      04-26-2012, 11:15 AM   #1
kklin
Drives: BMW Z4 M Coupe
I am setting up my P1Gear.com site with SCCA Solo compliant magnetic number and class plates.
  • Each 20" x 12" number plate sheet has two 8" tall 1.25" stroke numbers that you cut in half with an Xacto knife and steel ruler. This gives you two 12" wide x 10" high plates. There is a black border around 3 sides.
  • Each 20" x 12" class plate sheet has four 4" tall class designations with a black border around all 4 sides. After cutting you will have four 12" wide 5" tall class plates. Use the two as back up or share with a friend.
  • Position the class plates directly below the number plate and you will have a plate whose overall dimensions are 12" wide x 15" tall.
These car magnets are affordably priced and quality produced by CafePress for me. I will post pictures of my plates shortly.
If you might be interested, let me know what numbers and classes you'd like via a reply or email request@p1gear.com.
      04-26-2012, 11:23 AM   #2
ZStig
I find that bigger pieces of magnetic sheets like you're producing, VS ordering individually cut numbers hold much better to the car.
Cool stuff
      06-16-2012, 01:24 PM   #3
kklin
P1Gear
Number and class plates are now available at my P1Gear.com CafePress shop.
      06-18-2012, 03:01 PM   #4
ZStig
should be easier to report your cones now =)
      04-09-2013, 08:52 PM   #5
kklin
P1Gear.com magnetic number and class plates
P1Gear.com now has magnetic plates for all numbers 0-99 and all SCCA classes.
You'll also find some BMW and F1 Circuits wear.
All profits go to charity (American Cancer in 2012).
      04-09-2013, 09:43 PM   #6
ZStig
      04-11-2013, 07:26 PM   #7
z3papa
Drives: 11 E92 M3 ZCP, 07 335i
One suggestion, you may want to format the number section so you can have 3 numbers in the event anyone wants to go to National tour, Prosolo, National's with a co-driver. Allows them to put a 1 on there. Nice product. If you accommodate three numbers, I may order a set.
2011.5 E92 M3 ZCP.
      04-11-2013, 09:21 PM   #8
kklin
Thanks for your feedback. I had considered that as my son also sometimes co-drives with me when he's home from college.
Unfortunately I can't reasonable squeeze a 1 on a single sheet that has two plates, and still follow the Solo number width rules. I very much wanted to be able to keep it very low cost - less than $30 for numbers and classes.
I had old magnetic numbers that I had hand cut and painted with Krylon, so I wind up using these when my son co-drives. The trouble with hand cut numbers is that they tend to tear in the corners after about a season. I went that route and described a nice procedure to make your own neat hand cut numbers here.
While I thought of separately producing 1s, I doubted there would be any sales as it defeats the low-cost idea. I had the rough idea of combining it with other desirable graphics, but didn't come up with anything nice that didn't violate someone else's copyright.
Best of luck in the new season!
      04-13-2013, 06:10 PM   #9
3002 tii
3002 tii's Avatar
Drives: E86, E90, F25
I use magnets too but always use some clear tape over the leading edge just in case
Active Autowerke | Supersprint | TC Kline | Ground Control | MFactory | Volks | Nitto
NASA NE TT5 #821
      04-14-2013, 11:11 AM   #10
The HACK
Roger Murdock
The HACK's Avatar
486
Drives: 2006 MZ4C, 2015 Fiat 500e
How well do they hold up for track events at speeds exceeding 100 mph?
The hell I don't! LISTEN, KID! I've been hearing that crap ever since I was at UCLA. I'm out there busting my buns every night! Tell your old man to drag Walton and Lanier up and down the court for 48 minutes!
-Roger Murdock
      04-14-2013, 11:55 AM   #11
3002 tii
3002 tii's Avatar
Never had an issue on any front straight, where u typically max 125-127. I just make sure the doors are clean before I apply them.
NASA NE TT5 #821
      04-15-2013, 11:51 AM   #12
Gt4
Gt4's Avatar
Drives: E46 M3 ZCP & T4R Limited
Can you make a special order?
I need number 09 and class TA-0 for my local Time Attack series.
Let me know the price shipped to J6Y 1G9 in Canada. I can send the payment directly to you via paypal
Thanks
Marc
