FORUMS
- 5
| 09-04-2011, 05:21 PM | #1 |
![]() ![]() Drives: flat out Join Date: Apr 2008
Rogue Engineering Fixed Camber Plates Installed
Didn't have the money for adjustable camber plates, and if I were going to go that route, I'd want to mate it with coilovers which and I definitely didn't have the money for that so I figured I'd be the guinea pig for RE's fixed plates. Dinan offers something similar but at double or triple the price. RE is local to me and their products have excellent reputation so I figured it's worth a shot.
Happy to say install went flawlessly. Removed the crash pins, installed the plate, went for a 4 wheel alignment and was able to dial in -2.4 degrees on both sides (-1.1 on the rears). Pics of front wheel, Volk RE-30 18x8.5 wrapped in Star Spec 235/40-18. Will take a side pic later but wanted to show the angle first (the track ready m3 on the right is my neighbor's car): ![]()
![]() Recaro | AST | Vorshlag | Quaife | Stoptech | Volks | Autosolutions | BMW Performance Click here for my track videos Last edited by DSC_OFF; 09-06-2011 at 06:13 PM. |
| 09-06-2011, 07:00 PM | #3 |
![]() Drives: fairly quickly. Join Date: Oct 2010
Considering that's an M3 that appears to be on Hoosiers or NTO1's, I'll take the bet that the M3 will likely have him beat.
"It will not have enough power until I can spin the wheels at the end of a long straight in top gear."
-Mark Donohue |
| 09-06-2011, 08:17 PM | #5 | |
http://www.zpost.com/forums/showthread.php?t=576471 ... and it's going down.
| v3.0si |
| '08 Z4Coupe 3.0si | BMW Aero | BMW Performance |![]() |
| 09-06-2011, 09:25 PM | #7 |
My Scientific Wild Ass Guess wasn't too far off from reality...
Hard to tell performance tires from pictures unless you get a clear view of the tread or sidewall.
-Mark Donohue |
| 09-07-2011, 01:03 PM | #9 |
No it does the opposite if anything, stack plates add 1/8" if I had to guess. If you have the m coupe and you're looking to dial some negative camber, you should look at the Turner shim kit (even much cheaper than RE, $15 or something like that).
![]() Recaro | AST | Vorshlag | Quaife | Stoptech | Volks | Autosolutions | BMW Performance Click here for my track videos |
| 10-24-2011, 04:20 AM | #10 | |
![]() ![]() ![]() Drives: Z4 M Coupé - Carbon Black Join Date: Mar 2008
Any advantages for basically the same thing as far as I can tell? I am getting -2.5 on the Frontend with the TMS kit. |
| 10-24-2011, 06:33 AM | #11 | |
![]() ![]() Drives: 2007 Z4 M Coupe Join Date: Sep 2008
Because of the difference in the distance between the shims and the pivot bolt vs. the outer edge of the wheel/tire and the pivot, the loss of clearance will be some multiple of the thickness of the shims--see http://www.eabjr.com/Camber-Shims.php to understand the geometry. I'm shimmed to -2.75 degrees, and with the stock wheels and tires it looks kind of close. I'm going up to an 8.5" wheel, et 35, with 245/40/18 tire; I have 5mm spacers and hub extenders in hand to solve the problem if they don't clear the strut. |
| 11-03-2011, 12:56 PM | #14 |
I don't know how much you can achieve, but with KW V3s at max height I got -2.1 in the front. If you dropped it more you'd get more.
| 11-03-2011, 01:26 PM | #15 |
Not bad at all. Any idea on the rear? No pins to pull of course, so just wondering what max adjustment is with a drop. Seems like few people add adjustable camber arms in the rear and I've seen a lot of specs with around -2 in the rear.
| 11-03-2011, 01:42 PM | #16 |
Drives: A///MERICAN!!! Join Date: Mar 2010
Thanks for posting. Is -2.4 max? Personally, I'd cough up the extra $150 for Ground Control street plates. At -2.7 my front tires were still rolling over like a bitch
| 11-03-2011, 03:33 PM | #17 |
wyath: yes, the rear ended up at -2 exactly. I believe the rear does have some adjustment.
| Bookmarks |
