      05-16-2012, 10:10 PM   #45
trialskid
Drives: 08 335i
Originally Posted by paintpro21 View Post
18x8.5" ET35 Front with 235/40/18
18x9.5" ET22 Rear with 265/35/18 or 275/35/18
i have a brand new set of tires in the stock size i would like to use so would i need skinnier rims?
      05-17-2012, 03:20 AM   #46
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
149
Drives: '01 911 Turbo
No, you can re-use your stock tires. They just might be slightly stretched it all. Once you wear out those stock tires, then you can upgrade to wider tires
      05-17-2012, 10:33 PM   #47
trialskid
Drives: 08 335i
have they released pricing yet?
      05-18-2012, 12:45 AM   #48
007MCoupe
007MCoupe's Avatar
Germany
56
Drives: '18 Sakhir M3 ZCP
I'm sold.
      05-22-2012, 09:06 AM   #49
Rawyzf
Pontiac G8GT
Rawyzf's Avatar
Drives: 09 Pontiac G8 GT
Now that pricing is out, the official question is, when is a group buy going to be lined up?
      05-22-2012, 07:16 PM   #50
BIMMERGUY91
Drives: 2014 335I M Sport
What he said. I am in for a group buy
2014 335i M Sport
2010 328i M Sport
2007 Z4MC #1019/1815 (Sold)
1997 M3 (Sold)
1991 325i
      05-22-2012, 09:19 PM   #51
trialskid
Drives: 08 335i
where did you see the pricing
      05-23-2012, 11:03 AM   #52
BIMMERGUY91
Its on their website
2014 335i M Sport
2010 328i M Sport
1997 M3 (Sold)
1991 325i
      05-23-2012, 11:09 AM   #53
Rawyzf
Pontiac G8GT
Rawyzf's Avatar
Yup, here you go: http://www.myapexparts.com/2012/04/2...wheel-release/
      05-23-2012, 11:09 PM   #54
Eddy@ApexRaceParts
216
Drives: E30 M3, F10 M5
This thread is a technical only discussion, and we can only answer fitment questions in this section of the forum.
      05-24-2012, 12:42 AM   #55
ZeD4Mr
ZeD4Mr's Avatar
Drives: MR
Would 18x9 ET31/18x9.5 ET22 a direct fit on a stock setup Z4M?
Will Gun Metal or Hyper Black color be offered in the near future?
thanks,
      05-25-2012, 12:14 PM   #56
BIMMERGUY91
Paintpro, create a group buy in the sponsors classifieds!!!!!
2014 335i M Sport
2010 328i M Sport
1997 M3 (Sold)
1991 325i
      06-11-2012, 12:24 PM   #57
BIMMERGUY91
Bump for updates
2014 335i M Sport
2010 328i M Sport
1997 M3 (Sold)
1991 325i
      07-23-2012, 08:04 PM   #58
Eddy@ApexRaceParts
216
thanks,
18x9" ET31 is too aggressive for a stock Z4M. Camber plates would be a must to keep the wheel under the fender. 18x9.5" ET22 is a direct fitment for the rear.
Gun Metal is very similar to Anthracite. Hyper Black will not be offered.
Bump for updates
updates would be found in the classified section. This thread must be kept to technical/fitment questions only.
      07-29-2012, 03:07 PM   #59
GomboRombo
Roadie B4 Roady
GomboRombo's Avatar
Drives: Z4 M Roadster
What would the best fitment for stock suspension + tires be?
How about the best fitment for an 07 non-M staggered with Eibach's?
Remus, ZHP, Stubby, H&R Coilovers
      07-30-2012, 02:45 PM   #60
ApexRaceParts
Drives: M3
For your car we would recommend an 18x8.5" ET35 with a 245/35/18 front tire and either an 18x9" ET42 or an 18x9.5" ET43 with a 255/35/18 rear tire.
      07-30-2012, 07:17 PM   #61
Bammered
Track Addict
Bammered's Avatar
Drives: E86 Z4 ///M COUPE
Send a message via MSN to Bammered
Can't wait to get these on my ///M !!
I'm now going apex for street and track. The arc 8's for the track and these for the street.
Question is do I try and run 265's all round? I ordered 9.5et35 front and 10et25 rear. I have ground control coil-overs and I can currently just clear (slight rubbing) 255 30 front on the CH's.
My BBS CH' will be for sale: 19" 8.5 et35 and 10 et20 rear.
      07-30-2012, 07:47 PM   #62
Rated M Roadster
Rated M Roadster's Avatar
37
Drives: F10 M5
You can fit 265s up front with a spacer and camber; rear will be fine with 265s.
CURRENT ll F10 M5
SOLD ll E70 X5M
SOLD ll Z4MR VF570
      07-30-2012, 08:12 PM   #63
Bammered
Track Addict
Bammered's Avatar
Yeah the rear I'm not concerned with as I'm fine with the 275 19's....up front I run -3 degrees so that should help.
I was just thinking about what I could be giving up by trying to stuff the 265 up front. I guess more tramline? I am just enticed by the idea of being able to swap tires( not rims) front to back.
      08-02-2012, 08:03 PM   #64
ApexRaceParts
Drives: M3
If you would like to run a square combination the care will behave a lot more neutrally in that it will understeer much less. The -3 degrees of camber that you currently run definitely helps the performance of the car and aids in fitting the 265/35/18 tire and 18x9.5" ET35 wheel up front. You could run a 12-15mm spacer in the rear with an 18x9.5" ET35 to have approximately the same fitment against the fender as an 18x9.5" ET22. It is possible that you may experience more tram lining but the performance benefit will far outweigh any small stretch of road with inconsistencies that would cause tram lining.
      08-24-2012, 04:21 PM   #65
gferil
gferil's Avatar
23
Drives: 06 Z4MC
Quick picture of the wheels getting installed. So far, couldn't be happier, the wheels are gorgeous, and two of the four didn't need wheel weights, which speaks volumes for the quality of the wheel and Michelin PSS's.
      08-24-2012, 05:31 PM   #66
ZeD4Mr
ZeD4Mr's Avatar
Drives: MR
More pictures and spec PLEASE... Looks great and that's the color I want.
Tags
18x10, 18x9, 18x9.5, apex, ec-7
