      05-28-2007, 09:04 PM   #1
DocRiSK
DocRiSK's Avatar
Drives: Z4MC
Antenna
Sorry for repeating the topic, but since z4um is down I am gonna have to ask you guys for this info again.
Where can I buy the shorter aerial antennas?
TIA.
      05-28-2007, 09:08 PM   #2
Ski
Hockey freak
Ski's Avatar
Drives: Bimmer's
Send a message via MSN to Ski
TIA.
Check ebay and be done w/it..it's not expensive..
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
      05-28-2007, 09:15 PM   #3
DocRiSK
DocRiSK's Avatar
Drives: Z4MC
Thanks Ski.
Found this one on Ebay...
http://cgi.ebay.com/ebaymotors/3-CAR...ayphotohosting
What do you all think of it? (on a silver grey Z4)
      05-28-2007, 09:20 PM   #4
inTgr8r
inTgr8r's Avatar
Drives: 07 Z4M Coupe
My original Stubby post from another site....
Here it is....
I just got this in the mailbox today
I think it's the perfect stubby.....
This one is 3" and... it's also available in 5"
I'm out in the country a bit where AM can be a little week... it seemed to be just fine.
It may be a little weaker than OEM but I'm not sure since I rarely listen to AM radio.
pic across rear deck....
It's avalable here - Mangowalk E-bay store
& the close up...
The base match is perfect... even the material is an exact match.
You would think it's OEM
And on top of that.... it's flexible
      05-28-2007, 10:26 PM   #5
AlanL
Drives: 2010 328ix Sports Wagon
I got the same one based on that post a while back. Nice mod!
      05-28-2007, 11:10 PM   #6
BimmerZealot
Drives: 2014 Subaru WRX
Can anyone explain how to replace the OEM antenna with a "shorty" ? Also how does it affect FM signal quality. Thanks
      05-28-2007, 11:11 PM   #7
oneshare325
oneshare325's Avatar
Drives: E90 325i, E82 135i
2011 135i  [0.00]
2006 325i  [0.00]
Looks great! my old man has a 3.0si, i think this mod would look nice on his car!
      05-29-2007, 12:18 AM   #8
AlanL
Step 1 - buy the shorty antenna from the link above.
Step 2 - unscrew OEM antenna from the base.
Step 3 - screw on stubby antenna.
I have to confess that I never play my FM so I have no clue how well it works - I just like they way it looks
PS - aren't you glad we are here to help?
      05-29-2007, 12:28 AM   #9
DocRiSK
DocRiSK's Avatar
Drives: Z4MC
What do you all think of this one (on a silver gray Z4)?
I am not quite sure if I like it or hate it
      05-29-2007, 02:36 AM   #10
BimmerZealot
Ah, that's a lot simpler then I thought. I was afraid I'd have to rip out the trunk lining and unscrew something to get it off =P Thanks for the help
      05-29-2007, 08:03 AM   #11
inTgr8r
inTgr8r's Avatar
I prefer to have the antenna as innocuous as possible.
Also, it's a bit of trial & error to find something that matches the base cleanly.
- they are relatively inexpensive, so it's no big deal if you get one & decide you don't like it.
      05-29-2007, 03:56 PM   #12
takedown8
takedown8's Avatar
Drives: 2005 BMW Z4 3.0i
I agree with, Intgr8r, DocRisk. That one's a little too flashy for my tastes. I thought the whole reason for getting a stubby antenna was to make it less noticeable.
I remember people mentioning back on z4um that the antenna is more for AM whereas there is a strong FM receiver located somewhere in the trunk. So the stubby antenna does slightly reduce your AM reception but doesn't really affect FM.
Someone mentioned to me that whichever receiver is picking up the better FM signal (either your trunk or your antenna) is the one that is used to transmit. Make sense?
      05-29-2007, 04:22 PM   #13
inTgr8r
inTgr8r's Avatar
Originally Posted by takedown8 View Post
........ So the stubby antenna does slightly reduce your AM reception but doesn't really affect FM.
Yes that's what I recall.
My FM signal is not diminished at all & the odd time I listen to AM it works fine in most areas.
(IIRC the other FM antenna is behind the rear bumper.)
      05-29-2007, 06:39 PM   #14
DocRiSK
DocRiSK's Avatar
Drives: Z4MC
Thanks guys! Yeah I gotta agree that one is a bit flashy and that's kind of why I wanted your opinions - I am gonna go with the regular short stubby.
      05-29-2007, 07:07 PM   #15
Rick Hunter
Skull Squadron Leader
Rick Hunter's Avatar
122
Drives: '07 M Coupé & '16 435xi GCoupé
I also heard that the external aerial antenna is used for the BMW Assist features (Roadside Assistance). I haven't had to use it since activation, so I'm not sure how the reception would be for the shorter antenna. BTW, I also bought the shorty antenna from Mangowalk and the delivery was very quick (seller is located in northern WA). Definitely looks OEM (perfect greyscale colormatch).
      05-30-2007, 01:06 AM   #16
BimmerZealot
Dont paired phones also use the antenna to boost performance for a crisp connection?
      05-30-2007, 01:26 AM   #17
takedown8
takedown8's Avatar
My phone works fine with the stubby antenna (if what you say is indeed true).
      05-30-2007, 07:13 AM   #18
inTgr8r
inTgr8r's Avatar
BT pairing is for head end comm link only.
The phone is still the transmitter.
      05-30-2007, 07:44 AM   #19
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
I typically only listen to 8-Tracks, however, I did install the Bimmian Micro recently for appearance and it really changes the curves of the car imo when viewing from the side and rear - less focus on the antenna.
2006 Z4MC - #LL93158
      05-30-2007, 09:35 PM   #20
BimmerZealot
Ordered my 3" stubby from Mangowalk :P should be here by the end of the week hopefully. I tried the twist off stock antenna from base with no luck. I'm assuming I grip base and turn it counter-clockwise to loosen? (Dont want to break anything) Thanks
      05-30-2007, 09:36 PM   #21
takedown8
takedown8's Avatar
Yeah, it should screw right off. You won't break anything so long as you're not bending at the same time.
      05-31-2007, 08:30 AM   #22
561design
z4um Hooligan
561design's Avatar
Jamaica
56
Drives: 3.0Si
Righty tighty... Lefty loosey...
Charles
flickr
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
