FORUMS
- 5
| 12-27-2012, 01:00 PM | #1 |
What spacers with OEM wheels
What would be the recommended spacers to push OEM wheels to the outer corners, nice and flush.
OEM springs 245/40/18 265/40/18 -2.5 camber Thanks. |
| 12-27-2012, 04:28 PM | #3 |
I think I used 12.5 with OE.
Alpinweiss '07 M Coupe •Eisenmann Sport-Ceramic Black•Diablo-X•Fabspeed Headers•VRS Hyper-Narrow rear wing•Autosolutions SSK•APR splitter•Tekarbon headlights•StrongStrut STB•KW Clubsport•Poly FCAB/RTAB•Volk Racing G2•Direzza ZII•Stoptech BBK c/w Cool Carbon pads
| 12-27-2012, 09:00 PM | #4 |
M = Midlife Crisis
Drives: 2006 Z4MC Interlagos Join Date: May 2007
Depends on tires. With 235/265 Dunlops the fronts were good however I had slight rub on the rears with 12.5mm. I was lowered ~ 1/2". With OE tires they are fine. Punko I have 4 - 12.5mm Turner spacers if you want to try them?
2006 Z4MC - #LL93158
SuperSprint Race Cans, RE X Pipe, Fabspeed Headers, OE STB, AS Shifter, Dave Z Modified CDV, Ground Control Coil Overs, Stoptech lines, Stoptech Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, ZHP Shift Knob, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM |
| 12-27-2012, 10:21 PM | #5 |
![]() ![]() Drives: flat out Join Date: Apr 2008
For front, rule of thumb is to avoid 10mm spacers since hub lips vary. If it were me, I'd go 5 or smaller, or 12 or bigger on the fronts to avoid any issues. For the rears, any size works
15's would be flush to slight poke. 12's on all 4 corners should be flush without too much risk of curbing. Either way, make sure to get longer bolts.
![]() Recaro | AST | Vorshlag | Quaife | Stoptech | Volks | Autosolutions | BMW Performance Click here for my track videos |
| 12-28-2012, 06:19 PM | #6 |
I am running 12.5 in the front with the OE sizes. You are welcome to try the set I have on too if we meet up. I have more (less, i dont know) camber. On sharp bumps I rub a little bit. Then again I am lowered slightly as well.
If you want a set of 12.5mm I have brand new from Turner I haven't opened and not sure if I will use. Caddy looks like he has a few sets kicking around too. lol ![]() ![]() ![]() |
| 12-30-2012, 09:03 AM | #7 |
![]() Drives: 2006 BMW M COUPE Join Date: Dec 2008
Do the spacers affect handling or additional stress on the wheel studs. I considered putting the tires "out there" a bit , however with the shit on the roads these days all I would end up doing is sand blasting my paint
2006 M COUPE - one of 38 Imola Red produced for NA that year, ESS 455 Supercharger
| 12-30-2012, 07:31 PM | #8 | |
6 of Diamonds (ret)
![]() Mods: DaveZ's GDO, DIY Windscreen, Intravee IPOD adapter, MudFlaps, Hardtop Retrofit & Hardtop, Gap-tech Power Top Remote +, M-Front Bumper, Mstache, Diet Hamburgers & a Big Fat Steering wheel, AE's |
| Bookmarks |
