Reply
      11-28-2012, 06:38 AM   #1
Sirhan
Drives: Z4 M Coupe
HELP! - CSL 19inch Z4M - F:ET44 R:ET27
Guys
I have a set of of CSL wheels for my 2007 Z4M Coupe.
The specs are as follows:
FRONT- 19X8.5 ET 44 - TYRES: 265/30/19
REAR - 19X9.5 ET 27 - TYRES: 235/35/19
Will this work with no spacers?
Sirhan is offline
      11-28-2012, 06:46 AM   #2
Beedub
Yep no problem but the front won't look too hot, it will appear rather sunken...
A 10mm front spacer would give near ideal conservative z4m offsets.
Beedub is offline   United Kingdom
      11-28-2012, 06:55 AM   #3
Sirhan
Drives: Z4 M Coupe
Thanks Beedub, I do not want to use spacers so I guess that I will live with the sunken look.
Sirhan is offline   Reply With Quote
      11-28-2012, 07:56 AM   #4
dubsesd
dubsesd's Avatar
Drives: M coupe / 328xi LCI
Why don't you want to use a spacer?
2006 ///M Coupe TiAg / IR -- H&R coilovers/RPI exhaust/ZHP knob/19" Morr vs8.2 hand brushed/Stoptech 355mm 6/4 BBK/Turner strut bar/polished diagonal braces/m tower caps/tekarbon 2x2 coil cover/Michelin PSS/gloss black kidneys/painted gloss black roof/mstache 2 front lip/AFE dry intake/RPI forced induction/colormatch corners/black chrome //M badges/rear diffuser/aeroskirts/rogue mounts/DKF adjustable hangers/22%tint/euromode lighting/LED interior & plate lighting
dubsesd is offline   Reply With Quote
      11-28-2012, 08:49 AM   #5
v3.2mc
Not a New Member
v3.2mc's Avatar
i'm sure you know this and your OP has a typo...
the 235 tread should be on the 8.5", and the 265 tread should be on the 9.5".
v3.2mc is offline   United_States
      11-28-2012, 10:43 AM   #6
Sirhan
Drives: Z4 M Coupe
sorry, new to this forum. What a OP?
      11-28-2012, 10:47 AM   #7
Sirhan
Drives: Z4 M Coupe
Hi Dub
I dont want a spacer because of the vibrations and safety aspect. I drive above 260km/h often so I would not be too comfortable at those speeds with a spacer.
Freeways are gr8 in SA and cops can be bribed
If I use 245 at the front, will it rub?
      11-28-2012, 11:04 AM   #8
v3.2mc
Not a New Member
v3.2mc's Avatar
OP = Original Post = 1st post in the thread
welsome to zpost!
      11-28-2012, 11:25 AM   #9
Geauxkart
Geauxkart's Avatar
Drives: 2007 Z4 M Coupe Sepang
The "good" spacers are piloted, so they are concentric. I don't think strength is much of an issue, put the 10mm up front. It's the same setup I have. Zero vibration. Got them from ECS tuning.
Geauxkart is offline   Reply With Quote
      11-28-2012, 12:02 PM   #10
Beedub
Originally Posted by Sirhan View Post
Hi Dub
use a proper hubcentric spacer with longer studs or bolts is essentially the same as a lower offset wheel from the factory.... the spacers that are of concern are the bolt on type that then use their own studs..... like what the GTR owners use!!
      11-28-2012, 12:13 PM   #11
inTgr8r
inTgr8r's Avatar
Drives: 07 M Coupe
^ whs
some (Porsche) cars come with OE spacers
Alpinweiss '07 M Coupe •Eisenmann Sport-Ceramic Black•Diablo-X•Fabspeed Headers•VRS Hyper-Narrow rear wing•Autosolutions SSK•APR splitter•Tekarbon headlights•StrongStrut STB•KW Clubsport•Poly FCAB/RTAB•Volk Racing G2•Direzza ZII•Stoptech BBK c/w Cool Carbon pads
inTgr8r is offline   Canada
      11-28-2012, 01:25 PM   #12
marinb
marinb's Avatar
Drives: 2007 M Coupe
If you want you can run 245/35/19 front and 285/30/19 rear and it won't rub.
marinb is offline   United_States
      11-29-2012, 01:42 AM   #13
Sirhan
Drives: Z4 M Coupe
Hi Geauxkart
Do you have the link of the spacer that you used? part number?
      11-29-2012, 01:43 AM   #14
Sirhan
Drives: Z4 M Coupe
Without a spacer running 265 at the back and 235 at the front. Will i experience a bit more oversteer?
      11-29-2012, 05:06 AM   #15
Dammmittt
My favorite sign.
Dammmittt's Avatar
You could try 245/35 front, 265/35 rear like I have on my VS8s...while not a perfect height match, I think the extra rubber up front is worth it.
Best Website EVER!
Dammmittt is offline   Germany
      11-29-2012, 06:44 AM   #16
Geauxkart
Geauxkart's Avatar
http://www.ecstuning.com/BMW-Z4-M_Co...acers/ES11297/
And make sure to order the longer bolts they recommend.
      11-30-2012, 03:59 AM   #17
Sirhan
Drives: Z4 M Coupe
check out the pics
      12-01-2012, 06:34 AM   #18
Beedub
where did you pick these replicas from??
      12-01-2012, 10:33 PM   #19
dubsesd
dubsesd's Avatar
second, i hope you knew these are not authentic...
      12-02-2012, 07:41 AM   #20
Geauxkart
Geauxkart's Avatar
How can you guys tell??
      12-02-2012, 07:50 AM   #21
dubsesd
dubsesd's Avatar
there should also be a BMW imprinted in between the spokes. may also be a bbs marking on the inside. the spokes are also skinier than original csl wheels. if you weigh them, you will also see a difference
      12-02-2012, 08:09 AM   #22
Beedub
note the bmw stamp opposite the ///M badge ;-)
Reply
Forum Jump
