Reply
      11-21-2012, 08:43 AM   #1
Spedracer81
Drives: Z4MC
Need for speed..
Beside the obvious (CAI,Exhaust,ECU) what else can I do to get some more power? Without going crazy and supercharging anything else I can bolt on so I can stomp on my friends Subaru..
Spedracer81 is offline
      11-21-2012, 10:15 AM   #2
davesz4mc
Drives: 2007 z4mc
Light weight flywheel, Performance ignition coils, complete fluid change (motor, tranny, rear end), re-gear the rear end, tune.
The ones you mentioned make the other more effective.
2007 Z4MC, 1" drop H&R Springs, Evolve Tunning, Headers, K&N Filter, RPI scoop, Red top high energy coils, UUC Red Poly mounts (none bolt-through), UUC Lightweight Flywheel with Organic Clutch and a custom exhaust with just one AeroTurbine muffler.
davesz4mc is offline   Reply With Quote
      11-21-2012, 10:22 AM   #3
Alexander
Mad tyte EuR0 style boooi <--- Joke
Alexander's Avatar
Drives: E30, E85, MKVI
Alexander is offline   United_States
      11-21-2012, 03:20 PM   #4
beta
Drives: 2006 M Roadster
CAI and Exhaust are not proven to give more power. If you did the full exhaust: a freer flowing cat + x-pipe + exhaust it's more likely, but no one has posted dynos to prove it. Headers will still provide more power than full exhaust.
Proven ways to increase speed: euro headers, tune, more aggressive differential gearing. The other thing you can do is lose weight: racing seats, lightweight battery, lightweight wheels, etc.
Losing weight is often overlooked, but if you look at the 2012 cayman R (which has a 4.2 0-60) it has virtually the same HP/torque figures as the Z4 M but weighs 100+ lbs less. There are a LOT of other differences (PDK, etc.) but you get the idea.
beta is offline   Reply With Quote
      11-21-2012, 03:44 PM   #5
inTgr8r
inTgr8r's Avatar
Drives: 07 M Coupe
^ +1 hammer....nail....on head
Alpinweiss '07 M Coupe •Eisenmann Sport-Ceramic Black•Diablo-X•Fabspeed Headers•VRS Hyper-Narrow rear wing•Autosolutions SSK•APR splitter•Tekarbon headlights•StrongStrut STB•KW Clubsport•Poly FCAB/RTAB•Volk Racing G2•Direzza ZII•Stoptech BBK c/w Cool Carbon pads
inTgr8r is offline   Canada
      11-21-2012, 07:42 PM   #6
blender
Custom User Title
blender's Avatar
Drives: black
Torque is what shoves you down the road.
Excluding a supercharger ($5-7K), a rear differential swap at $3K is the biggest bang for the buck. You get 11% more 'effective' torque out of a 4.11 gear set, at the expense of top end speed, which you'll probably never use in a convertible anyway. I rarely see >130.
The diff swap is also visually indistinguishable from stock, if that matters.
blender is offline   United_States
      11-21-2012, 10:14 PM   #7
Spedracer81
Drives: Z4MC
all great ideas, but I'm trying to keep the car stock, or at least make changes that are easily reversible...
Spedracer81 is offline   Reply With Quote
      11-21-2012, 10:45 PM   #8
ZStig
Drives: VT2-500 M Roadster
headers, gears, and a tune to take advantage of the headers. Everything else is a waste of money.
and then you'll get a supercharger when you realized you spent $3000 to make 30rwhp
ZStig is offline   Reply With Quote
      11-21-2012, 10:51 PM   #9
JeffchaPz
JeffchaPz's Avatar
Drives: 2007 Z4M
OP - are you able to turn off traction control off.... hit sport mode and take off as fast as possible form a red light without loosing traction?
I ask.... cus I couldn't. Even thought I need new tires, I practice every time I get a chance and without loosing traction - When I do that I can see the speedometer clime up much quicker.
One time at a red light a dude in a little KIA with a loud exhaust got on my left side and rev it few times... I looked at him - it was clear he wanted some.... when the light turned green I sat on the same spot burning my tires while he took off.... once I changed to 2nd gear I caught up to him and past him - by the time I shift to 3rd... he was tiny in my rear view mirror... you know what I mean?
Don't floor it in 1st or 2nd... learn that trick and let me know if that helps.
I totally agree with what other members have suggested and I'm heading that way. I already have euro headers, I added my name to the list to buy DKF straight S-pipes and I'm ordering my tune this weekend. Now that it's cold/winter I hope to find me a good deal on ultra high perf summer tires. AND I'll be killing the mod-bug once and for all..... I hope
Drive safe.
Jeff.
JeffchaPz is offline   Reply With Quote
      11-21-2012, 10:54 PM   #10
ZStig
Drive safe.
Jeff.
lolwut? sport mode to launch faster in 1st gear? Don't floor it in 1st or 2nd?
1. Sport mode makes it really really difficult to launch this car at the limit of slip and optimal acceleration.
2. I have GOOD tires, and when they're warm, I go full throttle in 2nd AND 1st gear putting down at least 400rwhp with minimal wheelspin
3. The ideal launch isn't without wheelspin. Its with about 10% wheelspin
get some better tires, hit a real place you can learn to launch a car without going to jail (quarter mile racetrack), and then come back with advice. I don't like calling people out, but I couldn't just let this "advice" sit here.
      11-21-2012, 11:00 PM   #11
JeffchaPz
JeffchaPz's Avatar
Drives: 2007 Z4M
Well... if I do.... I'll be smoking my tires and not moving much.... I'm sure my tires have a lot do with the problem... the trick is to push the car to the point where it barely looses some traction.... my opinion.
      11-21-2012, 11:19 PM   #12
ZStig
you should be able to go full throttle in 2nd gear, on warm tires, and not lose any traction, unless you're high performance summer tires and its under 60*F outside. Then you just have to lower your rear pressure to about 28psi, and warm them up a little bit.
What size/brand tires do you have on right now and how cold is it outside?
I'm not arguing the point that you need to push the car until it barely loses some traction, just the sport mode, your full throttle comment as its all because of your tires/pressures/temperature
      11-21-2012, 11:21 PM   #13
ZStig
The topic of launching this car deserves a whole seperate thread, cause we didn't even begin talking about how to modulate the clutch and what RPM to launch at.... 2 more huge factors in laying down a good launch
      11-21-2012, 11:36 PM   #14
JeffchaPz
JeffchaPz's Avatar
Drives: 2007 Z4M
Z - I cant remember the exact model name right now.... but I know they are Yokahama.... and I know for sure they are not high performance tires. Last time I tried this it was about 80 some degrees few weeks ago.... I def have no traction in 2nd gear around 4 - 5 k
      11-21-2012, 11:41 PM   #15
seank
enthusiast
seank's Avatar
The best bang for your buck is a 4.10 diff or you can throw tiny wheels on there!
seank is offline   Reply With Quote
      11-21-2012, 11:52 PM   #16
ZStig
yeah, if it was 80* you need to upgrade tires my man. My personal recommendation is bridgestone re-11.
      11-22-2012, 12:21 AM   #17
beta
Just wanted to chime in that it really isn't that much if you look around. Gears can be bought then shot peened, REM polished and installed in your existing diff for less than 1k.
Then get wheels/tires. Any other mod (exhaust/CAI) will be for noise. Doesn't mean they're not worth it though.
An NA car should have no issues with traction with warm summer tires. First I can only spin if I intentionally try to, second all I get is a chirp if I have a good shift.
A 4.10 diff with 275/35 rear tires is almost exactly 15% more torque. That's a little bit more torque than ESS stage 1.
      11-22-2012, 05:46 AM   #18
Yeggman
Drives: 2009 Z4 s3.0i 6MT
OP, Buy a Corvette. If your friend has a WRX STi, you are not going to keep up.
Jeff: Tire smoking and street racing Kia's? How old are you?
Yeggman is offline   Reply With Quote
      11-22-2012, 08:45 AM   #19
GammaZeta
Drives: 1
+1...if all you're looking for is cheap, straight line speed...you picked the wrong car.
GammaZeta is offline   Reply With Quote
      11-22-2012, 02:57 PM   #20
JeffchaPz
JeffchaPz's Avatar
Drives: 2007 Z4M
REs are def in my radar....
Any thoughts on Toyo R888? My car is loud enough already so tire noise shoudn't bother me.... http://www.tyrereviews.co.uk/Tyre/Toyo/R888.htm
Yeg... I'm 93
      11-24-2012, 10:50 AM   #21
Yeggman
[/url]
Yeg... I'm 93
I figured as much Young whippersnappers are always stirring up trouble.
      11-24-2012, 11:41 AM   #22
dorifto88
Drives: 88 Nissan Pathfinder
honestly, take a leisurely drive in the mountains.
dorifto88 is offline   Reply With Quote
Reply
Forum Jump
