      06-13-2012, 10:09 PM   #1
gmd2003
gmd2003's Avatar
179
ESVt-1 Z4M at PCA DE Roebling Road 6/9/12
Some of the more open laps of the day in the PCA white group at Roebling. Trying out a new camera angle, works well can even see my speed on my AIM solo. [u2b]
[/u2b]
      06-13-2012, 10:46 PM   #2
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
79
Drives: '01 911 Turbo
Looks like a fun track.
OT, but is that how we're supposed to use the thumb buttons on the steering wheel? For my car, I've always wrapped my thumbs around the corner
I think the only times I use thumb buttons are for go-karts hah.
      06-13-2012, 11:09 PM   #3
gmd2003
gmd2003's Avatar
179
It lets me get a better feel for what the car is doing through the wheel feedback that i lose if i'm putting a death grip on the wheel. Just my way of keeping things loose.
      06-14-2012, 07:14 AM   #4
Mirko
Mirko's Avatar
What settings do you have your KW's set at for track and how did they perform?
      06-14-2012, 08:48 AM   #5
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
GMD - great laps, what lap times were you turning this go around ? I can see a few areas from the video where you can likely pick up significant time, unfortunately most of the data I have from my Z4M is in Traqmate and not the AIM Solo I recently switched to. I believe I'm back up there in August with Flat out and again in October with the PCA Citrus club who I instruct with, would love to ride shotgunf or a few laps.
Typically you don't want to wrap your thumbs around the steering wheel at a track. In the even of contact of a severe loss of control it can break your thumbs when the steering wheel spins rapidly (This is also in essence why if you watch indy car the second they go into a spin they take their hands completely off the wheel).
2004 Porsche GT3 |White
HRE R40 Monoblocks | KW Clubsport Suspension | RSS Lower Control Arms and Suspension Links | GT3RS Wing and Front Bumper | Cup Car Lip | Euro GT3 Seat | GMG Half Cage | Europipe Exhaust | EPL Tuning
      06-14-2012, 08:51 AM   #6
S54dan
I no longer work for United BMW!
S54dan's Avatar
171
Drives: E46 M3, E46 330i ZHP, E36 325i
1994 BMW 325i  [4.25]
2005 M3  [4.83]
2005 325i  [4.00]
2003 330i ZHP  [4.50]
Your car looked good out there. We had fun too. Hope to see you again in the future
BMW CCA, PCA, & CHIN Motorsports Instructor.
      06-14-2012, 09:09 AM   #7
gmd2003
gmd2003's Avatar
179
Thanks I was running 1:27 consistently my best lap was 1:25, yeah I know I'm leaving a ton of time on the table in 1 and 3 and 9 , but I had a bad spin happened in 3 so I'm still overly careful there (100 mph sideways is not fun). I am coasting into 1 too much as well need to stay on the gas longer, but at 140 plus it's been messing up my turn in to 1 when i brake later. Just need more repetitions only been doing this for a year.
      06-14-2012, 09:10 AM   #8
gmd2003
gmd2003's Avatar
179
Thanks! It was nice meeting you as well.
      06-14-2012, 09:45 AM   #9
gmd2003
gmd2003's Avatar
179
They definetly keep the car planted and flat way better than stock, i was seeing peak lateral G in the 1.1 range on street tires although very sticky street tire (Re-11's). I am still utilizing them on 6/10 rebound and compression up front and 5/10 in the rear. I have been dialing in proper camber set up and won't make any changes in suspension settings until I'm maximizing my current setup, i.e within .1 seconds of my fastest lap every time. I think the KW 3 are a fantastic value for what you get.
      06-14-2012, 10:34 AM   #10
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
1 definitely need to lay into it all the way to the markers, then hard brake. In my Z I was actually down shifting to 3rd once I hit the first apex which allowed me to get to power earlier on the exit of the 2nd part of the turn and rotate the car. This may be different with your gearing.
Trick to 3 is to turn in much earlier and hug the inside of the turn there. The pavement is shaped like a /\ from when they paved it, you can load the car up on the inside and get to full throttle for a second going into your brake/downshift. If you spun there it's likely from being a bit too wide and getting the off camber side where there is a ton of marbles. More grip on the inside will also let you get to throttle from 2-3 more, but still will want a lift to settle the car.
Another trick to Roebling for the wallet, make sure you're swapping your tires right to left at the end of each day.
      06-14-2012, 10:51 AM   #11
Mirko
Mirko's Avatar
I am running 9 compression front, 11 rear and middle setting for rebound all around and honestly don't want to change it. Car is fairly flat but does like a little oversteer (which I like) on entry if I give it a little too much mustard.
On warmer days do you find they make the whoosh sound of the shocks compressing?
Have read great things about the RE-11's but I already picked up Michelin super sports which grip nicely. Will try the RE's next time though.
      06-14-2012, 12:43 PM   #12
gmd2003
gmd2003's Avatar
179
Staying on til the markers puts me at 150 GPS speed b/c of the supercharger but with my brakes theres no reason i cant do that. Yeah with the 4.10's and the extra power from the supercharger 4th gear is all i need, I actually run out of gear mid turn coming out of two if i downshift. the only place i can still use third is turn 5 and 6 but its def not necessary tons of torque to rotate the car in 4th with my setup. dynoing 390/300 at the wheels. I agree with 3 as well came in faster than usual b/c i got 2 right and went wide and spun bc of camber and marbles. What speed did you turn into 3? I'm hitting mid 90's coming out of 2 then slowing down to low 80's for turn in.
Ha def right about swapping tires it eats up the left side
      06-14-2012, 02:01 PM   #13
gmd2003
gmd2003's Avatar
179
Haven't noticed the whoosh , but then again between the blower , engine ,headers and exhaust i don't hear much else
The PSS are good in fact I like their feel on turn in, better than the RE-11's but they don't have the absolute grip nor the heat tolerance of the RE-11's thats why I switched.
      06-14-2012, 02:06 PM   #14
gmd2003
gmd2003's Avatar
179
[quote=onelove;12152992]GMD - great laps, what lap times were you turning this go around ? I can see a few areas from the video where you can likely pick up significant time, unfortunately most of the data I have from my Z4M is in Traqmate and not the AIM Solo I recently switched to. I believe I'm back up there in August with Flat out and again in October with the PCA Citrus club who I instruct with, would love to ride shotgunf or a few laps.
I will be there in August with Flat out too. Shame you sold your M I was looking forward to some lead /follow. I've never run with that group before how is it? Was wondering what run group I should sign up for,intermediate? Looking forward to meeting you and any tips would be appreciated.
G
      06-15-2012, 10:15 AM   #15
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
Flat out is a great group, a few of my friends started it after not getting enough track time with other groups. This is there second event at Roebling and the first went without a hitch. I'd sign up in Intermediate. Advanced last time was cars running 1:16-1:21 and dominated by GTRs, GT3s, etc.
Looking at some old data from a 1:22 Lap I had on my work computer, I'm entering 9 at 95mph and end up at 138 braking into 1. By the mid-point between 1 and 2 I'm at 68mph. Turn 3 I was able to carry 94mph through the turn.
I love tracking the Z4M but was at a slippery slope. No one that I ran with at the time used them so I was in a world of my own trying to get data, etc. Many of my friends run GT3 and GT3RS so it was either spend 10-15k on a supercharger,cage, seats and harnesses, or sell the car and get a GT3. Safety was also a huge concern since we run tracks like Sebring and Daytona as well, and the GT3 offered a bolt-in cage vs having to cut half the car appart like the Z4M. I still miss the car quite a bit!
      06-15-2012, 02:16 PM   #16
gmd2003
gmd2003's Avatar
179
Cool I figured I should be able to do 90 with the RE-11's I have been doing 85 going into 9. My minimum in 2 is consistently 64 so thats not bad , but as I figured you are killing me in 3 by 8mph. What front/rear alignment settings (camber/toe) did you settle on? I'm at -2.5 .03 toe in front and -2 rear . Figure i'll end up finding that -3.5 is needed up front going by my tire temps last time
Thanks!
GJ
      06-15-2012, 02:59 PM   #17
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
From memory I had -4.0 in the front with 0 toe (which I also used on the street and got decent tire wear), rear I believe was -2 camber, can't find my notes to know 100%.
