      06-08-2012, 01:17 PM   #1
nwflbimmer
Drives: 2007 MCoupe (Interlagos Blue)
Alarm Install in 07 M coupe.
I have searched the forum looking for instructions concerning this. The most recent comments are about a year ago and I am not sure the people are still on the forum. So I am going to just ask out right and confirm what I have interpid.
The hood sensor seem to be pretty cut and dry. It mounts between the two cross members on the fire wall under the hood. the wire looks to be behind the brake reservoir.
The siren/tilt snsor is mounted behind the passenger rear wheel. Asd I understand you remove three (3) plastic screews and pull back the plastic wheel liner. I looks like it is mounted next to the carbon canister. and the wires are just loosely hung there.
Once everything is installed you go to the dealer to have the alarm coded, before it works.
Thank You
Paul
      06-08-2012, 01:36 PM   #2
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Thank You
Paul
All correct, with the exception of the location for the alarm unit. Goes more or less between the two mufflers. Here are the instructions I used.
      06-08-2012, 02:12 PM   #3
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
The alarm is mounted on the passenger side. You do not need to remove fender liner. The bracket is visible looking between muffler and rear qtr panel from under the car. I had my installed without removing fender liner.
      06-08-2012, 02:30 PM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
see Finnegan's post for the correct location
      06-08-2012, 03:00 PM   #5
Beedub
i have this and its crap anyway..... you'd be better off getting a quality aftermarket unit imo!!
      06-09-2012, 02:47 AM   #6
nwflbimmer
Yeah I was kinda thinking about getting a viper alarm. But I want my clown nose to work rather than an led some where else blinking
      06-09-2012, 07:23 AM   #7
Beedub
Just place the power lead to power the clown nose.
      06-09-2012, 11:16 AM   #8
KevinC
your average JAMF
KevinC's Avatar
My clown nose blinks and I don't have the factory alarm. I don't know if it came from the factory this way, or if the stealership programmed it to blink at some point - I never asked them to - but it probably scares 98% of the amateurs who might consider a smash & grab away. The other 2% will get into your car if they really want to, alarm or not, so I'm quite happy with this solution.
I just bought a used E46 ZHP Coupe and it has the OEM alarm, so all my noses glow.
'21 M2 Comp
'19 Golf R
      07-12-2012, 12:11 PM   #9
nwflbimmer
Well I installed the tilt/siren module under the car and the hood sensor. I notice the other day that the clown nose was blinking when the car is locked. I know before I installed the sensors the led light didn't work. I wonder if the alarm is working now? without me having it turned on at the stealer.
      07-12-2012, 12:24 PM   #10
3002 tii
3002 tii's Avatar
2282
Why not just test yourself? Lock the doors via key fob. Then try opening the trunk manually with the key inserted.
Follow for latest mods
      07-12-2012, 12:26 PM   #11
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^whs
mine worked without any programming.
      07-12-2012, 04:31 PM   #12
nwflbimmer
Damn I feel like - Blonde Star (look on facebook)
      07-12-2012, 09:56 PM   #13
nwflbimmer
not working!
      07-12-2012, 11:33 PM   #14
RobMCoupe
RobMCoupe's Avatar
60
not working!
I have to activate my alarm even though my clown nose blinks prior to install. My Indy shop couldn't get it working properly. The remote do not unlock all doors and do not chirp on lock. It only chirp unlock. I have the dealer do the activation.
      07-13-2012, 05:40 AM   #15
nwflbimmer
how much did it cost to have the dealer activate the Alarm?
      07-13-2012, 05:57 AM   #16
3002 tii
3002 tii's Avatar
2282
Stupid expensive, my indy shop did it for $40
      07-13-2012, 05:52 PM   #17
RobMCoupe
RobMCoupe's Avatar
60
It was free for me because I told them they didn't program my keys properly. Car was still under warranty. The going price is around $100.
      07-13-2012, 05:54 PM   #18
RobMCoupe
RobMCoupe's Avatar
60
My Indy use AutoLogic but could not get right. I decided not to mess with it and have the dealer do it.
      07-13-2012, 07:57 PM   #19
3002 tii
3002 tii's Avatar
2282
Is that same as the gt1? I think that's what's needed.
      07-13-2012, 08:11 PM   #20
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Stupidly expensive is an understatement. I think I paid about $150 at the dealer to get mine coded, if I recalled correctly. Chances are that it won't go as expected the first time either. Search the alarm thread and you will see all the troubles related to getting it working correctly.
      11-21-2012, 02:09 PM   #21
jcnpa
Drives: 06 red Z4MR
alarm siren
I have looked but do not see where it states to put the siren in the Z4MR. Is it the same as an I or SI in the bumper or does it go under the car similar to the Z4MC?
Thanks in advance.
      11-21-2012, 02:16 PM   #22
Swashplate
Swashplate's Avatar
Drives: in Anger.
The best theft prevention is already a standard option in our cars. A manual Transmission. Considering more people have passports in the US than can drive stick you are looking at less than 15%
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs
1217/1815
!!! BOILER UP !!!
