      11-11-2012, 01:37 PM   #771
Beedub
BTW i'll check mine, i installed mine on the cold side of the motor and installed it the inner bodywork down by the firewall, last time i looked it was fine but i will defo check :-) i noticed that the top section of your already appeared to be damaged as mine is quite abit longer than your item.
      11-11-2012, 02:15 PM   #772
22022
22022's Avatar
Drives: VT2-500 ZM4 roadster
Hi Guys,
Sorry i don't contribute much to Zpost but i stalk it every day especially this thread .
Excellent job on your time Rof..er ZStig your a full second and 1/2 faster than me but im not running meth.
Your right about the accuracy at the truck stops my car with stock wheels and battery was 3600lb full tank this cant be right.
And Beedub is right, our axles are weak this is what happened to my passenger half shaft in second gear under full throttle at around 6500 RPM.
ZStig have you sourced out and after market axles yet?
      11-11-2012, 03:26 PM   #773
Beedub
YUP...... seen a few like this now...... wouldnt expect it to go at high rev situations, more high grip, drag situations.... @ 6500 tq is gradual and linear...
talk us through your car and kit bro??? hows it running and hows things??
Meth at this time of year shouldn't make to much difference now..... here in the UK its sub 10 deg C so meth would cause bog situations.... my car runs lovely at this time of year, sadly it only comes out on the sunny, dry days :-(
      11-11-2012, 05:03 PM   #774
ZStig
Originally Posted by 22022 View Post
Hi Guys,
thanks man. You're definitely looking at the right thread, this is where I post EVERYTHING related to my experience
What kind of kit are you running on your car? Vt1-445 or VT2-500? If your axles broke running as much power as me, that DOES worry me. Might have to be my next major mod before I upgrade power. I definitely won't run slicks without upgrading my axles
I think I'm only getting minor gains from my meth kit. The pump isn't mounted lower than the meth tank, the nozzle can be moved upstream another 6", and I have to get an adapter for my aftermarket check valve so I'm not running TWO check valves. I wanna mount my pump so that the line coming from it, to the nozzle, is as short as possible so it could theoretically kick in faster even though a check valve should keep it pre-loaded..
      11-11-2012, 05:27 PM   #775
ZStig
here's my first run, against an AA tuned 135i. Pretty crappy launch, as you can hear my rpms drop a little. The 2-3 shift was freaking instantaneous though! Obviously the exhaust cutouts were wide open, so it sounded like a chainsaw
      11-12-2012, 02:04 AM   #776
22022
22022's Avatar
Running a VT2-500 euro cats & header with Stromung cans, 4:10s lower on H&R springs on Kumho Ecsta XS,the car runs awesome.
I only drive the car on sunny dry days as-well,parked for the winter now.
Broke the axle last month, ambient temp was around 12*c around 11 pm, out driving having some fun.., got some wheel hop into second then it hooked up and bang.
Fixed it myself, got a used half shaft from a 06 M3.
      11-12-2012, 04:13 AM   #777
Beedub
i was warning you.... our axles are 100% at risk... everytime i start off from the sprint line (on circuit alone in sprinting) its full throttle from the word go on a high grip surface, i think.... i this the time my shafts are going to snap....
we need to look into the DSS axles imo asap.... they were mega money tho ;-) and it requires you sending your stockers in.... :-(
really nice to see the FI community growing.
      11-12-2012, 04:14 AM   #778
Beedub
thanks for the info..... easy home DIY???
so we use the same half shafts as the m3?? i thought they may be slightly shorter, thats good info ;-)
      11-12-2012, 05:10 AM   #779
Rated M Roadster
Rated M Roadster's Avatar
37
Drives: F10 M5
His half shaft broke because of wheel hop, not the extra power. You can break half shafts on a stock car with wheel hop (the drag strip is where they're most vulnerable)...
CURRENT ll F10 M5
SOLD ll E70 X5M
SOLD ll Z4MR VF570
      11-12-2012, 08:28 AM   #780
Beedub
i agree, its Partly down to wheel hop but extra power surely has to be a contributing factor.... every failure on the z4m platform documented so far has been on an Fi car..... i know it only takes one bout of sever wheel hop and pop But imo.... The Fi guys should be looking at this at some point, its your dragging then you DEFinitely should be looking at an axle upgrade. i will be for sure....... no stone unturned and all that....
      11-12-2012, 10:06 AM   #781
ZStig
What are the upgrade options?
      11-12-2012, 10:12 AM   #782
Beedub
DSS :-( only one.
      11-12-2012, 01:32 PM   #783
ZStig
HPF doesn't make them?
      11-12-2012, 02:16 PM   #784
22022
22022's Avatar
Yes same as the M3. DIY not to bad,you need to remove part of the exhaust and sway bar, you defiantly need the right tool to remove the spindle form the hub to get the half shaft out.
      11-12-2012, 02:52 PM   #785
22022
22022's Avatar
DSS :-( only one.
Beedub Is this what your referring to:http://www.driveshaftshop.com/import-axles/bmw/e46-m3
2001 to 2006 e46 M3 should be the same as our cars according to http://www.realoem.com/bmw/
Please correct me if im wrong.
      11-12-2012, 04:12 PM   #786
Beedub
yes!!!!! we send in our axles then they come back rated to 1000hp... lots of money tho!!!! jeeeeeeezzzzz $999 but worth it, for me, it would be a killer to have to send the axles to the states and have to deal with shipping, lead times.... i wish the'd do a buy off the shelf option :-(
im doing lots of standing starts from the start line of the sprint course.... we'll see if i pop one of these... i'll do some proper checks on these items once the car is in the air next time.
      11-12-2012, 07:49 PM   #787
ZStig
I might just wait to break an axle, and then replace it. I have a towing service subscription
      11-13-2012, 05:53 AM   #788
pandusr
pandusr's Avatar
Italy
Drives: BMW Z4M Roadster ESS CFR 525
Smile
Hi guys.
I'm an Italian guy who reads for a long time. My Z4M E85 2006 (call Pina) has:
-CFR525 Ess kits (8 psi)
-differential 4.10
-EUR catless headers
-SS xpipe
-Bartoli racing mufflers
-AEM Meth kit (start 2psi, full 6 psi)
-front 245/35-19 rear 275/35-19
- 505.9 Rwhp 518 Nm (AFR 11.6)
I also fear for our drive shafts and when there are jumps do i care. Early photos and chart.
Sorry my English much at school.
Best regards
Gabriele
      11-13-2012, 09:26 AM   #789
Beedub
Originally Posted by pandusr View Post
Hi guys.
-differential 4.10
-SS xpipe
Best regards
Gabriele
pics pics ppppppiiiiicccsssss!!!!! 500 rwhp @ 8psi sounds alittle much however!!!!!!! AFR perfect, loved those ess kits with the ASA blowers.... they should have offered it as an option imo!!!
      11-13-2012, 12:21 PM   #790
ZStig
AA said they could hook me up with an ASA blower upgrade if I wanted. $$$ hahaha. too tempting.
pandusr! welcome! sounds like you have a great setup. 500rwhp must be perfect for this chassis. Don't worry about your english. How much torque are you making, and what is the model of your supercharger?
      11-13-2012, 03:42 PM   #791
pandusr
pandusr's Avatar
Italy
Hi and thanks for the welcome.
I also think 505rwhp are many. I kept here the same braked dynamometer, before and after installation, to analyze the difference, and i felt it was a bit rich. Soon i will do more testing. I want to see the performance of the AEM meth kit.
Torque is 382 lb/ft (518 Nm). The model of supercharger is ASA TM1-20 HD.
Gabriele
      11-13-2012, 03:45 PM   #792
flipm3
E46 + E90
Philippines
78
Drives: E46 M3 + E90 M3
2009 BMW M3  [0.00]
2002 BMW M3  [0.00]
Gabriele
Now that is why you need an ASA! Super expensive, but man, the midrange power band and torque is OUT OF THIS WORLD!
I would love to see what AA would do if you got an ASA. That thing be such a blast to drive on the street and track!
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread
E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread
