Reply
      09-01-2011, 10:45 PM   #1
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
My New Track Accessory
Using the GoPro has been a blast but past few events have had showers and thus my wipers wouldn't allow me to mount the camera on the windshield. I could use one of their adhesive backed mounts on the front bumper but that's somewhat permanent... But recently came across a tow hook adapter for the GoPro.
This is the perfect spot imo, not only is it more level with the ground but it should pick up the noise coming from the hood. Can't wait to test this out!!
Recaro | AST | Vorshlag | Quaife | Stoptech | Volks | Autosolutions | BMW Performance
Click here for my track videos
DSC_OFF is offline   United_States
      09-01-2011, 11:51 PM   #2
mfanatic325
///M-fanatic
mfanatic325's Avatar
Drives: '07 Z4MC, '04 325Ci
Send a message via AIM to mfanatic325
That looks pretty legit. Post some vids when you're done!
VF570 S/C|TIAL BOV|SetRabCooler|Brembo GT 6/4|TE37s|NT05s|3.91 Gearing|TCK D/A|RPi Induction|SS Race Mufflers/X-pipe|JVT Headers|AS SSK|Sparco Pro2000/6pt.Harness|MS FloorMounts|SE Custom Harness Bar|Tekarbon Angels|M-Tech Pedals|OE Strut Bar|RE RSMs|8000K D2S|CDV DEL|CF Roof Wrap|MB Grills|UUC TrannyMounts/ClutchStop|V1 Mount|P3C Gauge
mfanatic325 is offline   Taiwan
      09-02-2011, 12:30 AM   #3
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
Great location, about to do the same on my car except using a ContourHD. Also trying to find a proper way to mount the camera and get a good view of the pedals , steering inputs, etc. On most cars the sunroof works great, but the huge divider on our cars makes it a tad difficult to get the right angle.
2004 Porsche GT3 |White
HRE R40 Monoblocks | KW Clubsport Suspension | RSS Lower Control Arms and Suspension Links | GT3RS Wing and Front Bumper | Cup Car Lip | Euro GT3 Seat | GMG Half Cage | Europipe Exhaust | EPL Tuning
onelove is offline   United_States
      09-02-2011, 01:06 AM   #4
Barryb97
Drives: 2006 M coupe
Looks great. Where did you get it?
CDV delete, clutch stop, strut bar, SS brake lines, radiator hole cover, brake duct stop removal, Gunmetal M3 reps, RAD wheel locks, M strut caps, roundel under hood, Intravee II ipod adapter, Homelink garage opener, air bag sticker delete, first aid storage under seats, Bumper plugs keyhole cover, painted reflectors, Headlight washer disable, Mstache front lip, Autosolutions SSK, Leather Z arm rest, Stromung exhaust, RPI scoop…
Barryb97 is offline   United_States
      09-02-2011, 01:51 AM   #5
bucko521
More of this than that!
bucko521's Avatar
Drives: BMW Z4 3.0i
Very nice.... please post the model and where it can be procured!
Bucko Future Vision
'06 Z4 3.0i Jet Black/ Biege/Black
Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill
Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector
bucko521 is offline   Canada
      09-02-2011, 06:37 AM   #6
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
I have one of the GoPro adhesive mounts in between the center pocket, at the very top. You get a good view of the steering wheel, shifter and windshield. Don't recall if you get any pedal action but I still thought it was pretty decent.
      09-02-2011, 06:42 AM   #7
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
I bought it from Rennline, same site I bought my H/T pedals (see thread here). Product link:
http://www.rennline.com/newssection.asp?dept=982
Few things to note though:
1) This bracket is meant to be used with their tow hook mount. However, due to the curvature of our bumper, the tow hook will NOT clear the front bumper even with the addition of extra washers. Therefore, you will have to call in your order and ask for a special order: a) tow hook screw + b) GoPro bracket but NO actual tow hook
2) As mentioned above, because clearance is an issue, you will need to also specify the need for extra washers. I don't recall how many used but I can check later today how many I used exactly that way you can specify the same number.
3) In their product link, you see the GoPro camera is mounted directly to their metal bracket. However if you look at their other picture where it's mounted on the rear bumper, you see they used one of the GoPro extensions (I believe it's the right angle arm) to get around the offset of the bumper. Because we have similar issues on our front bumper, I had to use that extension as well. FYI the extension is included with your original GoPro kit.
If you are interested in this mount, I'd call Rennline directly and ask for Tom. They have great customer service and Tom was the one who I spoke to when dealing with fitment questions so he should be familiar with what you'd need to get this to work.
      09-02-2011, 12:06 PM   #8
Loogey Clapp
Loogey Clapp's Avatar
Drives: 2006 Z4 3.0si
I have been wanting to add a camera like this for some of my roadtrips. I really like your setup!! When it is mounted outside like that, what kind of protection does the camera lens have against flying debris?
Loogey Clapp is offline   Reply With Quote
      09-02-2011, 04:37 PM   #9
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
The camera is sits inside a plastic enclosure provided by GoPro. It seems sturdy and the clasp doesn't seem like it'd come apart easily. Worst case you can buy a replacement enclosure if yours gets scratched up.
      09-02-2011, 05:23 PM   #10
007MCoupe
007MCoupe's Avatar
Drives: das Bierwagen
2007 Z4 M Coupe  [0.00]
excellent! now all we need is some vids.
also, what are your settings at (to get optimal video length without sacrificing too much quality)?
RPI scoop///VB3///75mm wheel studs//////Stubby///GoMiniGo///GC front sway bar///AKG Engine Mounts///AKG Trans Mounts///SS brake lines
Harris Hill Road, LVMS, Ring...
007MCoupe is offline   Reply With Quote
      09-03-2011, 12:42 PM   #11
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
My next event is in 3 weeks but this is how it looks mounted on the windshield, VIR in July:
      09-03-2011, 03:40 PM   #12
txz4
txz4's Avatar
looks like im playing gran tourismo!
nice driving dub!
txz4 is offline   Reply With Quote
      09-04-2011, 04:05 PM   #13
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
nice driving dub!
thanks man, I plan on adding more here:
http://www.youtube.com/user/dubbedown?feature=mhsn
      09-06-2011, 02:03 PM   #14
Loogey Clapp
I just got off the phone with Tom at Rennline. I told him I wanted a bumper mount for a Z4 and he knew exactly what the setup was. "tow hook screw and GoPro bracket but NO actual tow hook." He was very familiar with the setup for Dubbedown, so my order was a breeze. I don't think I was on the phone with Rennline more than 4 minutes and my order was complete. Thanks Dubbedown!! This is way cool. Now, all I need to do is get the GoPro!
      09-06-2011, 02:28 PM   #15
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
That reminds me, I'll go home and count the # of washers I had to use. But whatever that number is, put the washers on first and install the tow hook screw first. Then mount the GoPro bracket afterwards.
If you install the GoPro bracket with the screw first, and then install, the bracket may graze the bumper as you rotate it.
      09-06-2011, 03:51 PM   #16
WestCDA
Drives: 2006 Z4R 3.0si
Good idea for a mount location. I use RAM mounts for all my vehicle mounted equipment, so already have a bunch of mix and match components and device cradles. They are incredibly solid and adjustable, and once you've got a mounting solution for a new vehicle, you can mount any other device you have an attachment for.
For this, I'll just put an inexpensive RAM ball (a few dollars) on the end of a threaded rod adaptor - should work perfectly!
This is RAM's GOPRO mounting system.
http://www.ram-mount.com/NewProducts...5/Default.aspx
WestCDA is offline   Canada
      09-28-2011, 11:33 AM   #17
Loogey Clapp
Dubbedown, I haven't seen any of your videos from the bumper mount posted. How is it working out for you? Any issues with vibration or anything? Also, what is the rubber O-ring for on Rennline's screw mount for? Was that just to hold the washers on during shipping? Is it used when mounting to the bumper? Have you been able to check the # of washers you are using? I apologize for all the questions.
Since I now have this bumper mount, I ordered the GoPro last night. After looking at the videos from Cyrus on another thread, I am anxious to get going on this.
      09-28-2011, 11:54 AM   #18
TriAdX
Drives: 1968 Mustang
http://4wheelonline.com/atv/Sport_Cameras.175023 Good deals on cameras.. also have a bunch of Go Pro Hero kits.. all super cheap.
2007 Z4M Coupe - 2006 YZF600R(rip) - 1968 Mustang 302 - 1997 Eclipse Spyder GS
TriAdX is offline   Reply With Quote
      09-28-2011, 02:14 PM   #19
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
Haven't done a track session since but will be doing one this weekend so can post videos afterwards. I did count but I forgot lol. I'll count again today.
I do use the black rubber washer in case when I pull the mount out of the bumper, don't want to lose any white plastic washers. Plus I think it tigtenes better using that as opposed w/o it.
      09-28-2011, 04:12 PM   #20
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
www.ogracing.com
They were selling the LCD bacpac free if you purchased a GoPro at their normal retail price. Free shipping over $100 and orders ship fast...
      09-28-2011, 04:44 PM   #21
Loogey Clapp
Cool! Thanks for the advice! I don't do track but I do know a few good roads within 300 miles though.
      10-05-2011, 08:13 AM   #22
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
Good news: Finally got a chance to count the # of washers, 19 in total excluding the black rubber ring.
Bad news: Non-stop rain combined with thick fog at Watkins this past weekend, apparently the worst weather they’ve ever had (multiple crashes). Therefore did not get a chance to use the GoPro mounted to my bumper, instead ran it from the interior.
OK news: Will have a chance to test it once more in 2 weeks at NJMP Lightning.
Reply
Forum Jump
