      10-05-2011, 08:10 PM   #1
E85BMW
E85BMW's Avatar
Drives: 2006 M Roadster
E85 N52 Engine Swap
First off, I'll admit, I'm new to car mechanics.
That being said, I have a 2007 E85 Z4 (N52). I was wondering if it's possible to swap the engine with that of an E85 Z4///M's S54 engine?
Thank you.
      10-05-2011, 08:23 PM   #2
habitat412
Drives: 2008 Z4 M Coupe
Sure anything is possible if you have the money, but when all is said and done you are better off just buying a M Coupe. The motor alone along with the work is going to cost as much as your current car, but if you have the time and money go for it!
      10-05-2011, 09:03 PM   #3
beta
^^^ if you're doing it for fun or because you can, go for it! If you're doing it for the results the M will be much much cheaper and have much more.
      10-05-2011, 09:58 PM   #4
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
Buy an M
      10-11-2011, 05:19 PM   #5
-c-
-c-'s Avatar
Drives: bmw
Ok now I’ll admit I may have taken my "I" a tad too far with the M rear duals and body panels and such but when you are talking the power train it’s a whole new beast...
when I was converting my "I" to dual exhaust and going in and out of the "I" "Si" and "M" models there’s a lot going on in their than just the engine, first you’ll have to buy other suspension bits and fuel hoses and then you’ll have to get the exhaust correct and that has a whole set of issues and if you’re not doing the work yourself and you pay someone 30 bucks an hour you’ll quickly get up and over the cost of an M.
if you look around you can grab an M for 5 to 7 grand more than your car now, some were way less some more just look around...also you have to replace the ECU and gauge cluster tied to the car as well as key and all that jazz, you’ll also have to have the title and such to the engine you have in case you ever lose the key as BMW needs proof of ownership.
like I said its cost effective to just buy an M, since this is my wife’s car that I get to tool with it. Its an auto so I’m just having fun, I know I’ll never buy the M and I’m fine with that but I can play with the looks of it for now. not sure if you have the Si or I but if you want to wait I’m having a special tune done that will get your I to be better than that of a stock SI for HP numbers and from what I hear the feeling from and SI and an M are very close to one another.
      10-11-2011, 06:16 PM   #6
3002 tii
3002 tii's Avatar
2282
no point in swapping for a motor/car that already exists. you'll spend more doing a swap unless you happen to come across a wrecked M for cheap and plan on doing the work yourself. if you're bored, then i say go big or go home. go for a v10 swap from the m5. the motors usually can be had for 10k or less on ebay.
Follow for latest mods
      11-05-2011, 03:22 PM   #7
just2talented
just2talented's Avatar
Drives: Alpine ///M roadster
BUY AN M
      11-05-2011, 04:08 PM   #8
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
OR swap in something bigger than an S54....
Tags
e85, engine, n52, s54, swap
