FORUMS
- 5
| 06-15-2012, 03:45 PM | #1 |
Z4 M Oil change instructions?
Hi,
Was hoping to find some details with photos on oil change but after searching the best I could find was reference to an e46 oil change. http://www.bimmerfest.com/forums/sho...d.php?t=351298 Prefer something for a M. Any help? Thanks. |
| 06-15-2012, 04:44 PM | #2 |
![]() ![]() ![]() Drives: 2007 Z4 M Coupe Join Date: Sep 2008
They are practically the same! One tip I have to offer is to make sure to fully insert the Hex/Allen wrenh before you turn the drain plug cause it is very easy to strip it
| 06-15-2012, 10:29 PM | #3 |
Put 5 liters in the oil fill and the last 1/2 liter into the oil filter housing before closing it up.
I didn't do that my first time and it made an uncomfortable racket for the first 15 seconds after start up. And in follow up to what Pheonix said, buy a spare Oil Drain Plug for $2.76 (+$5.00 shipping ). |
| 06-16-2012, 01:21 PM | #4 | |
![]() ![]() ![]() ![]() Drives: 2007 Z4 M Coupe Join Date: Aug 2007
Try this procedure:
http://billswebspace.com/Z4MS54OilChange.htm Use oil filter kit P/N 11 42 7 833 769 which happens to be a Mahle OX 187 D with two O-rings and two crush washers. Do not buy the alternate MANN HU926/4X as it will not clear the intake manifold housing. I torque the oil cannister 13mm bolt to 33N*m (24 ft/lbs) and the 6mm Allen oil drain plug to 25N*m (18.5 ft/lbs) Quote:
Jim Millet
2007 E86 Z4 M Coupe/ZPP Premium Package/Nav System/Heated Seats/HD Radio/CDV Delete/Strong-Strut/TCK DA Coil Over Suspension/500# front; 600# rear/TCK Camber-Caster Plates ![]() |
| 06-18-2012, 12:23 AM | #6 |
Thanks for all the replies! The instructions from Bill's site looks perfect.
boydgti - where do you purchase your oil? I assume BMW dealership? I should update my profile - I'm in Edmonton now... |
| 06-18-2012, 12:47 AM | #7 |
In US, I get it from ECS Tuning.
| 07-13-2012, 12:56 AM | #10 |
Common wisdom is to change every 7500 miles, so you'll have to reset it every other time.
I usually use my Peake Research scan tool, but you can also get a knockoff GT1. Peake Research scan tool is handy to have in the trunk for SES lights while on the road. Knockoff GT1 is 1/3 the price, and hours of fun if you're into playing with software and want to run diagnostics and/or program optional features. Last edited by StickMon; 07-13-2012 at 01:09 AM. |
| 07-18-2012, 10:45 AM | #12 |
| 07-18-2012, 10:48 AM | #13 | ||
Aspiring Track Rat
| Bookmarks |
