06-28-2012, 01:42 PM | #23 |
Rep 5,329
to reinforce the area it would need to be proper weldin/on plates, if i see a failure with the stock units in place i'll re-inforce mine.
06-28-2012, 02:59 PM | #24 |
Rep 11,667
^whs
Welding is the only way.
07-06-2012, 06:37 AM | #26 |
Rep 222
If you were to fit a pair of rectangular shaped shims with holes for the bolts between the car chassis and the brackets, when the brackets are fastened on tightly, this would provide reinforcement to the chassis without the need for welding.
07-06-2012, 07:44 AM | #27 | |
Rep 5,329
If your cars on stock bars (which i believe are thick enough imo) this isnt an issue, id rather tune the setup with a proper coilover and spring rate setup.
05-19-2013, 06:09 PM | #28 |
enthusiast
48
Rep 1,695
Well, clunk, clunk, clunk, mine ripped out on the driver side.
3rd case documented. Seems to be a regular case with every performance BMW I have owned. |
05-19-2013, 11:14 PM | #29 |
703
05-19-2013, 11:28 PM | #30 |
enthusiast
48
Rep 1,695
Yes. Drove the Delta again. I guess it's not smooth enough for upgraded bars. I believe we will see failures with stock bars when these chassis hit 100,000 miles. It is amazing that it lasted this long after looking at it.
05-20-2013, 07:29 AM | #32 |
Rep 11,667
I just finished reinforcing mine with the epoxy method.
http://www.zpost.com/forums/showthread.php?t=786695
05-20-2013, 08:38 AM | #33 |
enthusiast
48
Rep 1,695
8000 miles.
05-20-2013, 01:50 PM | #34 | |
703
Looks like a spot that should be reinforced if one is keeping the car awhile even with stock bars as you suggest. Ian, thanks for the link (great template there to from Exdos). |
