FORUMS
- 5
| 11-17-2012, 04:02 PM | #1 |
Replacing Steering Wheels Spokes...help!
I have a new set of spokes and was able to replace the lower spoke easily. I am now stuck on the two side spokes. I removed the torx screws but it appears that not only holds the spoke together but holds the buttons on as well. Even after removing the screw, the spoke won't come off as the button component is in the middle (those of you who have removed these will know what I am talking about).
So, my question is, how do I get these off from here? I have read a thread about inserting a screwdriver into the holes on top and pushing in on some sort of spring to release one side of the airbag at a time and then removing the airbag to gain access but I cannot seem to feel any kind of spring and I don't want to continue poking around in there in case I cut a wire. Any advice?? Also, the button housings themselves are also scratched up and I would like to replace them but I cannot find a p/n for them anywhere including realoem.com. Has anyone also replaced these? If so, p/n ?? Thanks |
| 11-17-2012, 05:29 PM | #5 |
The video is for an E46, I'm only assuming the Z4M is the same. I did this on my E46 and it was simple.
Let me know how you make out. My spokes and buttons are looking pretty ratty. Was thinking of trying the Dinoc film. If you can post your experience (pics haha) removing the spokes, that would help me in the spring! |
| 11-17-2012, 07:49 PM | #6 |
Retired Paratrooper
Vid is correct for pulling the airbag off on the Z4. One spring clip on each side access through the holes behind the spokes. I used a small phillips screwdriver that fit the holes perfectly and hit the springs with no problem. I ended up not even disconnecting the wires to the airbag. I wasn't taking off the steering wheel and there was enough slack in the wiring harness for me to pass it though the steeing wheel and let it rest while I worked on the spoke covers.
After the air bag is off I didn't have any problem getting the side spokes off. Just remember to disconnect the battery before messing with the air bag so you don't set an airbag fault code. I wrapped my spokes in a 3d carbon fiber vinyl and they look a lot better. Should have come from the factory like this. Wrapped a few things to accent the interior. ![]() ![]() ![]() ![]()
Retired US Army 82nd Airborne Division.
- There's no such thing as a perfectly good aircraft. I have the option to get out while you have the pleasure of riding it in. ![]() |
| 11-17-2012, 07:55 PM | #7 |
![]() ![]() ![]() Drives: 2007 Z4MR silver grey Join Date: Feb 2011
I changed all mine out without removing the airbag, it can be done. I'll look at mine and see if I can remember how I did the side spokes.
John |
| 11-17-2012, 08:09 PM | #8 |
pmmjarrett, that looks really good! I was thinking of doing the same.
Do you have to remove the pieces that you want to wrap (ie: all the trim that you did on your car, did you have to remove it first??) I'd like to do the spokes and button covers like you did. If you have to remove the button covers to get the film on it, is it obvious to do so? Is the stuff you used the 3M "Dinoc" film? (http://autovinylsolutions.com/3M_108...Fc5cMgodCnUAVw) Is it easy enough to work with? I don't have any detailing experience per se. |
| 11-17-2012, 09:58 PM | #9 | |
Retired Paratrooper
What I am using is NOT Dinoc. It's a textured Chinese wrap that I import. I have enough of this stuff in the shop right now to wrap the whole car 5 or 6 times. Mabey I should wrap my house LOL. I removed everything I wrapped and recommend it so you can tuck the edges and not cut into stuff you don't want to cut into, like leather, with the razor when trimming it up. I think it's pretty easy to work with and the stuff with air drain channels makes for a nice easy bubble free installation. The part with the buttons on the steering wheel was prolly the biggest PITA part I did. Plenty of vids on youtube showing how to install wraps. Just make sure the parts you are wrapping are very clean and dry. My experience for ease will be greatly different than some though as I was a bodyman back 25+ years ago and still dabble a bit in it from time to time... As well as I have more tools than Tim "the toolman" Taylor too LOL Before ![]() After ![]() I took every piece I wrapped apart as far as I could to get the best look possible. ![]() To take off the console trim, you have to take out the entire console. ![]() On the door handle you can see how I tucked the edges and trimmed. ![]() I even took off the handles to wrap them so you wouldn't see any tan when pushing opening the storage door. ![]() ![]() Started playing with it a bit on the exterior, was interested on how these pieces would look wrapped vs painted body color as I'm right in the middle of prepping the car for paint. ![]() ![]() ![]() ![]()
| 11-20-2012, 01:43 PM | #11 |
The Wrapgician
Drives: z4si Join Date: Jan 2012
I hope you havent get your car wrap in chinese wrap film... you will 100% regret. it stick not well, peel after high temp from sun light, it would damaged your from removing the film off. 3m 1080 isnt that expensive compare to these cons.
| 12-03-2012, 05:09 PM | #12 |
Found another vid, this one from a Z4. Followed it and used a T20 screwdriver to push the springs in...piece of cake! Didn't even disconnect the airbag.
I now have the spokes and buttons replaced...looks awesome again! |
| Bookmarks |
