      11-21-2012, 04:30 PM   #815
Beedub
Originally Posted by tikamak View Post
Man how the fuck you shift 1st to 2nd like that ? this keeps baffling me.
Can you post a video explaining this as much as you can?
practice man, practice!! i find the stock gear setup great for banging home the shifts, its crap at slow granny shifts!!!!
      11-21-2012, 04:34 PM   #816
tikamak
Lebanon
24
bee post some video showing me your technique, i want to see how you do it.
I find myself unable to shift fast due to the grind issue or the fear from the grind issue.
Do you start moving the shift knob a jiffy before pressing the clutch pedal or after or at the same time?
      11-21-2012, 11:50 PM   #817
ZStig
In that video, I actually overrevved a little bit. I do owe you a video tutorial, I think you asked before.
Some z4m's have issues with grinding going from 1st to second. I don't, so I go hard on it.
The simplest explanation is perfectly coordinated timing with my foot hitting the clutch and my hand pulling the lever straight back. Believe it or not, its done in a single motion. I kick the clutch and shift at the same time. Going over a rough analysis of the audio from the videos, my 2-3 shift is between 100 and 200 milliseconds (from full throttle in 1 gear to back on the throttle in the next)
so yeah, clutch kick and shift happends in one syncronized motion
      11-22-2012, 04:46 AM   #818
tikamak
Lebanon
24
My 2nd-3rd shift is also at this speed but i'm always afraid of the 1st-2nd so i don't want to risk it
      12-10-2012, 04:19 PM   #819
Beedub
Interesting read here
http://www.gtrlife.com/forums/topic/..._fromsearch__1
http://www.amsperformance.com/resour...a-t-bolt-clamp
Ams.. these guy are quite literally imo one of the very best shops out, Interesting that they use worm style clamps on their 40psi 1500whp GTRs ;-) take a read!! very interesting!!
      12-10-2012, 08:55 PM   #820
ZStig
just gradually build up to it. If you fuck up a shift, just remember to immediately push in the clutch pedal as fast as you can
      12-10-2012, 09:03 PM   #821
ZStig
Problem is that ESS doesn't provide quality worm gear clamps. What I don't like about worm gear, is that the second you tighten them past their limit, they click off and lose connection, its probably like that for all worm gear clamps. Pain in the ass, they easily turn worthless after you overtighten them, which takes surprisingly little effort
I use some of the 1 or 2 stock ESS clamps in the hard to reach places that I'm not worried about, but most of the other stuff is high quality t-bolt. I could give a rat's ass about it not applying even pressure on 10" of the pipe, the point is that it silicone is soft and they do a great job of holding a great seal. Sure you can screw up a pipe if you tighten them while on a roid rage, but you'd have to be really aggressive with it.
      12-10-2012, 11:50 PM   #822
ZStig
Time to replace my camber eaten front tires. Will order the rears soon, they're near the wear bars. I loved my Bridgestone RE-11s, but would like to try their direct competitor, the Advan AD08 because they have slightly higher dry traction, plus they run much wider in the 265/35/18 size, so I should be able to put more power down once I upgrade to 10psi next year. Right now, in the Floridian warmth, the RE-11s have been hooking 1st gear pretty damn well in full throttle when warmed up.
Here are the width differences:
Tire/Tread Width
AD08/10.3"
RE11/9.6"
plus, they're 1lbs lighter
this is from -2.5* camber, and 0 toe. Might have to re-check my alignment
      12-11-2012, 01:03 AM   #823
22022
22022's Avatar
Drives: VT2-500 ZM4 roadster
+1
      12-11-2012, 04:17 AM   #824
Beedub
hmmmmm not sure you got the point here?? firstly.... you should BE tightening worm clamps Past their limit??? thats the whole point?? its about using your mecanics brain and knowing... right.... thats more than tight enough.... the post wasnt to bash you or anyone else using bolt thrus, it was more to educate as alot of us swap out and think Arhhhh these are better, which imo they are not ;-) Its a great article imo :-)
now.... have you had a bad day or is it just that time of the month?????
      12-11-2012, 01:52 PM   #825
ZStig
I just get defensive about my mods!
worm clamps break or snap off when you overtighten them, in my experience
      12-11-2012, 02:25 PM   #826
johanness
Drives: 2008 Z4MC
Does ESS piping have bead-rolled ends?
      12-11-2012, 04:08 PM   #827
Beedub
yes!!!
      12-11-2012, 04:11 PM   #828
Beedub
dont get defensive man... its a freaking clamp!!!! im just linking to what the experts think on it... incidentally i run the worm style, albeit upgrade and im more than please with them, infact using a hand tool they are great to Tq up as you really have to put effort in using the special worm clamp tool, you really get an idea of " ohhh thats tight enough" if you get me....
be cool bro..... be cool!!
      12-11-2012, 08:50 PM   #829
ZStig
I'll stab you over a clamp
      12-11-2012, 08:52 PM   #830
ZStig
BTW, I'm gonna be selling my stock section 1 with 90* bungs and my electric cutouts. I'll use those funds for a catless custom section 1.
Beedub, please be the first to upgrade to 10psi, so I know for sure what hardware is needed
I think Jaws can make a custom crank or supercharger pulley to bump up boost, just gotta find out if our injectors are adequate for 500rwhp
      12-12-2012, 11:10 AM   #831
Beedub
you have PM ;-)
      12-27-2012, 03:27 PM   #832
ZStig
Looks like one of my next mods will be a hidden towhook and a small trailer for my X-mas present!
a 9 foot Coleman Inflatable with 5hp motor
      12-27-2012, 03:32 PM   #833
Beedub
perfect for drug runs across small lakes.
Thats a god damn sick present....
i got a pair of underpants that were too small and crush my nuts. i really had to pretend with everything i had to do the "smile".
      12-27-2012, 05:20 PM   #834
ZStig
its funny, I'm looking at whats the biggest engine I can fit on that, legally. Maybe 15hp, and paint the "1" black. hahahah
      01-08-2013, 12:23 PM   #835
Beedub
small notice for you, ESS has now updated the tune for the 500/550 cars. you may want to get in contact and get your update.... no matter to me as im going to evolve.
      01-08-2013, 12:33 PM   #836
tikamak
Lebanon
24
Do you know what the update consists of?
