      11-13-2012, 11:21 PM   #1
usaz4mcr8cr
usaz4mcr8cr's Avatar
13
Drives: Z4MC
Another euro headers & euro cat install thread
I have a set of euro headers and euro cats in transit.
After "exhausting" the search function (pun intended), I need some help with part #'s:
6 Header to engine gaskets
1 Header to S piping/euro cats gasket
1 S piping/euro cats to X piping gasket
4 heat shield clips for the O2 sensor wiring
also, will I need to wrap the O2 sensor wires to protect the from the heat after I unfold them? If so, what kind?
If there are any additional parts that I may need please chime in. I plan to install them myself with the help of a buddy.
What tools will I need? Any tips or advice will be greatly appreciated.
Thanks in advance.
      11-24-2012, 07:34 PM   #2
usaz4mcr8cr
13
Drives: Z4MC
No help?
      11-24-2012, 07:44 PM   #3
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Nothing special aboutvt hose parts, pick them up at your local dealer or order online.
You'll find what you need here.....
http://www.realoem.com/bmw/select.do
      11-24-2012, 08:08 PM   #4
beta
Drives: 2006 M Roadster
You're in luck, typed this up for a friend. This is all the hardware involved.
Copper Collar Nut x 18 11 72 1 437 202
Header to the engine, 3 per pipe hence 18
Exhaust Manifold Gasket x 6 11 62 7 830 667
Gasket between header and engine
Exhaust Stud x 18 07 12 9 900 298
Studs on the engine for the headers
Exhaust Seal Ring x 2 11 62 7 830 668
Ring between headers and cats
Hex Nut (M10) x 4 18 30 1 317 898
Copper nuts between headers and cats
Exhaust Gasket x 2 18 30 7 830 674
Gasket between cats and x-pipe
Hex Nut (M8) x 6 11 62 1 744 323
Nut between cats and x-pipe
I used a cloth tape, check my mod thread in my sig. If I were to do it again I'd check CRFine's thread and just make extensions. He has pictures of them in this post. You only need 10cm or so.
You will need clips to fix the O2 wiring to the heat shield. I don't have a part number but check my mod thread for pictures of them.
      11-24-2012, 09:07 PM   #5
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Studs are a plus. Backed one out and fucked it up. Had to run to HF and get a die kit. Not fun
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      11-24-2012, 10:35 PM   #6
usaz4mcr8cr
13
Drives: Z4MC
Sweet! Thanks for the help guys!
I want to order all the parts at once.
You will need clips to fix the O2 wiring to the heat shield. I don't have a part number but check my mod thread for pictures of them.[/QUOTE]
Where can I search for this p/n?
Also, What part #'s do I need to make the extensions?
      11-25-2012, 07:16 AM   #7
Gt4
Gt4's Avatar
Drives: 2006 E46 M3 Estoril blue 6mt
If someone else is looking for a set of Euro headers, there is one for sale right now on m3forum.net for $650shipped
http://www.m3forum.net/m3forum/showthread.php?t=426573
      11-25-2012, 01:35 PM   #8
txz4
txz4's Avatar
59
Drives: 2006 M coupe
http://www.zpost.com/forums/showthread.php?t=644550
All the help you should need right here.
