Reply
      12-11-2012, 09:23 PM   #45
johanness
Hans X2
johanness's Avatar
Drives: 2008 Z4MC
Great #'s! Congrats
|Euro Headers|SS X-Pipe|REMUS|UUC|Zeck CDV|AFE Intake|H&R Springs|RPI Scoop|ZHP|AC Schnitzer Side Skirts|ESS DirectFlash|APEX|RE RaceBrace|
the very last TiAg Coupe
johanness is offline   Reply With Quote
      12-11-2012, 09:53 PM   #46
Rated M Roadster
Rated M Roadster's Avatar
Drives: E85 M Roadster VF570
Thanks guys!
Graph with boost:
Z4M VF570 DynoBoost by M detaR, on Flickr
Video of run:
http://youtu.be/V4UZL4scGzU
Z4MR ll VF570 472whp 332wtq ll AA headers
H&R coilovers ll ARC-8 w/ Hankook RS3
Stromung ll Aero skirts ll Passport SRX
Rated M Roadster is offline   Reply With Quote
      12-11-2012, 09:59 PM   #47
GuidoK
Zweistein
GuidoK's Avatar
Drives: Z4 3.0i ESS TS2
Nice run. Nicely documented with video etc.
GuidoK is offline   Netherlands
      12-11-2012, 11:50 PM   #48
dorifto88
Drives: 88 Nissan Pathfinder
dumb question, besides the 570, what engine modifications have you done?
dorifto88 is offline   Reply With Quote
      12-11-2012, 11:57 PM   #49
Rated M Roadster
Nothing to the engine. I do have AA headers though, which helps.
      12-12-2012, 12:06 AM   #50
dorifto88
thank you sir for the reply =)
      12-12-2012, 04:06 AM   #51
pokeybritches
pokeybritches's Avatar
Drives: G-Power Z4M, VF Z4 3.0i, ZJ
2003 BMW Z4 3.0i  [4.33]
2006 BMW Z4M  [0.00]
Good numbers. Did you have the AA headers in the before dyno?
G-Power Z4M (April Install) and VF Engineering Z4 3.0i - too many mods to list
pokeybritches is offline   Afghanistan
      12-12-2012, 09:07 AM   #52
Geauxkart
Geauxkart's Avatar
Drives: 2007 Z4 M Coupe Sepang
That lean condition scares me...
But the dyno is absolutely awesome.
Let us know if you get the tune straight, I am going FI but waiting on all the charts to decide the system, this wins so far, but need to make sure you get things straight first!
Thanks for being the guinea pig, and I hope that it all works out.
Geauxkart is offline   Reply With Quote
      12-12-2012, 10:18 AM   #53
Beedub
where are you seeing AFRs??? i cant see them??
OP out of interest did you log AFRs???
OP great numbers, you've documented it much better then all of the rest of us, i will be back at the dyno shortly for my revisions...... i promise to document the same, i take video with my d3200. Great great numbers!!!!
Beedub is online now   United Kingdom
      12-12-2012, 11:14 AM   #54
Geauxkart
Geauxkart's Avatar
Shut it down early cause it was running a little lean (VF and I will have to work on that). Very happy with the result though.
I read closely. Go back a page.
      12-12-2012, 11:33 AM   #55
Beedub
you did indeed ;-)
what were the AFRs saying at the shut down point rated??
      12-12-2012, 02:02 PM   #56
Rated M Roadster
I put the headers on with the SC.
Here's a dyno with AFR (notice change at 6750 rpm):
Z4M VF570 DynoAFR by M detaR, on Flickr
I have a BavarianTechnic scan tool (another toy to play with ) in the mail to determine if there were any discrepancies in the tail pipe reading since I do still have section 2 cats in place. I will be doing recordings of different aspects along with lambda (then converted to AFR) readings from both banks. Should be an easy fix assuming it wasn't simply a false reading by the dyno.
This is what I'll be doing with the BavarianTechnic tool: http://www.m3post.com/forums/showthread.php?t=723927
      12-12-2012, 03:10 PM   #57
Beedub
arhhh i see that is a lean spot for sure...... lets hope its inaccurate dyno reading ;-)
      12-13-2012, 11:40 AM   #58
Geauxkart
Geauxkart's Avatar
I keep thinking about these graphs, thanks again for taking the time to put them up. Those are awesome numbers.
Keep us posted on your experience, there are few reviews from other Z4M guys out there, and I really like this kit.
      12-13-2012, 11:47 PM   #59
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
Awesome!!!
2008 Interlagos Blue M Coupe
CDV delete : ZHP Knob : RE Trans Mounts : RE Clutch Stop : Stubby Antenna : Michelin PSS 235/265 : Magnaflow Axle-Back
mgwatson48 is offline   Canada
      12-14-2012, 08:47 AM   #60
GuidoK
Zweistein
GuidoK's Avatar
You mean the lean spot above 7300rpm? (that the afr curve starts to rise at 6700rpm)
I think that's intentional, seeing that both torque and power behave accordingly.
I think they adjust the mapping there to get an even torque graph and continous power buildup (lean mixture=more power)
I don't know when the lean mixture becomes too lean to cause damage (especially @ high revs), but it's still well below stoichiometric of course.
      12-14-2012, 10:06 AM   #61
ZStig
Drives: VT2-500 M Roadster
Daaamn them be some strong numbers! Let me know how the clutch holds up with hard launches
ZStig is offline   Reply With Quote
      12-14-2012, 11:50 AM   #62
pokeybritches
2006 BMW Z4M  [0.00]
What's a dyno look like when your fuel pump can't keep up with the demand?
ESS could have been right about the fuel system needing to be upgraded. It may not be tuning.
      12-14-2012, 02:20 PM   #63
GuidoK
Zweistein
GuidoK's Avatar
If it wouldn't be tuning you'd get an engine light with some obd2 code like p0171 or so.
But what they can have done is adjust the mixture (in the tuning), so the pumppressure doesn't get too low.
If you calculate: 6750rpm the afr is about 11.8, so thats about 572x parts gas (6750/11.8)
7800rpm (the max in this run) the afr is about 13.6, so thats (also) about 573x parts gas.
If the afr hadn't changed, the parts gas used (per minute) would be higher of course.
It's a big coincidence that in the high revs the engine (with higher afr) uses exactly as much fuel than in the highest rev before the afr start to rise.
So it's not because the fuel pump stops suppling fuel (no obd code), but maybe it is the result of careful tuning not to overstress the pump (resulting in fuel pressure too low) and letting the afr rise.
But a lean mixture gives more power (that could be the other reason). It's just bad for your engine if it gets too lean (valve temperature too high so they burn).
Still, then why have a high afr in the mid revs.
If the afr didn't rise above 6800rpm, it sure wouldn't produce so much power I think. Maybe up to 50HP less.
      12-14-2012, 02:26 PM   #64
Beedub
ok maybe im reading this wrong but doesnt the AFR go superlean after 6.7ishk rpm???
This gradual leaning Looks like a fueling supply issue BUt.... maybe the sniffer backed out the exhaust??? if those are indeed accurate.... the motor wont survive that for long.
i see 11.4 at redline....
^^^ dyno problem?????? it must be???
      12-14-2012, 02:37 PM   #65
tikamak
^_ What bee said. Run a dyno again to make sure that this not the case
tikamak is online now   Lebanon
      12-14-2012, 02:38 PM   #66
GuidoK
Zweistein
GuidoK's Avatar
stoichiometric is 14.7
Everyting below that is theoretically rich. Until 2600 its about 14, so what is 'lean'
But it almost can't be a dyno problem, because otherwhise the torque and power curve would gradually fall off, and instead it rises faster than with the rich mixture.
If it would be a dyno problem both the afr sensor/calculation (I don't know; do they pick that up directly from the first lambda probe?) and the power sensor/calculation would be at fault. That would be a coincidence...
Reply
Forum Jump
