Login
![]() ![]() SUPPORT ZPOST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
07-28-2012, 12:44 PM | #1 |
![]() ![]() 1
Rep 165
RPI Modification
Ok, even after reviewing that great summary for the after market exhaust modifications I decided to go for that tunnel reverberating, tooth aching, car alarm setting, and hyper droning RPI. No complaints on what I suspected was going to be an authenic track sounding exhaust, even after the initial 500 mile break in and one excesive noise warning citation(story for another thread w/ pictures).
However, I had a couple of thoughts that perhaps many of you have already considered. Could I modify this flow-thru exhaust system to deliver "slightly" lower db's? I had always thought the small, second tail pipe was a filler for the OEM cut-out, but never really looked at it before installation. Since there is no carbon build-up on it, this is either true or its flow must be restricted. There is a mesh patch inside it as it splits off the larger diameter exhaust pipe Has anyone removed this mesh patch to allow the smaller pipe to receive more air, or any air? Thanks!
'06 Z4 ///M Roadster: Silver Gray Metallic; Gray soft top. Zeckhausen CDV. ESS VT1 445 Supercharger. APEX ARC8's. Dunlap Direzza Star Spec's. Strong Struts. Royal Purple. RPI Exhaust w/ DKF hangers.
07-29-2012, 01:41 AM | #4 | |
![]() ![]() 167
Rep 7,336
07-29-2012, 02:35 AM | #5 |
![]() ![]() 57
Rep 1,604
Drives: Imola Red Z4MC
i have no primary cats (AA headers) and RPis and im startin to think i want it a bit louder.... either i dont think its too loud as well or it has begun to deafen me
///M - Some Mods 'N Stuff
07-29-2012, 03:42 AM | #7 |
tosser
![]() 18
Rep 988
what's that i can't hear you
but really, it's not loud unless i want it to be. it's got a bit of a loud cold start. nbd. if i let the revs climb slowly and shift, you'd think it's just a sporty sounding car. when i get on it and let the revs climb it's an angry bat out of hell. i live in a quiet neighborhood and manage to get home at odd hours of the night after partying without being too obnoxious.
'07 MCoupe lots of mods |
07-29-2012, 04:12 AM | #8 |
![]() ![]() ![]() 272
Rep 5,177
the rpi's are LOUD, but when you look at the exhaust, particularly with the euro headers in place, theirs literally no sound surpression anywhere, it looks like the stock setup completely relied on those huge cans to get the noise down, hence their bulk and weight, the rpi is basically a tuned straight pipe!!!
its LOUD!!
07-29-2012, 04:13 AM | #9 |
Rep 5,177
i need to get my DKF hangers on my car to see how much they dull down the noise... villa sed they make a difference!!
07-29-2012, 04:45 AM | #10 |
tosser
![]() 18
Rep 988
wow i wonder what RPI on my setup would be like.
got me verrrry curious...so if a used set happened to pop up at a reasonable cost i might have to pick them up for when i feel like getting a noise ticket.
07-29-2012, 10:13 AM | #11 |
![]() ![]() 1
Rep 165
I was thinking of approaching this on 2 fronts.
I know that what ever I do with this mesh patch over the smaller tube will probably not effect the exhaust flow very much beacuse it is at a 35 degree angle off the main tube but it might change the tone.They put it there for a reason! I was also thinking of welding a perforated funnel inside the flange ring that connects the RPI to the X-pipe. This will produce a little back pressure but not as much as stock. I still need to dynamat to help reduce cabin noise. I have to say that it is a awesome sound to hear the whine of the S.C. and the deep tone of the RPI's, just before the car alarms go off and building seismonitor registers the mag. 2 earthquake.
07-29-2012, 06:38 PM | #12 |
![]() 24
Rep 144
Dynamat , a layer of closed cell foam, and the ///m trunk mat helped but the drone and resonance from 2-3k rpm is still crazy. My shop left me a set of earplugs in the ashtray when I picked the car up as a complimentary "sound mod"
![]() My last m5 was cat-less and resonator-less and it was still quieter than this.... |
07-29-2012, 06:52 PM | #13 |
![]() 24
Rep 144
Oh, I have some leftover Damplifier pro (Dynamat only thicker) I'm happy to donate to any fellow rpi owners in the name of saving eardrums across America.
07-29-2012, 08:57 PM | #14 | |
tosser
![]() 18
Rep 988
![]() wow! there's a guy around town with an e60M5 with meistershaft and some other exhaust goodies. it is LOUDDDDD. you guys have me so curious about the RPI's now. i may have to pick up a used set once i get a real daily driver and reserve the M for the track and small trips here and there.
07-30-2012, 08:12 PM | #16 |
![]() ![]() 167
Rep 7,336
You guys are doing loud wrong. I'm gonna have electric bypass valves in the car soon. right before the mufflers. They arrive tomorrow, but I have some things to do for a week or 2 before I install
07-31-2012, 01:35 AM | #18 | |
tosser
![]() 18
Rep 988
also i'll have to hear this thing in person.
08-05-2012, 07:33 PM | #20 | |
![]() ![]() 167
Rep 7,336
http://marylandspeed.com/dmh-low-pro...ut-p-1313.html won't hear it in person unless you go to my new home in Delray Beach, FL ![]()
08-05-2012, 08:05 PM | #21 | |
![]() 404
Rep 7,552
08-05-2012, 10:08 PM | #22 | |
![]() ![]() 167
Rep 7,336
it comes with a switch you hold for 4-5 seconds for the flaps to fully open. You can stop it anywhere in between, but I'm gonna treat it as an on-off switch. Should sound very interesting, since some air will still hit the stock mufflers
