Reply
      05-18-2012, 07:47 PM   #1
IWantAnE92
Drives: 2001 330Ci | 2007 Z4MC
what is the widest spacer I can use on these Apex?
I just can't figure out offsets and all that for some reason!
I currently have these on my M but feel like I want a wider/more aggresive stance. What's the biggest spacer I should be able to get for these without any rubbing?
Apex Arc8
18x9.0" Offset: 42mmk
18x9.5" Offset: 35mm
I currently have v12s on them but may change over to Conti DWS.
Stock height.
Thanks in advance!
IWantAnE92 is offline
      05-19-2012, 12:54 AM   #2
BIMMERGUY91
Drives: 2007 Sapphire Black Z4 M Coupe
You can probably use a 10mm on the rear and maybe a 5mm on the front. MAYBE 15mm rear and 10mm front but that would be pushing it
07 Z4MC #1019/1815
BIMMERGUY91 is offline   Reply With Quote
      05-20-2012, 11:56 AM   #3
aaaafamily
aaaafamily's Avatar
Drives: E86 M
10-12mm on front with 245, more than 12mm, you will need negative camber
10-15mm on Rear with 275
i am running
Front: 18x8.5 +32 with 10mm spacer with -2.5 negative camber
Rear: 18x10 +20mm with -2.5 negative camber
aaaafamily is offline   United_States
      05-20-2012, 01:57 PM   #4
BIMMERGUY91
i am running
What size tires are you running on that setup? Any pics?
07 Z4MC #1019/1815
Reply
Forum Jump
