      08-12-2013, 11:37 AM   #947
seank
enthusiast
seank's Avatar
48
I am seeing over nearly 11 if that helps in 2nd and 3rd. I have not done a pull to red line in 4th yet, since it needs to be late at night on a week day to avoid cars and cops.
      08-12-2013, 11:59 AM   #948
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6332
Damn street racer!
Jealous of the little supercar you've created yourself
instagram: @ dubsesd
      08-12-2013, 12:22 PM   #949
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
that fits my correlation of boost to impeller speed a lot more... Are you complete sure you're not hitting redline and causing a boost spike? I'd get a dyno if I were you, you should be near 500rwhp
      08-12-2013, 02:18 PM   #950
seank
enthusiast
seank's Avatar
48
Positive on the red line. When I was having issues, I pushed it to the line. But now, if I gas it to 5000 rpms, I am over 6psi. It is kind of scary. It pulls so strong. I will be interested to see George's figures. I will do a dyno when I can get out at the track and use the Dynojet that we use on the track cars.
      08-12-2013, 02:20 PM   #951
seank
enthusiast
seank's Avatar
48
Originally Posted by dubsesd View Post
Damn street racer!
When you get bored and are falling out of love, it will bring it all back. You will fall in love all over again. I still won't be able to compete with the new M5, but she is more beautiful, sexy, and eye catching.
      08-12-2013, 02:28 PM   #952
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
^WHS.
      08-12-2013, 02:32 PM   #953
GuidoK
GuidoK's Avatar
10844
Drives: Z4 3.0i ESS TS2+
I still won't be able to compete with the new M5.....
Is that before or after you've reached the first corner?
      08-12-2013, 02:41 PM   #954
ZStig
279
you should be able to run mid 11s in the straight line
      08-12-2013, 11:39 PM   #955
ZStig
279
Well, I did a few more runs today, and I'm definitely not hitting 8psi.
7psi for sure in 2nd gear. 6psi in 3rd. Wondering if there's a way to test my belt for slip, or what else could cause a drop in psi in 3rd gear. Maybe a slow leak....
Still waiting on Jaws Motorsports to quote me on a shipping price for a crank pulley
      08-13-2013, 12:11 AM   #956
seank
enthusiast
seank's Avatar
48
Your getting the same numbers I was getting before using the digital p3 gauge for peak recall. I had to be in 4th to get 8psi. Not anymore.
You knew this, based on your chart.
      08-13-2013, 08:01 PM   #957
ZStig
279
Anyone know of a source for a ~5.5" crank S54 pulley?
Jaws is beating around the bush
      08-13-2013, 08:08 PM   #958
ZStig
279
I just out-drove a 700rwhp CTS-v to 4th gear. Guy was double clutching all his upshifts and lurching like crazy. Fortunately my local guy knows who it is (hence the power info), and is mocking him over the phone. He now wants a re-match on drag radials. ppfffffftttttttt. nope, street tires vs street tires baby.
      08-13-2013, 08:24 PM   #959
seank
enthusiast
seank's Avatar
48
      08-13-2013, 08:49 PM   #960
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
Peak recall is very inaccurate...
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      08-13-2013, 09:01 PM   #961
ZStig
279
should be accurate up to about 7800rpm
      08-13-2013, 09:13 PM   #962
Rated M Roadster
160
I mean as far as spikes. There's no way seank is hitting 11 psi without a spike... That needs a datalog to be proven not a spike, IMO.
Also, where is everyone else's dynos? Still no torque numbers on the G-Power kit, etc.
      08-13-2013, 10:52 PM   #963
ZStig
279
This new data makes a lot more sense. I'm now considering an oem 5.25" S50B32 pulley, with a 3.11" vortech pulley milled down and pro-grip coated
http://carbiniteracing.com/benefits/benefits.html
      08-13-2013, 11:02 PM   #964
Rated M Roadster
160
I was just on that site; thinking about sending my 11 psi pulley in to get coated.
      08-13-2013, 11:05 PM   #965
ZStig
279
11psi?
definitely coat that bad-boy. Seems like a much better deal to run a small coated pulley instead of a custom $$$ crank pulley.
I love that we now have a team of blown Z4Ms, pushing each other to the limits through combined research efforts, trial and error, and big balls of steel.
      08-13-2013, 11:13 PM   #966
Rated M Roadster
160
11psi?
I tried it out for a while; slips around 7k rpm. It runs about 52k impeller speed.
      08-14-2013, 09:08 AM   #967
ZStig
279
What size pulley?
      08-14-2013, 03:31 PM   #968
Rated M Roadster
160
What size pulley?
4.5 crank and 2.5 SC
