      01-21-2012, 03:58 PM   #1
zMpower08
zMpower08's Avatar
Drives: 2012 BMW 335i Sportline
RE Transmission Mounts and SSK Installed!
I just finished up installing RE tranny mounts and an RE SSK. It definitely improves the feel. Seems to be crisper, but the throws don't feel that much shorter (if at all).
Installing the mounts was pretty easy, aside from tightening the nut where the mount connects with the transmission. I did those last night and couldn't get it very tight because the space was so small.
Today I put in the SSK and had to remove the exhaust, so I had more room to tighten everything up.
Overall, I would definitely recommend these!
2008 M Roadster [SOLD] (Imola Red/Imola Red/Madeira Trim): Stubby Antenna, CDV delete, ZHP Knob, RE Transmission Mounts, RE SSK (Removed)
2012 335i Sportline (Melbourne Red/Black): Formula One Pinnacle Tint 15%R/30%F
      01-21-2012, 04:00 PM   #2
Beedub
did you tighten the mounts to Tq spec??? how are you guys getting a Tq wrench up in that space to Tq up properly?? Props for having a go yourself and no paying stupid prices for a garage to do it!!! SSK are not easy to install from what ive seen!!
      01-21-2012, 04:24 PM   #3
zMpower08
zMpower08's Avatar
Yeah, the SSK was a pain. It took us 4 hours. Taking the exhaust down and getting the rubber boot that seals the shifter into place were the two most time consuming parts. Luckily my friend who does a lot of work on cars helped out (he does corvettes and was pretty shocked at how tightly our cars are packed in). Worth skipping out on paying someone else to do it and its a nice hobby.
As far as the torque specs go, I didn't get a torque wrench up there. I just tightened them until it wouldn't tighten anymore. I figured since the transmission sits on them and the brace is bolted up the the body tightly, there would be enough force to keep them from creeping out.
      01-21-2012, 04:36 PM   #4
Finnegan
Finnegan's Avatar
Drives: Sapphire Black/Black Z4Mc
Tight enough is probably just fine. (There's really no practical way I could find to use a torque wrench on the top side nuts. Maybe I'm missing the boat). It's 16 ft lbs, which isn't much. There will be excessive vibration with too much torque (causing too much compression of the mounts).
      01-22-2012, 03:38 PM   #5
zMpower08
zMpower08's Avatar
While I was driving today, I found that in reverse the SSK contacts the driveshaft. I can hear the metal resonating and as revs increase the shifter starts the vibrate.
Is this slight contact something I should be overly concerned with?
      01-22-2012, 05:27 PM   #6
Beedub
i wouldn't be happy with that contact at all imo......... something is not right...
your ssk should be touch the prop shaft at all......
      01-23-2012, 08:51 PM   #7
zMpower08
zMpower08's Avatar
I just sent a note off to RE to see how we can resolve this issue. Luckily their company is based right near my house in NJ. I'm thinking that the pivot point was misplaced during manufacturing. It looks like there are several different notches to change the pivot location (maybe for different model cars?).
      02-24-2012, 10:31 PM   #8
zMpower08
zMpower08's Avatar
Removed the SSK
After being stranded in Pittsburgh at 1 am due to the shifter linkage coming apart a few weeks ago, and then being charged $426 to replace a 75 cent clip because I desperately need it fixed that day and didn't have access to a lift, I have decided to remove the RE SSK.
As I mentioned earlier, the kit touches the drive shaft in reverse and the noise has gotten progressively louder it seems. The kit has also become progressively sloppier as it seems to be loosening. RE said the contact is normal "at extreme angles" and after asking for the clearance specs between the bottom of the shifter and the shaft I stopped receiving a response from their company. The dealer (A&L Motors in Pittsburgh) told me that the clip most likely loosened due to the contact and vibrations--RE denies that this is a possibility. Obviously did not have a pleasant experience with the company...
A couple hours and $2.00 later, I have the stock shifter back in the car.
      02-25-2012, 12:03 AM   #9
3002 tii
3002 tii's Avatar
Drives: E86, E90, F25
You should look into the Autosolution ssk...
Active Autowerke | Supersprint | TC Kline | Ground Control | MFactory | Volks | Nitto
NASA NE TT5 #821
      02-25-2012, 12:24 AM   #10
gferil
gferil's Avatar
17
Drives: 06 Z4MC
Sorry to hear that. For what it's worth, I have the UUC SSK and Option 1 mounts and love the way it feels on the car. If you can deal with the long shipping times and sometimes rude customer service UUC is known for I say switch up to that.
      02-25-2012, 10:02 AM   #11
Beedub
absolutly would not expect the ssk contact i agree with your decision and im kinda dissapointed with REs repsonse...... Are they really saying its acceptable for the shifter to touch the prop shaft at extreme angles?? crazy, and dangerous imo..... Poor show RE.
      02-25-2012, 11:48 AM   #12
zMpower08
zMpower08's Avatar
Yeah I couldn't believe it either. And it's sort of embarrassing reversing out of a spot in a parking garage and having a loud ringing coming from my car.
      02-25-2012, 12:54 PM   #13
zMpower08
zMpower08's Avatar
I had looked into the UUC kit but the customer service reviews and the higher price scared me away. I'll be looking into them and auto solutions now.
      02-25-2012, 01:25 PM   #14
3002 tii
3002 tii's Avatar
I will never give UUC one cent of my money. Their customer service is beyond ridiculous. Shipping delays are just the beginning. I spent over $1500 on a big brake kit and they sent me the wrong brackets. I called them letting them know of the problem and they questioned the install. Only after numerous calls they finally allowed me to send it back. They acknowledged their mistake and decided to remedy the solution by sending the correct brackets via UPS ground, took 5 days. Even after that, I was having minor issues with their brakes but at that point they just refused to help any further. Ron is a class act d!ck.
Seriously give AS a call, they might make another batch for Z4s. A great AS review here (compared to RE & UUC):
http://m3.madrussian.net/review_as_ssk.shtml
NASA NE TT5 #821
      02-25-2012, 04:31 PM   #15
beta
Drives: 2006 M Roadster
That is terrible, it really shouldn't be touching your drive shaft. If you decide to install the auto solutions one, please post a review.
Nice review dubbed, that site is filled with good stuff. SSKs have come up a few times on here but that's the first review I've seen from someone that has tried all of them.
      02-25-2012, 04:53 PM   #16
inTgr8r
inTgr8r's Avatar
Drives: E86 Z4MC; E92 M3
I have the Autosolutions SSK as well.
They are expensive if you can't get a GB together but the product itself is fantastic!!!
It made a huge improvement with shifting; MUCH more precision and feel.
      02-25-2012, 05:10 PM   #17
beta
Also if you do go for the autosolutions SSK, check out this thread. Maybe ask him to supply chamfered bushings. I think the bushings he supplies are made for his selector rod, however on the Z4M you reuse the stock selector rod, so the bushings don't fit perfectly unless you chamfer them. Was that your experience as well intgr8r?
      02-25-2012, 05:25 PM   #18
inTgr8r
inTgr8r's Avatar
^yes, but it was a very minor thing to do.
It was a good thing that someone figured this out because it made a big difference in fitment.
      02-25-2012, 08:52 PM   #19
RobMCoupe
RobMCoupe's Avatar
20
Drives: 2007 Z4 M Coupe
Give AS a call. Everybody who purchased their SSK love the feel. I was the first one he sold the kit for Z4M. It took me a year for Ronald to design one. You might have better luck if you can get a group buy. I think he runs about 14 to 16 kits per batch.
      02-26-2012, 12:14 AM   #20
zMpower08
zMpower08's Avatar
Thanks for all the feedback and suggestions guys. I'll be looking into the AS one since so many people have had bad experiences with UUC. When I finally get around to buying it and installing I'll compare it to RE.
      02-26-2012, 03:52 AM   #21
beta
I'd sign up for a group buy if you start one.
      02-26-2012, 04:04 AM   #22
Beedub
+1
Tags
rogue engineering, short shift kit, ssk, tranny mounts, transmission mounts
