.0i
http://parts.bmwofsouthatlanta.com/
      12-28-2012, 02:18 PM   #7
dazed^
dazed^'s Avatar
Awesome, cheers!
Edit: Weird, by the way, that the part is indicated for non-M Z's only. That's why I couldn't find it somehow, I guess. Puzzling.
      12-28-2012, 03:11 PM   #8
Shipkiller
Shipkiller's Avatar
Drives: 2008 Z4MC & 2003 Z4 Roadster
The wheel liner will take about 10min (with tire removed) to replace. It is very easy.
Do not know if this helps you to visualize it, its the only pic of the rear in that area.
Shipkiller is offline   United_States
Reply
Forum Jump
