06-26-2011, 08:36 PM | #1 |
Rep 4,531
Any Sway Bars for M Coupes anymore?
I've been looking at getting ~27mm sway bar for my M Coupe, and before I found a H&R Sway bar set but now they have all disappeared and it's impossible to find them.
Anyone have places to get these or find them. Are non-m sway bars compatible? |
06-26-2011, 08:54 PM | #2 |
Rep 11,667
Ground control is one of the few options out there.
06-26-2011, 09:19 PM | #3 | |
Rep 4,531
06-26-2011, 10:34 PM | #5 |
Rep 191
Any problem using GC or H&R sway bars with the KW Clubsport suspension?
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
06-27-2011, 09:36 PM | #7 |
Rep 4,531
07-03-2011, 08:29 AM | #9 |
Bad Lieutenant
232
Rep 3,517
No, I don't believe so.
07-04-2011, 10:39 AM | #10 |
Rep 11,667
I notice that GC have a disclaimer for KW struts.
07-04-2011, 10:41 AM | #11 | |
Rep 11,667
Curious how you find this w/o also changing out the rear? BTW; UUC still lists H&R sways for the Z4M
07-04-2011, 11:03 AM | #12 | |
Rep 64
I currently have the bar set to the softest setting, which is best for push, but still a bit slow in transition. If I had more rebound in the rear, I could probably go stiffer on the bar, but I already have the rear rebound maxed out. (ps. You'd NEVER set a car up this way if you could change springs and both bars. This setup weirdness is all thanks to stock class rules, which allow DA shocks and the front bar, but don't allow springs, rear bars or camber changes past what the factory adjustments give you). |
07-04-2011, 11:18 AM | #13 |
Rep 11,667
Thanks, that makes more sense now.
07-04-2011, 06:28 PM | #14 | |
Rep 4,531
Thanks for the explanation. As well, did you swap out the sway bar by yourself at home or did you have it put on a lift and have it done by an Indy? I'm just trying to figure out if it's possible to do it in a driveway...Any DIY links available? Last edited by Kgolf31; 07-04-2011 at 06:41 PM.. |
07-04-2011, 06:51 PM | #15 |
Rep 4,531
Just looking now, it shows that OEM Sway bar front is 27mm.
H&R lists 28mm. Is it even worth it? Or should you just invest into GC 30mm sways? OR, can you adjust the 28mm to act like a stiffer set-up than OEM? I'm assuming 1mm isn't going to make a world of a difference. Thoughts? |
07-04-2011, 08:46 PM | #16 | |
Rep 64
I use the stock endlinks. They're all metal, so I see no reason to change them. The stiffest hole is hard to get the endlink into, but the other two are no problem. You need to jack the wheel up some to get the endlink into the hole. Swaybar stiffness is proportional to diameter to the 4th power, so the 28mm bar is 16% stiffer than the 27mm stock bar with the same lever arm (usually the middle hole on an adjustable bar). The UUC M3 bar is a 32mm tubular bar. They say it's equivalent to a 30.7mm solid bar, or 67% stiffer than stock with the same lever arm. If the M coupe ever goes into a ST class it would be into a new class called STU-R or something with boxsters, caymans etc. Don't think that will happen. The M coupe would probably be seen as an overdog in STU, even if they bent the rule on back seats. They took years to finally allow E46 M3s because people complained up one side and down the other that it was too fast. We'll see if it can put a dent into the Evos and STis. So it's stock, or straight to BSP/CSP, and I don't really want to deal with that level of pain right now. |
07-04-2011, 08:55 PM | #17 |
Rep 11,667
Are adjustable endlinks permitted to dial out preload?
