Reply
      06-12-2011, 06:05 PM   #1
GothM
Oversteer Enthusiast
GothM's Avatar
Drives: '06 M Coupe, Black Sapphire
Apex ARC-8 18X9 / 18X10 update
Hey, I rarely post on here but I thought I would post an update on my 18x9" 245/40 front, 18X10" 275/30 rear Apex ARC-8/Nitto Invo, H&R spring set up for the benefit of Z4M Kind.
I have been happily running the set up for two seasons. Last season I had no rubbing issues of any kind front or rear even at the track. This season the H&R Springs have settled enough that I am getting very slight rubbing on the outside rear tires on the track. Normal aggressive street driving however is not an issue. I was planning on dropping down to a 235 f & 265 r set up anyway due to my opinion that the 275 are more tire than I need and I am always looking to reduce unsprung weight. I am sure that this will fix the issue.
Hope that info benefits someone out there considering this set up.
Cheerio.
GothM is offline   United_States
      06-12-2011, 06:17 PM   #2
Quickid
Drives: 08 Z4MC, 06 X5 4.4i, 99 323i
Thanks for the update.
My set up is 18x9 ET17 (5mm less aggressive than yours according to 1010Wheels offset caculator) and I have 255/40/18 Advan Neova AD08 and the rears are rubbing (suspension is Eibach/Koni). The AD08s look wider than my original Contis of the same size and the shoulders are pretty square so that definitely contributes to the rubbing.
Quickid is offline   Reply With Quote
      06-12-2011, 08:02 PM   #3
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
Take a fender roller to the rear fender and you should be fine.
My street setup is a 245/275 19" Nt05 setup, I have no problems with rubbing even with the car slammed. As soon as I put the NT01s on with a square shoulder I was getting bad rub in the rear, ended up cutting out the fender liners and flaring the fenders a bit with the Eastwood Fender rolling. No more rub.
2004 Porsche GT3 |White
HRE R40 Monoblocks | KW Clubsport Suspension | RSS Lower Control Arms and Suspension Links | GT3RS Wing and Front Bumper | Cup Car Lip | Euro GT3 Seat | GMG Half Cage | Europipe Exhaust | EPL Tuning
onelove is offline   United_States
      06-12-2011, 08:10 PM   #4
Quickid
What's the wheel spec?
      06-12-2011, 08:12 PM   #5
Finnegan
Finnegan's Avatar
Drives: Sapphire Black/Black Z4Mc
Good to know, dedicated track wheels are on my "wish list".
2007 Sapphire Black Z4M / Apex EC7s / Eisenmann Exhaust / Euro Headers/Cat / Aero Sideskirts / DIY Stubby / Ultimate Pedals / AS SSK / RB Rotors / Other Stuff #1047
Finnegan is offline   United_States
      06-12-2011, 10:18 PM   #6
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
Same as above, from the group buy (apex 18x9 / 18x10). Street wheels are HRE C20. My front fender liners are worn through on the outside, just let the tire eat them up and then trimmed with a dremel.
That being said, glad I went to full on track wheels, trimming wasn't a big deal and took less than 2 hours for all 4 wheels. Well worth it for the extra grip on track.
      11-02-2011, 10:58 PM   #7
kklin
Drives: BMW Z4 M Coupe
Thanks for posting. I was looking for this exact information (but for 18x9.5s on all four corners.)
kklin is offline   Reply With Quote
      11-03-2011, 09:35 PM   #8
Neverlift328
Drives: 2007 Z4 M Coupe
I was planning on doing the same. 18 x 9.5 hopping to run 265's all around! still on stock suspension but am considering h&r springs and eventually coil overs.
I know I'll need a ton of negative camber on the front somewhere around 2.5 -3 degrees
"The best way of making a car faster is to tighten the nut behind the wheel"
Neverlift328 is offline   United_States
      11-03-2011, 10:33 PM   #9
kklin
If I buy new street autocrossers it will most likely be 275 Direzza Z1s (which don't come in 19"). I be driving completely stock with front full-depth Contis this weekend with phillyscca.com/solo.
BTW, I see you're from Hartford. I just bought my coupe (7/08 build) at North Haven a few weeks ago and drove it back to PA.
      11-04-2011, 08:33 AM   #10
Neverlift328
Very nice! North Haven isn't far down the road. Small world!
      11-04-2011, 10:32 AM   #11
ZStig
Drives: VT2-500 M Roadster
I run 265mm RE-11s all around, its fantastic! 18x9 wheels, spaced 35 offset front, and 20 rear
ZStig is offline   Reply With Quote
      11-04-2011, 11:53 AM   #12
kklin
I see you're around Philly. Weather's supposed to be nice this Sunday to play (or watch) at Warminster - http://www.phillyscca.com/solo2/index.html. 93 pre-registered so far. We're a very friendly bunch. All novices welcome if you've never autocrossed!
      11-04-2011, 01:25 PM   #13
Neverlift328
I was going to run the 18x9 but I wanted the concave look. Do you think rubbing will be a huge issue with my setup?? I really wanna make sure I can run these without issue before I spend a couple grand
      11-04-2011, 01:57 PM   #14
wyatth
Drives: E46 M3
235/265 a bit stretched on 18x9, 18x10?
wyatth is offline   Reply With Quote
      11-04-2011, 04:57 PM   #15
ZStig
I'll try to make it
      11-04-2011, 06:07 PM   #16
ZStig
what offsets do you want to run on 18x9?
      11-05-2011, 08:17 AM   #17
Neverlift328
I wanted to run 18x 9.5" offset 35 265 all around probably Hankook RS3
I will install camber plates to get around 2.5-3 degrees of negative camber 5 mm spacer most likely but not 100%
      11-05-2011, 10:42 AM   #18
kklin
I found more square feedback here - http://www.zpost.com/forums/showthread.php?t=473674
      11-05-2011, 11:12 AM   #19
ZStig
I haven't heard of anyone running 9.5" up front, but you should do your research....
edit: see link above
      11-05-2011, 11:30 AM   #20
Neverlift328
I posted all over that thread. see page 2 there are several pics of people running 9.5 in the front. The red car on the second page of that thread has them wrapped in pilot sport cups.
Reply
Forum Jump
