      11-17-2011, 09:59 PM   #23
beta
Drives: 2006 M Roadster
Let's see some pics guys! Before and after shots are encouraged
      11-24-2011, 07:22 PM   #24
dubsesd
OEM++
dubsesd's Avatar
No_Country
3592
Drives: F15 X5 MP/ 2016 F80 M3 INDVL
here you go guys....
      11-24-2011, 11:50 PM   #25
cooots
cooots's Avatar
Drives: Z4 M Coupe
Wow, great pics dubsesd
I think they look brighter here than they do in real life, but shows off the end result nicely! man your car is nice too.
Thanks for the input. You happy with them?
      11-24-2011, 11:56 PM   #26
dubsesd
OEM++
dubsesd's Avatar
No_Country
3592
Yes. Very happy with the kit. I did however get the replacement R-Dash LED license plate housing lights, that's probably why they are brighter. The kit ones are not very bright
      11-26-2011, 03:38 PM   #27
Bayonet
Drives: Z4 Mc
for anybody still wanting interior LEDs, bimmian is having its black friday special still going on i believe....should be 10% off and they have 3 different kinds to choose from.
http://www.bimmian.com/
      11-26-2011, 04:30 PM   #28
Aries326
Aries326's Avatar
Drives: 2008 Z4 3.0si
I just ordered a set of these from eBay to install in my 3.0si roadster. Something to do this winter. I can't wait!
@dusesd
Thanks for sharing those pics! Looks nice!
      12-10-2011, 07:12 PM   #29
goldguilexx
goldguilexx's Avatar
No_Country
27
Drives: mini
Just bought a set myself. Cant wait!
      12-14-2011, 04:21 PM   #30
jjdrivesajazz
Drives: 2003 bmw z4 2.5i
www.automationLED.com
in this car there are (2) 12smd godzilla panels for the front map lights and (1) t10 9smd wedge light for the trunk, the license plate and reverse lights will come very soon!
      12-15-2011, 08:31 AM   #31
Aries326
Aries326's Avatar
Originally Posted by cooots View Post
Replaced my rear licence plate lights with these...
Attachment 606721
Same amount of light as the standard globes, but white instead of yellow. finishes off the job nicely.
How's it look? I bet it was a lot cheaper than getting the whole replacement lights.
      12-15-2011, 06:29 PM   #32
cooots
cooots's Avatar
Drives: Z4 M Coupe
In my opinion, huge improvement over the standard look.
In terms of cost... US$4 delivered.
Try it, and if it turns out you don't like them, just throw them out. Can't imagine this happening tho.
      12-20-2011, 12:15 AM   #33
Aries326
Aries326's Avatar
That would be great if you could do that dubsesd!
Out of curiosity, I actually installed a pair of these 8-LEDs in the roof light afterward (2xreading lights)...
Attachment 604009
They fit fine through the reading lights holes, but not through the centre light hole??? must be slightly different diameter (or maybe it was just me). Not necessarily an issue though because, as XMetal mentioned previously, you can easily remove the glass and reverse-install the LEDs without any hassles. Or dremel the LED down a bit.
I did find that these LEDs were more closer to the brightness of the standard globes. Although I was happy with the ones I got with the ebay kit, I figure I might aswell keep these new ones in.
Moral of the story - if your not satisfied with the brightness of the LED roof lights, or any of the other LED lights for that matter, just spend an extra couple of bucks to get an LED with more lights on it to replace it.
A bit of trial and error may be required to satisfy your lighting preferences - no big deal. The results are definitely worth it and you'll probably never have to change the LED again.
Got a part number for these? I'm not too satisfied with the brightness of the LEDs would consider changing them to these LEDs. Thanks!
EDIT: Never mind. I was able to find them without part #s.
      12-20-2011, 12:25 AM   #34
Aries326
Aries326's Avatar
So, I finally installed my LEDs from the kit suggested above. It was ok. I loved the warm glow but the reading lights were too dim so I'm going to change the LEDs as suggested by other members here. Here are before and after pictures. Sorry if my camera didn't capture enough of the lights. I took the shot with a 35mm f1.8 Nikon lens with a D3100 at ISO 800 and I believe 1/40.
      12-20-2011, 01:33 AM   #35
Aries326
Aries326's Avatar
Originally Posted by chickdr View Post
I went ahead and ordered a 16LED festoon for my trunk only to find out my trunk doesn't use a festoon.... The roadster uses a wedge style lamp. Back to the drawing board.... Glad I only paid 1.50 for the bulb.
I just made the same mistake. I need to read these threads slower. Anyone want to buy a 16 LED festoon, let me know.
I just bought a set of these. It it's got 10 LEDs. It should be bright enough for the trunk.
      12-20-2011, 11:00 PM   #36
cooots
cooots's Avatar
Drives: Z4 M Coupe
Great photos, Aries326... perfect for people who want to see a direct comparison.
1 picture = 1000 words
thanks for the input
      12-28-2011, 03:23 PM   #37
jjdrivesajazz
a common mistake when buying LED's is that people assume MORE LED's = BRIGHTER
there are 2 common types of LED's, 5050smd and 1210smd
each 5050smd is as bright as 3 1210smd, so a 6smd 5050 festoon bulb is as bright as a 18smd 1210 festoon bulb
so for maximum light output, use 5050smd's, check out www.automationLED.com
      12-31-2011, 01:17 AM   #38
GammaZeta
Drives: 1
Very interested in doing this for the Z4M Roady interior lights. I would like to have the lights whiter and a little brighter, but not TOO bright.
Where is the best place to purchase them and what exactly should I buy to just do the cabin lights?
      01-03-2012, 12:03 AM   #39
cooots
cooots's Avatar
Drives: Z4 M Coupe
see posts #1 to #37
      01-03-2012, 12:07 AM   #40
GammaZeta
Drives: 1
I did, but I am still confused:
"there are 2 common types of LED's, 5050smd and 1210smd
each 5050smd is as bright as 3 1210smd, so a 6smd 5050 festoon bulb is as bright as a 18smd 1210 festoon bulb"
How the hell am I supposed to know what to buy after that?
      01-03-2012, 01:11 AM   #41
Aries326
Aries326's Avatar
Here's what I put in my trunk. The kit that was suggested by the OP comes with a festoon which a Z4 non-M does not have.
Here's the kit I bought from eBay for the Z4. This is what the OP suggested buying. I haven't tried figuring it out yet, but you can probably put together your own set cheaper but it's a bit of a pain in the ass to do.
I thought the reading lights were a bit too dim so I tried replacing them with these but it didn't make too much of a difference because you still only have one LED that's really facing downwards. It's not like the inside of the housing is reflective and the other lights on the sides would help.
So after ordering some extra LEDs and playing around with them a bit, I'm basically using the same LEDs that came with the kit except for the one in the trunk.
      01-03-2012, 09:53 PM   #42
cooots
cooots's Avatar
Drives: Z4 M Coupe
Was just kidding you
Your probably best to go with the ebay kit I suggested (all the lights are a good brightness, except the roof lights which may be a little dim for some).
If it turns out your not happy with the brightness of the roof lights - replace them with some alternatives (going by jjdrivesajazz's post - something with 5050smd LEDs would be your best bet). Again, ebay.
At the end of the day, we're not talking big $ here, so don't be afraid to experiment.
Hope this helps...
      01-06-2012, 12:09 AM   #43
jjdrivesajazz
you could tell easily by the size, and most reputable LED stores will tell you if it's a 5050 led or 1210 led in their description
refer to www.automationLED.com for more pics, check under godzilla and t-rex lights
here's a quick comparison to 12smd panels, both have 12 led's, but the left one has 12 5050 LED's, while the right one has 12 1210 LED's
      01-11-2012, 07:44 PM   #44
nicepeta
Drives: 2010 MINI cooper
Thats bright! nice pictures too
I got my from 4aeautodesign.com They have all kinds of LED with great price too
Tags
led interior light globe bulb
