      02-14-2012, 04:45 PM   #1
kinkkujuusto
Drives: BMW Z4 2.5i -07
Aftermarket PDC
Here is a short story of my latest mod.
I bought this Cobra set from thurgo.co.uk. I painted them to match the cars paint.
I jacked up the car.
Remove rivets, 3 each side.
And then 5 nuts from the bottom.
Disconnect licence plate lights.
Bumper removed.
Dirty exhaust pipes.
Good chance to clean them.
You will find marks behind the bumper.
My little DeWALT is handy.
Drill from inside bumper with 3mm. I used a 3mm and then 17mm drills bits.
Then 17mm from outside.
Here is what it should look.
Attach wiring etc.
Put everything back in reverse order. Done! Here is link for bigger picture.
      02-14-2012, 05:08 PM   #2
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
very clean install. Good job
      02-14-2012, 05:11 PM   #3
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Nicely done and good DIY! Got me thinking about this one--coupe visibility out the back is, well, "poor" to say the least!
      02-14-2012, 06:02 PM   #4
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
can you elaborate a bit more on bumper removal? anything else other than removing the rivets and bolts?
The Raspinator
      02-14-2012, 06:11 PM   #5
kinkkujuusto
After removing rivets/bolts just pull it gently.
      02-14-2012, 06:27 PM   #6
Finnegan
Finnegan's Avatar
4 post on the board is a nice DIY.
      02-14-2012, 06:39 PM   #7
beta
Drives: 2006 M Roadster
Excellent post, this is one mod I've been interested in.
How does it work? is it just that you install the box in the cabin and it beeps when it's close to things? Any pics of that part of the installation?
      02-14-2012, 09:04 PM   #8
phoenixbmwlife
phoenixbmwlife's Avatar
Drives: M235i & G30 540i
2014 BMW/M235i  [0.00]
Beautiful Mod!
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta
https://www.instagram.com/bmwm_life_/
https://www.instagram.com/autogiftua/
https://www.instagram.com/phoenixbmwlife/
      02-15-2012, 12:11 AM   #9
kinkkujuusto
It works just like any other parking aid. It beeps faster/more when you approach something. When only 30cm left it beeps continually.
No pics for the installation, its very simple. Just plug all wires to main unit and then take +12V from reversing light.
      02-17-2012, 11:59 AM   #10
Jony722si
The Wrapgician
Jony722si's Avatar
Drives: z4si
2006 BMW z4  [0.00]
2009 Bmw 135I  [0.00]
2022 BMW M4C  [0.00]
2009 335i  [0.00]
Would you kindly to show the specific model of PDC that you bought? I'm interested to this DIY too
      02-17-2012, 12:14 PM   #11
kinkkujuusto
You can find it on 1st post. It is Cobra A0358.
      02-17-2012, 02:40 PM   #12
esqu1re
esqu1re's Avatar
41
Drives: M Coupe
Looks great, but where does the wiring connect to? Head unit?
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      02-17-2012, 04:15 PM   #13
kinkkujuusto
That black box in pic 1. Very easy, just take +12V from reverse light and ground from the cars body.
      03-21-2012, 01:48 PM   #14
davesz4mc
Drives: 2007 z4mc
Can you extend the wires for two sensors and run them to the front? Then you can know your about to curb your splitter lol, and still know about things behind you.
      03-21-2012, 03:59 PM   #15
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Even if you can extend the wires, the sensors won't get activated unless you have it in reverse...and when do you drive your splitter into the curb when you're in reverse
      03-21-2012, 06:55 PM   #16
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
Maybe a front mounted camera so you can see if you're gonna hit the curb would be a better solution.
      03-21-2012, 09:54 PM   #17
Ron Stygar
Drives: 2006 Z4 M Coupe
PDC
In 2007, I researched the PDC ready to go using BMW set up and sensors. Part guy said sensors don't last.
I decided to do a BMW camera set up front and back with aftermarket cameras. BMW wouldn't let you purchase the cameras.
I like the cameras because I can see the curbs front and back. I have it height in the right place to show front and back from one foot from the curb.
Cameras shows what I did in Bimmerfest:
http://www.bimmerfest.com/forums/sho...d.php?t=194687
You can get thirteen sheets of PDC installation instructions from a BMW EPA disc. Last one ended 09/2003. Maybe you can get it from BMW.
If interested, I have three EPA of them new and not copied.
$25. shipped USA.
      03-22-2012, 08:49 AM   #18
Walkurie
Walkurie's Avatar
Drives: 06 M Roadster / 99 Jaguar XK8
Hey, that's a monster drain cover in your garage, kinkkujuusto. I'd want to make sure I never left the top of that off!
