Reply
      12-25-2012, 06:23 PM   #1
liamduong
liamduong's Avatar
Drives: 2007 BMW Z4M
VMR VB3, macht schnell spacers, h&r springs
Merry christmas everyone. Time for some goodies. 18x8.5 et 40/9.5 et 22 vb3. Macht schnell 5mm spacers for the front. H&R springs. Can I go with 10mm instead of 5mm spacers in the front?
liamduong is offline
      12-25-2012, 09:27 PM   #2
dubsesd
dubsesd's Avatar
Drives: M coupe / 328xi LCI
Nice gifts! 10 would be tight unless u modify your fender liner or adjust camber
2006 ///M Coupe TiAg / IR -- H&R coilovers/RPI exhaust/ZHP knob/19" Morr vs8.2 hand brushed/Stoptech 355mm 6/4 BBK/Turner strut bar/polished diagonal braces/m tower caps/tekarbon 2x2 coil cover/Michelin PSS/gloss black kidneys/painted gloss black roof/mstache 2 front lip/AFE dry intake/RPI forced induction/colormatch corners/black chrome //M badges/rear diffuser/aeroskirts/rogue mounts/DKF adjustable hangers/22%tint/euromode lighting/LED interior & plate lighting
dubsesd is offline   Reply With Quote
      12-25-2012, 10:02 PM   #3
inTgr8r
inTgr8r's Avatar
Drives: 07 M Coupe
Also depends on tires
Alpinweiss '07 M Coupe •Eisenmann Sport-Ceramic Black•Diablo-X•Fabspeed Headers•VRS Hyper-Narrow rear wing•Autosolutions SSK•APR splitter•Tekarbon headlights•StrongStrut STB•KW Clubsport•Poly FCAB/RTAB•Volk Racing G2•Direzza ZII•Stoptech BBK c/w Cool Carbon pads
inTgr8r is offline   Canada
      12-28-2012, 01:48 AM   #4
liamduong
liamduong's Avatar
Wheels mounted and balanced by Les Schwab Tire Center. Still need to add spacers to the front and H&R springs.
liamduong is offline   Reply With Quote
      12-28-2012, 09:11 AM   #5
dubsesd
dubsesd's Avatar
Looks nice. You should take some pics from further back with your diffuser
      12-31-2012, 02:00 AM   #6
liamduong
liamduong's Avatar
Front springs are on. Will do rears tomorrow. The H&R front springs are the same length as the OE front springs. Is it supposed to be like that?
      12-31-2012, 07:55 AM   #7
dubsesd
dubsesd's Avatar
Did the car lower in front after you installed them?
      12-31-2012, 04:13 PM   #8
liamduong
liamduong's Avatar
I did not measure the height on stock springs before the install. So I'm not too sure if it's lower or not. I think it's a little bit lower. Can someone give me an approximate height on stock front springs?
      12-31-2012, 07:50 PM   #9
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
youre H&R springs are still new, stock springs has milage on them. itl'll settle a bit
i2ichal2dZ4M is offline   Reply With Quote
      01-02-2013, 12:27 AM   #10
liamduong
liamduong's Avatar
rear springs are on. I had to improvised in order to get the springs in and out using a jack as you can see in the picture. Will post pictures of the car tomorrow.
The height of the rear on OE springs was approximately 365.125mm. With H&R springs, the height was approximately 342.9mm. So, a drop of 22.225mm or 0.875 inches.
      01-02-2013, 12:33 AM   #11
liamduong
liamduong's Avatar
I just ordered 10mm Macht Schnell spacers for the front. After installing the 5mm spacers, it was not flush enough. So I'm going to try the 10mm spacers.
      01-02-2013, 07:22 PM   #12
dubsesd
dubsesd's Avatar
thats not how you cxalculate a drop height. just because the spring is shorter doesnt mean it will compress the same as a stock one. why didnt you use the spring compressor for the back? that just looks dangerous
      01-02-2013, 10:55 PM   #13
liamduong
liamduong's Avatar
I calculated the height by measuring from center cap of wheel to wheel arch.
I tried using the spring compressor but because of the angle and limited room, I wasn't able to fit the compressor. It was really hard with the spring compressor for the rear. So, I ended up using the jack. I know it's dangerous. It was the only way but it made taking the spring out much easier. I would not recommend my method.
      01-03-2013, 07:38 PM   #14
liamduong
liamduong's Avatar
Pictures of H&R with 5mm spacers in the front.
      01-03-2013, 07:41 PM   #15
dubsesd
dubsesd's Avatar
looks excellent!
      01-17-2013, 12:38 AM   #16
bdn3d
Drives: Z4m Coupe/ Mini Cooper S
Where did u get the rear diffuser?
Good things may come to those who wait, but only what's left by those who HUSTLE!"
-George Washington
bdn3d is offline   Reply With Quote
      01-17-2013, 01:29 AM   #17
mickfo
mickfo's Avatar
Drives: 2007 Z4MC
Love the looks of that car with new wheels and ride height.
What tire sizes are you using, are they still OE sizes (225/45 - 255/40)? Reason I ask is because I am getting my current tires (PSS in OE sizes) mounted on a set of APEX wheels of the same size as your VMR's and was wondering how stretched (if any) they will look. Also, I have not thought of spacers but am now going to buy either 5's or 10's for the front based on your pics.
mickfo is offline   United_States
      01-17-2013, 11:18 PM   #18
liamduong
liamduong's Avatar
Rear diffuser is ACS Schnitzer from Euroactive
I'm using OE tires. They fit very well. Does not look stretched at all. You should get at least 10mm spacers for the front, depending on the offset. I have 5mm spacers in the rear. I might even go with 15mm for the front and again, all depending on the offset.
Reply
Forum Jump
