FORUMS
- 5
| 11-09-2012, 07:51 AM | #1 |
Drives: BLACK Z4 MCOUPE Join Date: Sep 2010
OEM Z4 MC Callipers sprayed diff colour?
Has any body sprayed their OEM Z4 MC callipers a different colour? if can you post pics or maybe direct me to a thread on the forum which has some pics...
i have a black z4 mc, and thinking of doing it...not to sure on what colour to go. |
| 11-09-2012, 08:31 AM | #2 | |
I have some pics, but I'll have to resize the files to post them in this thread now that the file uploader is being a nazi about pixel counts. If you do a thread search for "M5 wheels" you should be able to view the pics I already posted, though. The sliver was a fairly conservative color, but it was in line with the overall color scheme I'm going for. Speaking from past experience, regardless of what color you want, use a G2 or other high quality ceramic paint kit, they last far longer than the store-bought rattle cans and have a very nice, glossy appearance. The rattle cans (even the "gloss" ones) tend to look dull in comparison and start to flake/rust after a year or less.
![]() Python Smart Start /// LED Lighting /// 20% Tint /// Reflector Decals /// Gloss Black Roof /// Aero Sides Tekarbon Spoiler /// Mstache /// Rear Diffuser /// Stubby Antenna /// LeatherZ Armrests 18" M5 Replica Wheels /// 15mm RS Technik Spacers /// Akebono Ceramic Pads /// Michelin PSS Tires |
| 11-15-2012, 12:34 AM | #6 |
(formerly SD 335is)
Drives: '06 Z4 M Rdstr | '11 335is E92 Join Date: Jan 2011
I painted the calipers black on my wife's Le Mans Blue 335is Coupe last year shortly after redelivery. I used the G2 kit and bought it on Amazon. It's a two-part epoxy which has to be mixed together. It's not a spray and must be brushed on. Everything has to be ready to go before you mix because it will start setting up. You only have a couple of hours. and you can't stop once you start. It's very runny and drippy initially but starts to get sticky. I'd do the two front calipers first for the best results.
While the brush in the kit is OK for large areas, I went to Home Depot and bought a set of their artist's brushes that I found in the paint section. They're relatively inexpensive, buy two sets. Make sure that you use latex gloves and have a good supply because as paint gets on the gloves and the brushes you'll be changing them out a few times. It's really a 2-day/weekend job. You'll probably spend a lot more time jacking up the car, removing the wheels, wire brushing and cleaning the calipers, and extensively masking anything you don't want the epoxy on, and then reversing all of that after it's dried than you will painting. I let everything dry overnight before I took the tape off and put the wheels back on. You don't want to mess up your hard work by being impatient at the end. You'll get the best results if you take the calipers off the rotors but this will add considerable time to the project. I can post pics or point you to my Picasa web album if you want to see the results on my wife's car.
Mine: 2006 Z4
Roadster | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Premium | Navigation | Heated Seats | iPod Adapter | Purchased 7/19/12Hers: 2011 335is Coupe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | Premium | Convenience | Heated Seats | Navigation | Harmon Kardon | iPod/USB | European Delivery 5/12/11 ![]() |
| 11-15-2012, 12:36 AM | #7 | |
| 11-15-2012, 12:55 AM | #8 |
Thinking of spraying my calipers black.
I did a Duplicolor rattle can on my E46 and like said earlier, the finish was dull. It held up great, but it was just dull.
![]() 07 Z4M Coupe: 235/265 Hankook RS3, H&R E46 M3 30mm Front Sway Bar, Hawk HP+ Pads, Vorshlag Wheel Stud Conversion 12 128i Coupe: Stock, for now |
| 11-27-2012, 04:31 PM | #9 |
![]() ![]() ![]() ![]() Drives: 2007 Sapphire Black Z4 M Coupe Join Date: Apr 2010
If you want a nice glossy black for your calipers use duplicolor gloss black engine enamel. It holds up well and looks really nice. I have used it on many cars. Will be redoing mine from red to gloss black with that paint.
07 Z4MC
#1019/1815 |
| Bookmarks |
