      02-05-2013, 12:26 PM   #881
Rated M Roadster
Rated M Roadster's Avatar
29
Drives: F10 M5
Originally Posted by ZStig
I wonder if it will just snap in. Im assuming i have to remove the M brake ducts, but i hope thats it
The under tray will be different; no more fangs.
CURRENT ll F10 M5
SOLD ll E70 X5M
SOLD ll Z4MR VF570
      02-05-2013, 06:24 PM   #882
ZStig
No biggie, I'm missing the undertray anyway. Ran over truck tire pieces on the highway. hahah
Bumper ordered! Excitement building, especially since this mod isn't coming out of my pocket
      02-06-2013, 09:22 AM   #883
pokeybritches
pokeybritches's Avatar
Bahrain
125
Drives: ESS/G-Power Z4M, VF Z4, 987.2
2006 BMW Z4M  [5.00]
2006 BMW Z4M  [4.25]
2003 BMW Z4 3.0i  [4.50]
If you decide you want fogs later, maybe we can work out a swap for light control modules. I did the M bumper conversion on my non-M, so I don't need the fog selection. We would have to look and see if there's any car-specific data stored in the LCM.
VF Engineering Z4 3.0i, ESS Z4M, G-Power Z4M, 987.2 Cayman S
      02-06-2013, 01:56 PM   #884
ZStig
I don't think the M comes with light control modules, and I don't think the basic aero bumper kit I bought comes with it either. Shipping kinda sucks though, I didn't budget for it. $175. sheesh
      02-13-2013, 09:46 AM   #885
ZStig
The bumper is on national backorder. Eta 2 weeks
      02-21-2013, 08:50 PM   #886
ZStig
No wonder shipping was $175...came all the way from Germany
      02-22-2013, 01:14 PM   #887
Beedub
Awesome, very jealous :-)
      02-27-2013, 08:40 PM   #888
ZStig
The Aero bumper is now with the painter, who will also fill in the holes for the headlight washers. They're only charging me $75 for that option, and BMW wants $60 for 2 new covers, so its a no brainer.
I asked about eliminating the fog light holes, and they said they can do it, but there is a lot of work involved and it would be costly. My plan is to use them for brake ducts, maybe even combine piping with the openings below them (the bottom side grills)
      02-27-2013, 09:24 PM   #889
flipm3
E46 + E90
Philippines
72
Drives: E46 M3 + E90 M3
2009 BMW M3  [0.00]
2002 BMW M3  [0.00]
Oooo, I can't wait to see the new bumper
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread
E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread
      02-27-2013, 10:12 PM   #890
ZStig
Should be done Tuesday
      03-05-2013, 11:19 PM   #891
ZStig
whew! that was scary, it wasn't even close to clearing the intercooler without modifying all 3 the lower grilles and the corners of the bumper itself. For some reason, the lower grills have a large protrusion behind it that I had to slice off.
Also, the corners of the bumper that have little tabs that snap into the $36 piece that often breaks off: the M bumper has indentations between 2 of the tabs and this one didn't. Took me 10 minutes to figure out why the hell the corners weren't snapping into place. Then I cut out the little grooves it was missing.
By the way, the basic aero bumper kit from tischer doesn't include a tow hook cover ($20), or the $36 x 2 headlight washer covers. Thankfully my local euro car paint shop only charged me $75 to fill and hide the headlight washer covers.
Note the cuts on the back of the grille
      03-12-2013, 04:19 PM   #892
Str8 RippiN
Str8 RippiN's Avatar
26
Drives: E46 ZCP ///M3
to anyone that had the 445 kit and upgraded to the 500 i was curios to hear your thoughts on the following
-usability
-mpg
-drivability
-$ to HP capita(to upgrade)
-any negatives or positives from going from 445 to 500? i.e. Tire wire, clutch, higher running temps, clutch slip?
-weight difference? i know the 500 weigh about 35lbs more than the 445 with all the additional components, is it noticeable?
Thanks - Tommy
      03-12-2013, 11:07 PM   #893
iPhoneEngineer
Drives: 2007 BMW Z4 M Coupe
-usability
-mpg
-drivability
Thanks - Tommy
I went straight to the 500, but from everything I've read, the 445 actually has noticeably higher running temps than the 500 because the intercooler makes a very significant difference. IIRC the oil cooler is also larger?
Highly recommended; the extra power and torque is very noticable and brings the car into a true supercar realm. It's almost as fast once locked up in 2nd as my 2012 911 Turbo S
      03-13-2013, 08:45 AM   #894
ZStig
I think only beedub upgraded here
      04-27-2013, 04:24 PM   #895
tikamak
Lebanon
24
Hi zstig,
ESS sent me intercooler brackets that belong to E46 M3, can you please measure the intercooler brackets your have as well as take angles so that i can fabricate it locally?
I also need the length of the intercooler pipe bracket
I also need pictures of both intercooler pipes (sc to i/c and i/c to intake) taken from below the car as well as from above so that I know how to install them.
I was sent an e46 M3 manual as well. so i don't know how this will fit exactly.
awaiting your replies in here or on jad_mrad@hotmail.com
      04-27-2013, 05:21 PM   #896
GuidoK
GuidoK's Avatar
596
Drives: Z4 3.0i ESS TS2+
If you got an e46 kit it's wise to contact ess and ask if there are more differences if you didn't already have.
I also recieved an E46 kit (somehow they dont have different order#), and with mine (m54 engine) there were more differences than only the brackets which you only notice when building. For exemple the bolts to hold the belt rollers were longer then they should be, resulting in screwing the bolts in the cast oil filter housing too deep, resulting in cracking the oil filter housing (the bolt lug with thread). Luckily I have a Tig welder which can handle aluminium so I could fix that because that cast oil filter housing is a $400,- part....
I also needed another belt and some parts.
Z4 3.0i | ESS TS2+ | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers | Sachs performance clutch
      04-27-2013, 05:30 PM   #897
tikamak
Lebanon
24
I contacted AJ, I'm waiting for his reply ^^ or waiting for a different reply than the one i had concerning my issues.
i need my car running with locally made parts before ESS send the correct bracket. that's why i need measurments and tons of pics from different angles.
      04-27-2013, 05:44 PM   #898
GuidoK
GuidoK's Avatar
596
You're working against a deadline? That always sucks.
      04-28-2013, 11:55 AM   #899
ZStig
Originally Posted by tikamak View Post
Hi zstig,
ESS should give you the info you need, more accurately than me. I can help you, but not until later tonight.
If you're talking about the "intercooler pipe bracket" that attaches straight into the intercooler piping that has a hole in it, my kit didn't come with the correct one either (too short) so I fabricated one myself using a piece of aluminium
      04-29-2013, 12:01 AM   #900
tikamak
Lebanon
24
Ok thank you zstig, as i will do that as well. The bracket is too short and with the help of pics from beedub I discovered this.
Any pic would be wonderful from you guys as it will show me the pipes positions.
      04-29-2013, 12:02 AM   #901
tikamak
Lebanon
24
Btw when im done i will do a build thread as well
      06-16-2013, 11:25 PM   #902
ZStig
Selling the cutouts. Going to use the funds to go fully catless
http://www.zpost.com/forums/showthread.php?p=14174182
