      05-13-2012, 01:36 PM   #23
mpm3
mpm3's Avatar
Drives: 2007 M coupe
2007 BMW M coupe  [5.00]
2011 BMW M3  [0.00]
any release date info ?
      05-13-2012, 01:46 PM   #24
antennahead
antennahead's Avatar
Drives: 2007 Z4MR silver grey
Originally Posted by BIMMERGUY91 View Post
Definitely. And if you like hellaflush just add a spacer lol
Thanks, I think I'll stay with "flush" ............. not a fan of "hellaflush"
      05-13-2012, 02:33 PM   #25
gferil
gferil's Avatar
23
Drives: 06 Z4MC
Originally Posted by mfanatic325 View Post
I went in to tesy fit for you guys, so the pix should be posted up soon =]
And I went in right after him...too bad we missed each other though.
Good news is they tested the silver and the anthracite on my car, and black on mfanatic's, so we get to see all three colors on our cars!
      05-13-2012, 03:25 PM   #26
dorifto88
Drives: 88 Nissan Pathfinder
in for pics !
      05-13-2012, 06:19 PM   #27
007MCoupe
007MCoupe's Avatar
Germany
57
Drives: '18 Sakhir M3 ZCP
Excellent! Thank you guys so much!!!
      05-13-2012, 09:24 PM   #28
BIMMERGUY91
Drives: 2014 335I M Sport
Dear god please post pics!!!! I cant freakin wait!!!
2014 335i M Sport
2010 328i M Sport
2007 Z4MC #1019/1815 (Sold)
1997 M3 (Sold)
1991 325i
      05-13-2012, 09:25 PM   #29
BIMMERGUY91
Im not a fan of function over form or form over function. I believe in function with form I guess thats why I like BMW
2014 335i M Sport
2010 328i M Sport
1997 M3 (Sold)
1991 325i
      05-13-2012, 11:35 PM   #30
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
149
Drives: '01 911 Turbo
Oh really? What time did you get there? I didn't think you were going to make it till late afternoon, so I headed home for lunch
      05-14-2012, 12:01 PM   #31
BIMMERGUY91
Pics Or It Didnt Happen!!!
2014 335i M Sport
2010 328i M Sport
1997 M3 (Sold)
1991 325i
      05-14-2012, 12:31 PM   #32
antennahead
      05-14-2012, 05:41 PM   #33
Eddy@ApexRaceParts
226
Drives: E30 M3, F10 M5
We test fit multiple combinations of the EC-7 wheel on the Z4 M last Friday. This model is very similar to the E46 M3 in terms of clearance, but with a little less fender side clearance in our experience.
Our first test was our preferred track setup: 18x9.5" with 265/35/18 tires front and rear. This is normally done with an 18x9.5" ET35 wheel front and rear, plus a 12mm spacer in the rear. Because we were using prototypes and only had one of each, we mounted an 18x9.5" ET35 front wheel and an 18x9.5" ET22 rear wheel. This is a spacer free direct fitment that gives the car a great staggered look while remaining square. You do sacrifice the ability to rotate tires front to rear with this staggered offset combination.
The rear fitment is a direct bolt on, but the front fitment requires camber plates, and a suspension that can properly clear the wheel and tire. It is important that the lower spring perch remain above the tire. If the spring or perch is next to the tire, then a thick spacer may be required for clearance which makes the fitment far too aggressive. A 5mm spacer would be acceptable, but anything thicker would push the setup too far out. The stock strut's integrated lower spring perch can clear the 265 setup, so a simple lowering spring and camber plate install can make for a very ideal track setup on the Z4 M. Many coilovers use long springs, helper/tender springs, or cone shaped springs. These may have to be replaced with a single shorter spring usually 6-5" in length to guarantee that the perch remains above the tire.
We had Satin Black prototypes in 18x9.5" ET43 and 18x10.5" ET27 available so we mounted those on the Z4 M as well. To correct for offset, we used a 12mm front spacer making the front effectively ET31. A 265/35/18 front and 285/35/18 rear tire were used for the test fitment. With the amount of negative camber the car had, this front fitment was not an issue. The rear 285 did stick out of the fender and is not a recommended size. This car arrived with a set of 19x10.5" ET22 Volk wheels and 275 tires and there were no signs of serious rubbing issues on the 19" setup, so the 18x10.5" ET27 wheel could be used with a 275/35/18, but attention to inside liner rubbing would be needed as the 10.5" wheel sets the barrel relatively close to an area known to rub on the inside. Generally 18x10" ET25 with a 275 tire is the widest we recommend for the Z4 M fitment.
Another Z4 M came that did not have camber plates installed. The cars only suspension mods were Eibach lowering springs and koni yellows. For this car we used the 18x8.5" ET35 Front and 18x9.5" ET22 rear with 235/40/18 and 265/35/18 tires. The front is an easy fit. A 245/40/18 could also be used on this wheel width. In the rear a 265/40/18 or 275/35/18 would also be a good choice.
The last test was with Anthracite finish wheels. The front was again 18x8.5". The test wheel was ET45 and we used a 10mm spacer to push it out to the ideal 35mm offset. The rear was 18x10" ET25 with a 275/35/18 mounted. The 275 was a Michelin PS2 and not an extreme summer tire like most of our tires. This tire was narrower and had more clearance than an extreme summer tire would.
      05-14-2012, 05:51 PM   #34
v3.2mc
Not a New Member
v3.2mc's Avatar
i really like the silver finish. interestingly enough, i don't much care for the anthracite. i thought i would like that one more, but not so much anymore.
thanks to our testers for getting their cars in for photos!
      05-14-2012, 06:10 PM   #35
gferil
gferil's Avatar
23
Drives: 06 Z4MC
Mine is the Silver Grey coupe...it's actually running Bilstein HD struts, not the Koni Yellows.
Anyways, thanks to Apex for letting me try the wheels on.
v3.2mc, the anthracite color is really one you need to see in person...similar to the sepang bronze color of your coupe. It went really well with the silver grey paint, and I think would look just as nice with black and white paint as well.
Regardless of color though, the wheels are beautiful in person, great lines, curves, build, weight...
I'm definitely looking forward to the pre-order of these!
      05-14-2012, 06:27 PM   #36
mfanatic325
///M-fanatic
Taiwan
149
I need aero sideskirts, BBKs, and possibly a new front splitter setup to complete the aesthetics portions of the car
      05-14-2012, 06:31 PM   #37
gferil
gferil's Avatar
23
Drives: 06 Z4MC
^Hahah...yeah. Bummed I didn't get to put on the black roundels before the shoot. Yesterday I finally put the custom black roundels for the sides and rear (blue parts and outer chrome ring painted black) and that would have been a nice touch with the anthracite wheels.
      05-14-2012, 06:31 PM   #38
Eddy@ApexRaceParts
226
Thanks for the clarification on the suspension. It was very bright out and you can see that the color of your car was not accurately represented in many of the photos (blue hue, washed out). Anthracite really did go well with your car.
      05-15-2012, 03:19 AM   #39
BIMMERGUY91
Holy crap these are gorgeous. Im in for a set as soon as they are available. Do you think I will have any trouble with the 18x10 +25 with a 275 in the rear. I am on H&R coilovers
2014 335i M Sport
2010 328i M Sport
1997 M3 (Sold)
1991 325i
      05-15-2012, 12:33 PM   #40
mpm3
mpm3's Avatar
2011 BMW M3  [0.00]
should be fine that whats i would be running
      05-15-2012, 04:35 PM   #41
mfanatic325
///M-fanatic
Taiwan
149
You should have no problems at all with the rear. Inside clearance up front is all you guys really have to worry about. My regular set of wheels are 10.5" +22 in the rear, with 275s, and it doesn't rub on the inside at all. My rear fenders are rolled slightly however, so as to prevent rubbing. It occasionally rubs (albeit minor rubbing on the fender liner) at the track, but on the street it never does.
      05-15-2012, 05:55 PM   #42
trialskid
Drives: 08 335i
What would the best fitment for stock suspension + tires be?
      05-15-2012, 06:18 PM   #43
Eddy@ApexRaceParts
226
18x8.5" ET35 Front with 235/40/18
18x9.5" ET22 Rear with 265/35/18 or 275/35/18
      05-16-2012, 12:10 PM   #44
OG_M3
Drives: ae86; z4mc
2011 BMW M3  [0.00]
2007 BMW Z4MC  [0.00]
1985 AE86  [0.00]
looks good. i really like the hyper silver.
waiting to pull the trigger on a 18x9 and 18x10.5 setup
Tags
18x10, 18x9, 18x9.5, apex, ec-7
