      09-22-2012, 12:30 PM   #1
Kgolf31
Kgolf31's Avatar
361
Drives: 2007 Z4MC, 2012 128i
M People Post your Hitch Designs!
Hey all,
I'm starting to build my car towards a slightly BSP prepped car (TCK DA coming this upcoming year, with probably LTW flyweel).
Anyways, I'm going to start running R-Comps once I burn off my RS3s, so I need to start looking into a tow-hitch design so I can transport tires.
A friend who had a Z4 gave me this picture, but I don't know if the rear of our cars are the same:
Can anyone post actual designs of their hitch so I have something to work off of?
Thanks!
      09-22-2012, 02:45 PM   #2
psygnosis
psygnosis's Avatar
16
Drives: '04 Z4 3.0i Sport
Less battery bucket, more exhaust
      09-22-2012, 11:33 PM   #3
Kgolf31
Kgolf31's Avatar
361
So we have the same rear frame?
      09-23-2012, 05:58 PM   #4
Gt4
Gt4's Avatar
Drives: E46 M3 ZCP & T4R Limited
I am about to start a Group Buy for hitch for Z4M & M Coupe for people who would like to bring a trailer like HF trailer (wheels/tires, fuel jugs, tools, ...) or just a bike rack.
If I can get 20 peoples at a decent price where I am not working for free..., I can fabricate & paint or powder coat hitches this fall before Christmas. I would also provide a wiring diagram to connect the 4 pins/5 wires to the car for trailer brake and flasher lights.
I will start my own thread if there is interest.
Marc
      09-23-2012, 06:20 PM   #5
Kgolf31
Kgolf31's Avatar
361
Marc
Please start something up. I'm interested.
      09-23-2012, 06:45 PM   #6
Gt4
Gt4's Avatar
A Z4 hitch is different than a Z4M / M Coupe hitch just because the rear bumper isn't the same.
The Z4 is lower than the Z4M/Z4MC. If you want to preserve the oem rear diffuser, you must cut the bumper grill and go through it with the 1 7/8'' ball mount.
VS
      09-23-2012, 07:28 PM   #7
Kgolf31
Kgolf31's Avatar
361
Makes sense. I'm assuming you can completely take the mount off when you're inbetween events so you don't have a huge ball mount hanging off your bumper?
More pictures of what it would look like w/the trailer off and the diffuser cut would be appreciated (if you have time). I'm trying to get the least intrusive thing done.
Basically, when the mount is off, I don't want anyone to know there is a connection hitch hiding behind that diffuser.
      09-23-2012, 07:43 PM   #8
Gt4
Gt4's Avatar
Yes you can remove the ball mount between each event.
The only way someone will notice it is because the grill is cut.
      09-24-2012, 06:13 AM   #9
Shipkiller
Shipkiller's Avatar
Drives: Me
Did you look at this post: http://www.zpost.com/forums/showthre...=trailer+hitch
      09-24-2012, 03:40 PM   #10
JasonH
Aspiring Track Rat
JasonH's Avatar
Drives: 2007 M Coupe, 2003 M3 Vert
Originally Posted by Shipkiller View Post
I'd like to do a hitch too, maybe for next year. I wonder if you do a hitch like the one in the above link, but just totally remove the diffuser grille, would you have room to reach in from the back to insert the pin for the receiver? That way you wouldn't have to cut anything including the diffuser panel under the car. Another alternative is the vertical hitch like from Execuhitch which still requires a hole under the car (but should be almost totally invisible with the receiver removed unless you crawl under the rear bumper.)
      09-24-2012, 05:09 PM   #11
elerner61
elerner61's Avatar
52
Drives: '07 Z4M Roadster
I had a hitch welded up for me by a local body shop/machinist.
http://www.zpost.com/forums/showthre...ighlight=hitch
      09-25-2012, 09:16 AM   #12
schwank
Drives: 06 z4 m coupe
Id be interested
K&W v3, APR splitter, magnaflow axle back35% tint, stubby antenna, Jet black, and interlagos blue stock wheels, clutch delay delete, illuminated ZHP shift knob, Leather Z m shift boot, and arm rest.
      09-25-2012, 02:00 PM   #13
sabbanick
Drives: 08 SBM M coupe
me too
      11-03-2012, 11:07 PM   #14
EMP07
EMP07's Avatar
23
Drives: Z4M
I'm very interested as well. But I would like to see a design that can lower the positioning for the equipment i.e have the wheels and tools box be mounted lower if possible than the pictures in this thread.
something like this or lower
BSM Z4M Coupe
      11-04-2012, 05:30 PM   #15
Gt4
Gt4's Avatar
I will start a Testing Water thread in approximately a month to test the market to see how many people would be interested to buy custom hitch for the Z4MR/Z4MC platform. Right now, I am way too busy to do that.
Ideally, the hitch would go through the grill in the rear bumper. You can put a straight ball mount with no riser to lower the attachment point. But the trailer need to be to the level to avoid to have too much weight on the tongue.
With the Harbor Freight trailer, it's possible to put the leaf springs under the axle to lower the trailer. I have one at home and I will try to modify it and see how low I can drop it
I am also looking to fabricate a custom trailer that will be lower than the harbor freight, 4'x6' so I can bring more wheels, tools, fuel jugs, EZ-UP tent,..., at the track.
      11-04-2012, 07:45 PM   #16
TexasZed4MC
TexasZed4MC's Avatar
Drives: 2006 Interlagos Z4 M Coupe
I am in for this also
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor
