Go Back   ZPOST > Marketplace > Sponsors Classifieds
Reply
      11-21-2012, 03:16 PM   #1
VF-Engineering
Drives: E92 M3
\ VF-Engineering: Z4M VF480 and VF570 superchargers /
We are proud to announce the release of our
Z4M Coupe and Roadster superchargers
available in 2 power stages
VF Z4M
Maintaining the original BMW quality, smoothness and reliability were the key factors in the VF design. VF have harnessed reliability of Vortech superchargers with their 10 years of supercharging experience and worldwide OEM supply contacts to create the ultimate supercharger system for the ultimate driver’s car.
Some Background and History of our S54 development:
In late 2004, VF purchased a 2005 model M3 and chose to create and test its complete aftercooled Stage 1 kit. A production manufactured aluminum manifold with integrated air-to-water heat exchanger (charge cooler) is provided for added value and greater performance compared to similar air/air systems. Typically used in European Rally cars, air/water cooling is the ultimate in aftercooler technology for on and off the race track. Air/water cooling provides superior cooling ability over air/air without lengthy ducting while creating cooler intake temperatures for more powerful and reliable ignition.
The E46 M3 Stage 2 kit [released Feb 08] offers even greater performance via extra boost from a smaller supercharger pulley, replacement stiffer serpentine belt tensioner and upgraded custom stage 2 software ECU flash with larger stage2 fuel injectors and MAF upgrade. This kit requires the use of high performance cats. The test car was setup with Supersprint headers and Euro M3 cats. Drag racing and aggresive back to back peak rpm shifting will likely require a clutch upgrade. 100 octane fuel recommended when used on the race track. A pre-cat wideband air/fuel ratio monitoring gauge is recommended.
Onto the Z4M
Around 2010, VF decided to change all tuning to be done 100% in-house by VF for VF amidst a bevy of multiple on-going projects. The decision eventually lead to VF-Engineering facilities to now be dedicated to only Research and Design. Through 1000's of miles of real-world testing in various conditions combined with our knowledge and data from our revolutionary air:water cooled E46M3 S54 systems, VF has created the Z4M VF480 (Stage 1) and VF570 (Stage 2) system for the Z4M community who has long been waiting for a new, reliable, high-performing supercharger option with the advanced and superior air:water cooling capabilities. All the aspects of the E46 M3 superchargers are now inherent to the S54 Z4M superchargers.
Special to the Z4M
You may find that ECU software programming can lead to further complication with shipping, downtime, installation/labor time. VF-Engineering has decided to take the time to include our All-New Hex Flash OBD2 Cable with every kit at no additional cost.
The Hex Flash Cable will allows for multiple features:
1) Upload our custom VF-mapping directly to your car via the OBD2 port and your laptop.
2) Do full readouts of the current state of your car
3) Use the cable and Hex Flash software as a fully functional Diagnostic Tool to read any error or check engine lights.
4) Revert to stock software at anytime for any reason.
Stage 1
VF480
480 hp / 340 ft/lbs
5.5-6.0 PSI
V3-SQ supercharger
Cast manifold with slide-in air/water cooled cartridge
ECU software flash
Stage 2
VF570
570 hp / 380 ft/lb
8.5-9.0 PSI
V3-SQ supercharger
ECU software flash
Please PM, email, or call for Special Forum Pricing
Photo credit: Rated M Roadster
VF-Engineering is offline
      11-30-2012, 03:39 PM   #2
VF-Engineering
Drives: E92 M3
Bump for updates and new information!
Read more about it:
Official info thread - http://www.zpost.com/forums/showthread.php?t=772916
User DIY Install - http://www.zpost.com/forums/showthread.php?t=771394
VF-Engineering is offline   Reply With Quote
      12-03-2012, 05:05 PM   #3
VF-Engineering
Drives: E92 M3
Newest pic of VF570 installed on Z4M.
Courtesy of Rated M Roadster.
      12-03-2012, 05:15 PM   #4
Beedub
That pic is a kit seller.
lol!!
i love how the lines of the intake manifold match the lines on the stock cam cover.... thats sick.
Beedub is offline   United Kingdom
      12-03-2012, 05:46 PM   #5
dubsesd
dubsesd's Avatar
Drives: M coupe / 328xi LCI
blew my mod budget this winter. buying this upcoming fall!
2006 ///M Coupe TiAg / IR -- H&R coilovers/RPI exhaust/ZHP knob/19" Morr vs8.2 hand brushed/Stoptech 355mm 6/4 BBK/Turner strut bar/polished diagonal braces/m tower caps/tekarbon 2x2 coil cover/Michelin PSS/gloss black kidneys/painted gloss black roof/mstache 2 front lip/AFE dry intake/RPI forced induction/colormatch corners/black chrome //M badges/rear diffuser/aeroskirts/rogue mounts/DKF adjustable hangers/22%tint/euromode lighting/LED interior & plate lighting
dubsesd is offline   Reply With Quote
      12-03-2012, 07:45 PM   #6
ricanbandit
ricanbandit's Avatar
Drives: 2008 M Roadster
Damn!
///M Roadster: Stromung Exhaust, Stubby, BMW Performance Shift Knob, RPI scoop, TSW Nurburgring's, Total DeBadge
ricanbandit is offline   Reply With Quote
      12-21-2012, 03:05 PM   #7
VF-Engineering
Drives: E92 M3
I know a lot of you guys are interested. In case you didn't know...
All BMW superchargers are 10% off with Free Shipping
until it all ends Dec. 31st 2012
Place Your Deposit
Get your supercharger with a 10% deposit
by credit card before it all ends.
After you see these prices
You will realize how much you will save. Take your car
beyond the norm and expand your power to apocalyptic proportions!!!
Z4M
VF480 $800.00 off
480 hp / 340 ft/lbs
5.5-6.0 PSI
V3-SQ supercharger
ECU software flash
VF570 $900.00 off
570 hp / 380 ft/lb
8.5-9.0 PSI
V3-SQ supercharger
ECU software flash
      12-28-2012, 07:02 PM   #8
VF-Engineering
Drives: E92 M3
Bump!
Reserve your kit today with a 10% deposit
Reply
Forum Jump
