      07-17-2011, 12:51 PM   #23
Addeg
Drives: 06 Z4 M Coupe ESS VT1-445
Originally Posted by Roffle Waffle View Post
My friend has a V-box, so after the break in period, I'll get some good 60-130 numbers up!
Im really looking forward to this so i can compare the times to my VT1 times
      07-17-2011, 03:44 PM   #24
Samjam927
The One And Only
Samjam927's Avatar
15
Drives: 2006 TiAg ///M Roadster
2006 Z4M Roadster  [10.00]
2003 Z4  [5.00]
Sweet, keep us updated!
      07-18-2011, 04:09 AM   #25
Beedub
tom... any updates?? broken complete yet?
why why why have you not checked boost on this thing?? you could be running 5psi and not know??? p.s the ess clamps are rubbish and are notorious for coming loose...... a boost check needs to be done weekly if you havent got a boost gauge.
      07-18-2011, 03:38 PM   #26
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I'm putting on a bigger silicone coupler in an hour, I'll get the boost checked when I dyno it, hopefully sometime next week.
      07-18-2011, 03:39 PM   #27
ZStig
279
Its running alpha-N right?
      07-18-2011, 04:18 PM   #28
Beedub
complete alpha n tune using intake temp sensor under your intake mani ;-)
      07-18-2011, 05:05 PM   #29
iPhoneEngineer
Drives: 2007 BMW Z4 M Coupe
How well does this compensate for altitude changes? Alpha-N can use any number of sensors, but I'm not totally sure all it's equipped with. My daily commute involves 2,000ft of altitude changes (at least three good "ear pops" :-P), so I've been curious for a while.
      07-18-2011, 07:23 PM   #30
Twisted Six
Twisted Six's Avatar
Drives: Z4si-coupe
Use T-bolt clamps from Ebay rather than standard hose clamps.
All my boosted cars blew hoses until I installed the T-bolt versions.
EXAMPLE >>http://cgi.ebay.com/ebaymotors/intak...Q5fAccessories
      07-19-2011, 11:54 AM   #31
ZStig
279
I ordered this piece to solve my only issue. The car runs fine without it, but I'm obviously getting little to no boost right now.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Should be easy, breazy, beautiful after that
      07-19-2011, 01:08 PM   #32
Beedub
nice piece........ i simply lengthen the boost pipe slightly as i wanted to keep things as neat a possible, this however will do exactly the same thing :-) very nice looking piece...... you wont need all that lenght so maybe cut alittle off the long end, job done, nice solution, my lengthening solution is OTT, but then im a OTT kinda guy :-)
FFS i cant wait for one of you guys to give me your impressions on this thing :-)
      07-19-2011, 01:10 PM   #33
ZStig
279
Roman told my shop that that piece is 2.5" to 3". So we picked one up locally, but had to return it. Obviously the wrong size as it was way too tight to fit over the black intercooler pipe. *sigh
Right now my car has a half open pipe at the airbox, and sounds like a gattling gun at full throttle. hahahahaha. i don't mind, I just don't like the idea of unfiltered air getting in, so I'm not driving it much
The ebay piece I found also has walls that are about 2x as thick as the ess piece
      07-19-2011, 01:12 PM   #34
ZStig
279
I had no boost leaks on my first day out, so I did get a short impression of the potential. It was fantastic. Thats why I'm not stressing over this situation
      07-19-2011, 02:10 PM   #35
Beedub
this will completely solve your issue, nice quality :-)
      07-19-2011, 02:13 PM   #36
Beedub
awesome........
definatly see what your saying about the unfiltered air, defo not good on the s/c or turbo setup, those blades are fragile.....
      07-19-2011, 04:00 PM   #37
ZStig
279
No- the air coming into the blower is filtered, just have a gap on the airbox area going to the engine
I just called the store to upgrade my shipping, to make sure I get it by Friday
      07-19-2011, 04:14 PM   #38
Beedub
arhhh my bad excuse me.
      07-19-2011, 04:31 PM   #39
ZStig
279
I hope we ordered the correct diameter piece and that it fits, because Roman@ess said its a 2.5" to 3" reducer, which we tried on because there was one available, and it was too tight to fit
      07-20-2011, 04:14 AM   #40
Beedub
3" to 2.5 should work no probs??????
      07-20-2011, 09:25 AM   #41
ZStig
279
Thats what I tried. Maybe because the walls were much thicker (5 layers vs 2), it would not fit because it is less flexible. I also lined up the ESS elbow to the other 2.5" pipe, and there was definitely a difference in diameter, I'm betting its .25". Maybe because it stretched?
      07-20-2011, 09:37 AM   #42
Beedub
yeah thats makes sense and ess's pipe is alot more plyable, you can really stretch it....
your new one just put something really thick in their to stretch the silicone :-)
      07-20-2011, 09:40 AM   #43
ZStig
279
Shouldn't be a need to stretch the new one, since it'll be 2.75" at the intercooler pipe. Sounds like ESS in Norway will re-imburse me for the new intake elbow I'm buying (hopefully?), and depending on fitment, may use something similar for all future kits as per our recommendation
      07-21-2011, 02:24 AM   #44
Beedub
im wondering if your new silicon piece has come in yet??
