      03-04-2013, 04:41 AM   #375
johanness
Drives: 2008 Z4MC
Originally Posted by Sal@Evolve
Originally Posted by johanness View Post
3 Evolve tunes. 3 running too rich. Looks like Evolve didn't get it right. Can't compare tuning an E46 to these cars in any way
If there is a problem with these tunes then we will fix this.
I am looking at these cases and going to study the DRF files.
There is a massive inconsistency between the tuning we have been doing for a long time on these DME's in the USA and now.
It doesn't matter what it takes, will find the issue.
There are far more maps in the MSS70 than the MSS54 with respect to ignition timing vs temperature and vans timing vs temperature.
If the temperature remains too cool a different vanos profile is taken.
What's interesting is that the fuelling is changing so much pre and post tune where the fuelling has not been changed that much!
Rest assured, already working on this. We will find the issue with these cases first and if a small issue is found then everyone will be updated.
Still waiting for an update on this (3 months?)
      03-04-2013, 06:57 AM   #376
inTgr8r
inTgr8r's Avatar
Drives: E86 Z4MC; E92 M3
Which probably means they didn't figure it out.
      03-05-2013, 09:52 PM   #377
davesz4mc
Drives: 2007 z4mc
They need to get on it then...
2007 Z4MC, 1" drop H&R Springs, Evolve Tunning, Headers, K&N Filter, RPI scoop, Red top high energy coils, UUC Red Poly mounts (none bolt-through), UUC Lightweight Flywheel with Organic Clutch and a custom exhaust with just one AeroTurbine muffler.
      03-05-2013, 10:11 PM   #378
Jumbosock
Jumbosock's Avatar
37
Drives: 2007 M coupe
Originally Posted by sixspeed View Post
Interestingly I spoke to Evolve today about some map work, and have offered them to have my Z4M for as long as needed to play about with a tune. If that means they can get the development of this box out of that, then that's fine by me. I just need the car back before the end of March, but that's 4-5 weeks of development time for fitting etc.
Speaking with Sal tomorrow, so will mention this then.
From the intake thread it looks like they are at least gonna have a Z4M on site to play with.
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights
      03-11-2013, 09:49 PM   #379
bmwschnell
bmwschnell's Avatar
Drives: '07 Z4M coupe; '16 Volvo XC-90
Any update on this?
      03-15-2013, 01:37 AM   #380
beta
Drives: 2006 M Roadster
I finally got my car dynoed. I expected to be making more power, so I'm disappointed.
Next step for me is to re-flash stock firmware (except euro version of the software instead of US), send that file over to Evolve. Then go dyno the stock firmware, flash and dyno again to verify a gain.
The only reason I can think of for the lower than expected output is that I'm due for a valve adjustment. Could this cause the power I'm seeing? I'll make sure to get that done before the next dyno as well.
This dyno gives results about 10% lower than the most common dynos, so multiply by 1.1 to get a more standard number and 1.25 to get a rough crank number. I got 250. I was expecting at least 10-15hp more.
What do you guys think?
      03-15-2013, 04:46 AM   #381
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
79
Drives: '01 911 Turbo
I'm honestly not sure why that dyno read so low. I understand that dyno-to-dyno differences in peak output #s are not exactly apples-to-apples comparisons, but there should be at least a ballpark range for stock or otherwise-modified.
I honestly think your car should be putting out like 280rwhp and 240rwtq at least. Perhaps the AWD dyno had something to do with it? I'm not particularly sure. I do know that Gernard used the same dyno as I did, under same operator and gear runs, so I'd take a look at those for comparison?
      03-15-2013, 09:56 AM   #382
tikamak
Lebanon
24
mmm, beta? have you let your car adapt for 200 miles before going to the dyno?
You also need the uncorrected data.
This is making me wonder if i should go dyno my car before installing the ESS supercharger because when the supercharger is installed i won't be of any help to you NA guys.
      03-15-2013, 01:38 PM   #383
beta
That's what I did last night, I looked at gernard's dyno and he's reading about 10hp higher at any point in the curve. He does have a gruppe M intake and his custom exhaust, but no headers! So I should have at least his numbers.
I'm going to see if I can get any other dynos of S54 owners on that same dyno.
      03-15-2013, 01:57 PM   #384
tikamak
Lebanon
24
Anyone still having O2 and EGT codes? I am still having EGT and O2 codes after removing my cats completely and salman@evolve is still looking into the problem.
The car feels strong like before but this is making me wonder if this feeling is the throttle remapping, i don't know if i have time to get a dyno with the tune and dyno without the tune before installing the ESS supercharger VT2-500.
How many cars have reported power gains so far and how many reported O2 and EGT issues with decatted systems or EURO headers?
      03-15-2013, 02:10 PM   #385
marinb
marinb's Avatar
Drives: 2017 911 GTS
Do you have a CEL because it's throwing codes? Or are you talking about the readiness monitors not ready for O2 and EGT?
I don't have any codes, Sal fixed that. But my car is showing O2 and EGT not ready, I was told to do a drive cycle (but I haven't gotten around to it yet ... because it's a pain in the ass).
      03-15-2013, 02:19 PM   #386
tikamak
Lebanon
24
I still am having a CEL and when clearing it, it will come back after the first drive cycle.
I have told salman several times about it and he told me that he's looking for the reason why the CEL is still showing rather than just turning it off (quote).
This is my state since 3 months, I still have some patience in me because when i install the supercharger soon, it will have the ESS supercharger tune.
      03-15-2013, 02:28 PM   #387
TNZ4MC
Drives: 2006 Z4M coupe
I am having issues with my readiness monitors not resetting. I do not have a cel and no codes show up when checked. I have had a couple of times when my battery died which reset the monitors but I have since driven the car 300 miles after getting a new battery. My setup is evolve tune with euro headers and euro S-pipe with all sensors hooked up accordingly. Any thoughts?
      03-15-2013, 03:05 PM   #388
marinb
marinb's Avatar
It can take a while with normal driving for readiness to reset. If you want to speed up that process then Evolve will tell you to do a drive cycle, here is the link they sent me:
http://www.m5board.com/vbulletin/att...-procedure.pdf
I haven't done it yet so I can't confirm if it works or not.
      03-15-2013, 04:50 PM   #389
beta
I get occasional EGT plausibility, but AFAIK that's normal because the DME is expecting the EGT to be in the US location. This is one of the reasons I want to flash euro DME software on there.
Haven't had any issues with O2s and I just got smogged. Just not overwhelmed with the power I'm making. But I still don't know how much of that is due to tune or valve adjustment pending.
I guess I'll find out when I re-dyno.
      03-15-2013, 05:23 PM   #390
marinb
marinb's Avatar
We should do a dyno day together to compare tunes, plus get someone with a stock Z4M to baseline the dyno.
      03-15-2013, 05:47 PM   #391
beta
I'm down for that. If we can get 3-5 from the bay area we can get good rates and really comparable numbers.
      03-15-2013, 08:47 PM   #392
mfanatic325
///M-fanatic
Taiwan
79
That's why I ran those dyno days while back lol, but not all the tunes were out back then unfortunately. You guys should've gotten baseline during that time though!
      03-15-2013, 11:02 PM   #393
kennyfrc
kennyfrc's Avatar
Drives: 2008 Z4MC
Question: How much more evidence is needed to prove what seems, at least to me, obvious?
Daily: 2010 Tacoma Double Cab
      03-16-2013, 01:25 AM   #394
gferil
gferil's Avatar
17
Drives: 06 Z4MC
I should knock on wood, but I seem to be one of the people that got lucky...went to the same place to get dynoed each time, but I have a thread that shows stock dyno, dyno with intake and exhaust, and then dyno with Evolve tune, intake, and exhaust...and the dyno with the tune was by far the best, and the tune really did it's job to smooth out the power and give some decent gains overall...
Like I said though, I should keep my mouth shut...cause I feel like I'm one of the few with a tune that is running OEM headers, so I wonder if that has anything to do with it. I plan on getting my EU headers installed in a few months though, so I'll do another dyno run at the same place again to see what happens.
Maybe during that next dyno run we can get the locals with the tune to all do them at the same time. I know RobMcoupe is running EU headers with a tune and he told me that his car pulls like crazy since he had the tune installed, so I'd be interested to see what numbers he is putting down.
      03-16-2013, 01:33 AM   #395
RobMCoupe
RobMCoupe's Avatar
20
Drives: 2007 Z4 M Coupe
I'll see if I have time in a few weeks to dyno my car. A group dyno sounds good.
      03-16-2013, 02:45 AM   #396
johanness
Drives: 2008 Z4MC
I thought you were Evolve all the way?
Wait till you try an evolve tune with euro headers, salman @ evolve is a genius.
After a few chats, i do not trust any other tuner, i will have him tune my ESS vt2-500.
The problems you are all having are NOT indicative of a Euro header install. When done correctly there should be no CEL, no 'readiness' fault, and no other issues (except a huge grin across your face).
ESS pioneered this tech for our cars (specifically), and their tune is flawless.
