Reply
      05-05-2012, 09:55 PM   #1
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
What Spring Rates Are You Running?
Just curious to know what spring rates some of you are using. Can you specify
1) Chassis and motor (roadster vs coupe, m54/n52/s54)
2) Which coilover brand?
3) What size springs and rates front/rear?
4) Is your car track only or street & track?
5) What kind of events and how many events per year? (ie, auto-x, DE, TT, club racing)
6) Are you using aftermarket swaybars?
Trying to get a better understanding of what rates people are using and what they find to be most effective (given the type of driving they do).
Recaro | AST | Vorshlag | Quaife | Stoptech | Volks | Autosolutions | BMW Performance
Click here for my track videos
DSC_OFF is offline   United_States
      05-05-2012, 09:56 PM   #2
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
I'll start...
1) coupe, n52
2) AST 4100
3) front: 6" 450#, rear: 5.5" 550#
4) street & track
5) DE events, 10 days per year
6) stock oem swaybars
I started with the lowest rates given that NJ roads can be pretty brutal but may work my way up in 100# increments...
      05-06-2012, 08:07 PM   #3
seank
enthusiast
seank's Avatar
What a great thread. I hope others will add their info.
seank is offline   Reply With Quote
      05-07-2012, 12:53 AM   #4
mfanatic325
///M-fanatic
mfanatic325's Avatar
Drives: '07 Z4MC, '04 325Ci
Send a message via AIM to mfanatic325
1) coupe, S54
2) TCL D/A
3) front: 500#, rear: 500#
4) street & track
5) DE events, <= 8 days per year
I had an option of 450# or 500# front spring rates when I bought the TCKs, and I opted for the stiffer ones.
So far as good, even though rears are supposed to be stiffer
I have no idea about spring height, but if I had to guess, maybe 6" fronts, and 5" rears?
VF570 S/C|TIAL BOV|SetRabCooler|Brembo GT 6/4|TE37s|NT05s|3.91 Gearing|TCK D/A|RPi Induction|SS Race Mufflers/X-pipe|JVT Headers|AS SSK|Sparco Pro2000/6pt.Harness|MS FloorMounts|SE Custom Harness Bar|Tekarbon Angels|M-Tech Pedals|OE Strut Bar|RE RSMs|8000K D2S|CDV DEL|CF Roof Wrap|MB Grills|UUC TrannyMounts/ClutchStop|V1 Mount|P3C Gauge
mfanatic325 is offline   Taiwan
      05-07-2012, 03:42 AM   #5
dorifto88
Drives: 88 Nissan Pathfinder
e86 s54
ground control coilovers
12k rear, 10k front (6" front, 5" rear)
street and track
auto-x, and maybe track days if money comes up
stock swaybars
dorifto88 is offline   Reply With Quote
      05-07-2012, 05:30 PM   #6
mfanatic325
///M-fanatic
^ So that's like 560# fronts; 672# rears Mike. Since 1 kg/mm = 56 lbs./in
      05-07-2012, 06:49 PM   #7
dorifto88
yup =)
      05-07-2012, 07:12 PM   #8
seank
enthusiast
seank's Avatar
Interesting that everyone so far has stock sway bars. I assume they have adjustable linkages. And why did everyone decide to not increase sway bar diameter or get one that is adjustable?
      05-07-2012, 11:18 PM   #9
mfanatic325
///M-fanatic
Perhaps I'm not at a level yet where I could put uprated sways to full use, but I feel like the car doesn't need it the way it is right now
In fact, if I were to do it all over again, I would spend another year tracking on bone stock suspension first before putting an uprated system in. I only tracked the car three times in stock form prior to putting my TCK D/As in.
Maybe it's also because my training wheels was my MR2 turbo, which has quite different vehicle dynamics; and when I hopped in the Z4M, even in bone stock form, I found it ridiculously easy to control in comparison
I just feel like honestly the car is already damned good, especially for a good 80-90% of trackers out there (as most people aren't even good enough to need any uprating; myself included of course)
      05-08-2012, 01:22 PM   #10
jmillet
jmillet's Avatar
Drives: 2007 Z4 M Coupe
2007 E86 Z4MC S54
TCK DA coil overs with 500#F and 600#R. TCK camber/caster plates.
Primarily track but does see some limited street use.
Instruct at BMW CCA and PCA driving school events; about 12 track events a year.
Running stock sway bars.
For track use run Toyo R-888 tires and PF-06 brake pads.
3) what size springs and rates front/rear?
Jim Millet
2007 E86 Z4 M Coupe/ZPP Premium Package/Nav System/Heated Seats/HD Radio/CDV Delete/Strong-Strut/TCK DA Coil Over Suspension/500# front; 600# rear/TCK Camber-Caster Plates
jmillet is offline   United_States
      05-08-2012, 02:42 PM   #11
The HACK
Noob
The HACK's Avatar
Drives: 2006 MZ4C, 2013 Veloster Turbo
2006 MZ4 Coupe
Ground Control School/Track kit, single adjustable Koni with GC camber plate.
440#" front, 550#" rear
Driven on street once a week, otherwise all track
HPDE, 8-10 days a year (used to be around 20days but a 4 year old child has pretty much ruled THAT out)
OE Swaybars
No way I'd ever take my BMW to the track.
Then why do you have $3,000 worth of suspension mods on your car?
-Overheard at the last B****rfest.
The HACK is online now   Reply With Quote
      05-08-2012, 03:34 PM   #12
AUTOX08MC
AUTOX08MC's Avatar
Drives: 08 Z4m Coupe
1) Chassis and motor (roadster vs coupe, m54/n52/s54): 08 M Coupe
2) Which coilover brand? Ground Control w/Ground Control Camber Plates
3) what size springs and rates front/rear? 440 F 650R
4) Is your car track only or street & track? Some Street/Many Autocross
5) What kind of events and how many events per year? (ie,20-25 auto-x)
6) Are you using aftermarket swaybars? Ground Control Med Front (set to full stiff) Soft Rear set to full soft
7) Hoosier A6 285/30/18 all around on 18 x 9.5" 35mmoffset front with 3mm spacers, 18 x 10" rear 25 mm offset rear ride height 1/4" higher than stock for autocross
08 Z4 MC, Arctic White, GC Suspension 650/800, GC Swaybars (med/soft), Remus Cans, SS Lines, BMW Strut Brace, TC Cline RTAB, RPI Scoop, Stock Wheels w/ Dunlop Star Specs 245/275, Autocross Wheels: Apex 18x9.5 18x10 all w/285/30 A6 Hoosiers, Fabspeed Headers, Evolve Tune, Aluminum Adjustable Rear Camber Arms
AUTOX08MC is offline   Reply With Quote
      05-08-2012, 04:35 PM   #13
seank
enthusiast
seank's Avatar
jmillet
Nice pic, but do you have any figures for us?
      05-08-2012, 05:08 PM   #14
F360C
Drives: M Shoe
1) E86 S54
2) Ground Control
3) 600lbs 6" front and 750lbs 5" rear
4) Track/autox/fun street driving it does it all
5) 10 tracks days last year and many autox's
6) Ground control front and rear bars but I took the rear bar out and I am currently running no rear bar. Traction was improved with the elimination of the rear bar.
I think in the near future I will be going with 700lbs front and 850lbs rear.
07 Z4 M Coupe AW/IR
F360C is offline   United_States
      05-08-2012, 06:10 PM   #15
dorifto88
Originally Posted by F360C View Post
1) E86 S54
2) Ground Control
do you have the 'stock' rear height adjusters with that 5" spring? ive always been really scared because the 5' spring can come off completely when the wheels are in the air and the parking brake released.
      05-08-2012, 06:24 PM   #16
F360C
Drives: M Shoe
Yep running the regular GC rear adjuster. Never had a problem with the spring coming off yet.
07 Z4 M Coupe AW/IR
      05-10-2012, 07:16 AM   #17
z3papa
Drives: 2007 BMW 335i
1) Chassis and motor (roadster vs coupe, m54/n52/s54) -- M5430
2) Which coilover brand? AST 4200
3) what size springs and rates front/rear? 6"x570#F/5.5"x683#R
4) Is your car track only or street & track? Mixed street and autox with occasional track
5) What kind of events and how many events per year? (ie, auto-x, DE, TT, club racing) +25 autox
6) Are you using aftermarket swaybars? H&R fronts/OE rear
fast modifications include front and rear SS braces, AST 4200's DA coil overs with front #575/#750 rear, Vorshlag camber plates, GC RSM, H&R sway bar, conforti Shark injector, Conforti CAI, Performance Gearing custom diff, UUC power pulleys, Magnaflow exhaust, Recaro seats, and ARC8's with RS3 and Style 32's with Pilot Super Sports for autocross
z3papa is offline   Reply With Quote
      05-10-2012, 10:53 AM   #18
runnerx
runnerx's Avatar
Drives: 06 M roadster; 06 330i 6spd
1) E85 S54
2) Ground Control Track School kit with race camber plates
3) 500lb/in front / 600lb/in rear
4) primarily track, but probably street driven once or twice a week
5) ~10 track days per year
6) OE sway bar
2006 BMW ///M Roadster 6spd manual
2006 BMW 330i 6spd manual
https://lh5.googleusercontent.com/--bIgrh8ES_s/TxSUCvOmDUI/AAAAAAAAPh0/OOjwrRZtta0/s912/z4mcomparo.jpg
runnerx is offline   United_States
      06-19-2012, 11:22 PM   #19
Z///Ms
Z///Ms's Avatar
Drives: Z3M Rstr, Z3M Coupe, Z4M Coupe
2006 E86 Z4MC s54)
Bilstein PSS10
Track Car
Instruct at BMW CCA driving school events; about 15 track events a year
GroundControl swaybars front and rear.
Tuner camber plates, solid rear bushings, BFGoodridge R-1 tires with PF-01 brake pads.
Z///Ms is offline   United_States
      09-02-2012, 02:20 PM   #20
pal
pal's Avatar
Drives: Z4 M Coupe
Very interesting thread. Here is my information and I have a question as to why you all are running a higher spring rate out back?
(1) 2007 Z4MC, S54
(2) KW Clubsports
(3) Stock KWC springs- 400lbs front and progressive rear
(4) Street (weekends and occasional wkdy) & track
(5) DEs - 10-16 days a year (8-12 events)
(6) Stock sways
(7) PS2 tires (31psi front/30psi rear- cold)
(8) No camber plates; using Turner washer kit to get around -2.3° front; -1.8° rear.
(9) Happy with the setup so far- comfy enough on the street and great on track. Want to reduce roll some more and increase mechanical grip so plan to go for 450lb front and ?? rear this winter for next year.
pal is offline   Reply With Quote
      09-02-2012, 03:33 PM   #21
Spreadsheet
Drives: Black 2007 Z4MC
1) Chassis and motor (roadster vs coupe, m54/n52/s54) - Z4MC
2) Which coilover brand? - AST4100
3) What size springs and rates front/rear? - 550lb Front/650lb Rear
4) Is your car track only or street & track? - Street, about 8-10K a year
5) What kind of events and how many events per year? (ie, auto-x, DE, TT, club racing) - 1 to 2 auto-x a year
6) Are you using aftermarket swaybars? - No, but considering Ground Control swaybars
What you didn't ask:
7) What camber/caster units are you using - Vorslag
8) Are you happy with the system you are using? - Yes. Once past 'walking speeds', suspension is really more comfortable than stock. More noise comes in due to less rubber isolation, but true seat in the pants feel is better road isolation.
Spreadsheet is offline   United_States
      09-13-2012, 08:38 PM   #22
TSM330i
2006 330i, TSM, Black, manual, sport
TSM330i's Avatar
Drives: E90 330i, E86 Z4 3.0si
Anyone know what the spring rates should be for a full-blown race car? No street driving at all.
More than likely, going to run AST4200 or 5200.
This would be for a non-M.
Thanks
2006 330i, TSM, Black, Sport, JIC Cross Coil-Overs, UUC Sways, 18" Advan RS, Mich PSS 255/265, Custom Alcantara M-tech steering wheel, VAC pedals, Rogue shifter, M-Tech front, CF emblems, Dinan TB, Intake, exhaust, strut bar, Stoptech BBK, LSD, M3 susp., LUX 5, CF Hood and CSL, Sparco Seats, AA tune, CF Roof
TSM330i is offline   United_States
Reply
Forum Jump
