      12-13-2012, 06:03 PM   #1
TNZ4MC
Drives: 2006 Z4M coupe
OBD II scanner
I am looking for an OBD scanner that can tell me if the readiness monitors are ready for emissions testing. Anyone have any suggestions?
      12-14-2012, 02:35 AM   #2
Barryb97
Drives: 2006 M coupe
I use the PLX Kiwi 2 wifi adapter and the REV app on my iPhone works pretty well.
CDV delete, clutch stop, BMW pedals, Strongstrut bar, SS brake lines, rad hole cover, brake duct stop remove, M3 reps, roundel under hood, Intravee II, Homelink, air bag sticker delete, first aid storage, keyhole cover, painted reflectors, Headlight washer disable, Mstache front lip, Autosolutions SSK, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings front, TC Kline DA coilovers…
      03-11-2013, 08:21 AM   #3
stasha
Drives: 2007 Z4 Coupe
I'm hoping this thread might be able to help me with my problem...
Is the OBDII scanner you're talking about, the software/cable setup that can be purchased from eBay (as an example - http://www.ebay.com/itm/261163472483....m1497.l2649)?
I was told that an autoparts store scanner has limited use in the BMW, hence, I should get this software/patchcord kit.
Well, I'm having problems getting the software loaded on my laptop, despite numerous emails to the seller (from England - " bmw-cable").
Is this what you are using?
If so, can I get some hints on loading it and making it work?
Thanks.
      03-11-2013, 08:44 AM   #4
ricanbandit
ricanbandit's Avatar
19
Drives: 2008 M Roadster
I use this one with The Torque app on my SGS3, love it great little device
http://www.amazon.com/BAFX-Products-...dbii+bluetooth
///M Roadster: Stromung Exhaust, Stubby, BMW Performance Shift Knob, RPI scoop, TSW Nurburgring's, Total DeBadge
      03-11-2013, 08:44 AM   #5
Shipkiller
Shipkiller's Avatar
Drives: Me
ODB-II is the same for all brands. It only reads engine/emissions faults. If you want to read any of the other data on the car, then you need special equipment or software. There is no standard here like there is for ODB-II.
PM me your email address. I will send you my procedures for installing INPA on Windows 7 (including 64).
INPA is the real deal....
      03-11-2013, 09:52 AM   #6
stasha
Thanks Rican. I'll check it out.
Shipkiller -- will PM -- BTW, I'm in Portsmouth, VA. "Shipkiller" = aviation? missiles?, subs?
      03-11-2013, 09:59 AM   #7
Shipkiller
Shipkiller's Avatar
Drives: Me
If you can't PM: shipkiller1181 at g m a i l . c o m
If you want a painless 'guaranteed to work' solution, try BMTechnic. I have the Ebay cable and had to search the internet for all the various forms of the BMW software. I learned may things but I went ahead and purchased the BMTechic cable and software even after I had my system up and running.
The BMTechnic software installer is just bulletproof. It just works.
Retired 24year Bubblehead.
      03-11-2013, 10:21 AM   #8
stasha
All I want to do is register my new battery without paying the stealer $200 -- and so the AC/Heat and NAV screen will start working again.
      03-11-2013, 10:26 AM   #9
Shipkiller
Shipkiller's Avatar
Drives: Me
BMW Z4's do NOT need to register a new battery.
Sounds like your car is now in Transport Mode.
      03-11-2013, 10:47 AM   #10
stasha
Yep. Happened after I had a dead battery. How do I exit Transport?
      03-11-2013, 12:08 PM   #11
Shipkiller
Shipkiller's Avatar
Drives: Me
Once you get your software/cable up and running, I think INPA will do it, but I am not sure since I have never had to do this myself.
      03-13-2013, 01:15 AM   #12
Steenos
Drives: 2007 Z4M Coupe
2007 M Coupe  [0.00]
Shipkiller I'd like to talk to you about getting INPA installed on my machine if possible. Thanks
      03-13-2013, 11:14 AM   #13
Shipkiller
Shipkiller's Avatar
Drives: Me
It will have to be via email. I am currently in Hawaii for the next 35 days.
      03-13-2013, 11:51 AM   #14
Steenos
2007 M Coupe  [0.00]
Have a great trip! I bought this cable on ebay http://www.ebay.com/itm/271119742928...S:3160&vxp=mtr
The cable comes with INPA software. I'll let you know when it arrives.
      03-13-2013, 01:31 PM   #15
stasha
Steenos,
I purchased mine from eBay at http://www.ebay.com/itm/261163472483...84.m1497.l2649
The ads are very similar. I suspect it all comes from a Romanian contact.
Will be curious if you have probs. I have probs getting the Virtual program up -- but Ship sent me some instructions that might be a work around. Have yet to carve time out to try them.
      03-14-2013, 02:14 PM   #16
thelinux
Drives: 2008 Z4 3si
If you want to buy creader scanner, it's really cheap here. Only $59 and free shipping. I think bavaauto sells it for $179.
http://www.aliexpress.com/item/Cread...530561793.html
      03-14-2013, 03:16 PM   #17
StickMon
StickMon's Avatar
Drives: 2006 MR
The Product Description on the Creader is classic!
      03-14-2013, 05:58 PM   #18
stasha
I read the product description -- what in the world does it do?? It looks like a Chinese person who took English in HS is translating using a dictionary and thesaurus.
Can you tell me what the Creader does? Why would I want it?
Thanks.
      03-14-2013, 06:49 PM   #19
StickMon
StickMon's Avatar
Drives: 2006 MR
Actually, it was probably in Chinese and run through something like Google Translate.
Looks like a generic OBD-II scanner. I have an Actron I use on the other cars, but the generic ones aren't very good for BMWs.
I carry a Peake Research in the trunk for use on the Z, and use INPA and DIS for deeper probing.
      03-14-2013, 07:04 PM   #20
stasha
You're right -- it's like a Google translation.
What is a "Peake Research"?
      03-14-2013, 07:26 PM   #21
thelinux
Drives: 2008 Z4 3si
Thanks.
http://blog.bavauto.com/10813/bmw-an...ing-live-data/
      03-14-2013, 08:02 PM   #22
StickMon
StickMon's Avatar
Drives: 2006 MR
This gismo. Reads proper BMW hex codes and will reset not only SES light but service intervals as well.
