Reply
      07-29-2012, 06:12 AM   #1
zgood4u
Drives: Z4M coupe Metallic Black
Gas pedal sticking
As the title states, it's a bit disconcerting. When pushed to the floor the pedal sticks to the base of the assembly and it feels like it's magnetized. I've not had this happen before. I have to shut the car down and literally pull the pedal off the floor assembly. Anyone know what is going on here?
zgood4u is offline   United_States
      07-29-2012, 08:33 AM   #2
DataStream18
Drives: 2004 ESS TS2 Z4R
You may need to lube up the joints and/or clean the base that will help.
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit.
DataStream18 is offline   Reply With Quote
      08-01-2012, 06:26 PM   #3
JFleming
Drives: '07 328xi, '07 Z4 3.0si
Mine stuck once too.
I had a problem with my gas pedal sticking too.
see my post here.
http://www.zpost.com/forums/showthread.php?t=530195
JFleming is offline   United_States
Reply
Forum Jump
