      06-07-2011, 02:42 PM   #111
Barryb97
Drives: 2006 M coupe
I found it took a little finagling to get it to line up. I attached mine with sheet metal screws into the bumper cover. I pre-drilled holes in the lip and then match drilled a pilot into the bumper cover while pushing or pulling to the location I wanted. The only place I had a bit of a problem was right at the inner portion of the "fang". There wasn't quite enough material to get it exactly right and still install the existing fastener so it did sit an eighth of an inch or so recessed at those points. But it still looked fin.
That is until some idiot (me) smacked a curb this weekend. It's off now deciding whether I can repair it or not.
CDV delete, clutch stop, BMW pedals, Strongstrut bar, SS brake lines, rad hole cover, brake duct stop remove, M3 reps, roundel under hood, Intravee II, Homelink, air bag sticker delete, first aid storage, keyhole cover, painted reflectors, Headlight washer disable, Mstache front lip, Autosolutions SSK, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings front, TC Kline DA coilovers…
      06-07-2011, 02:58 PM   #112
RocketsTexans
Drives: Z4MC SB
Originally Posted by MIKe86 View Post
Anyone else that received their lip have one that doesn't fit right?
Doesn't fit like the pics, if I make the sides/corners of the filler piece between the fangs even with the bumper the middle protrudes a lot. It's more curved than the bumper is. If I make the middle part even, the corners of the filler piece between the fangs are tucked in.
Anyone else have this issue or did I just get unlucky?
Hmm, this is making me having 2nd thoughts now.
      06-07-2011, 05:43 PM   #113
Composite Steve
Drives: 03 330i ZHP, 73 Mini, 74 914
I'll investigate and see what's the matter. I test fitted the first form/mould on 3 separate Z4 M(s) and fitment was good. I did noticed not all 3 bumpers were 100% alike; fitment varied slightly between the cars using the same form.
Is there a balanced medium between those two senarios you mentioned?
      06-07-2011, 07:02 PM   #114
vicj
vicj's Avatar
Drives: '06 M Roadster; 2010 Mini
I had the same issue with mine. The ends of the lip dont line up quite right. The curve of the lip, also does not quite match the curve of my bumper. To use the factory bolts in the outside portion under the bumper cover, I was forced to "persuade" the lip a little bit. Even with all this, in the end, it looks pretty good, as long as you dont run from side to side to see that the end points dont match up right.
      06-07-2011, 08:36 PM   #115
MIKe86
Drives: 90 332is
I'll see if I can get some kind of double sided sticky tape before the end of the week and snap some pics so you can see exactly what I see.
If it were close enough to slightly persuade the piece into place I'd be ok with it but it'd be way too much stress on the piece and my bumper IMO with the amount of difference there is.
Anyway I'll snap some pics asap to give a better understanding.
Thanks for the response..
      06-07-2011, 09:53 PM   #116
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
LOL!! Your not the only! just go get some bondo or fiberglass resin...quick fix
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      06-17-2011, 01:40 PM   #117
Composite Steve
1. krnnerdboy -Picked Up
2. shimmy09 -Picked Up
3. barryb97 -Shipped
4. NickyC -Shipped
5. z4murder (in for 10+) -Shipping Info/Payment requested
6. vicj (in for 10+) -Shipped
7. MIKe86 (in for 10+) -Shipped
8. Hdoan86 -Shipping Info/Payment requested
9. eunosracr (in for 10+) -Shipping Info/Payment requested
10. BookerM3 (in for 10+) -Shipping Info/Payment requested
11. Jumbosock with a 3 pointer to make it 10! (x 2)
12. wacaw325 (in for 10+)
13. JDN34
14. jair_onsa(in for 10+)
15.CobraR1339
16. Shec44 (in for 10+)
17. nofear
18. z4-villalona
19. MochaV
20. McWong
21. 850tgul
22. Little C
23. MPOWER78
24. Blind32
25. Steve335
26. johanness
27. Recklessz4
28. david_lm
29. Finnegan
____________
30. S54B32M
31. E86M C
      06-17-2011, 07:23 PM   #118
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Send a message via AIM to Blind32 Send a message via Yahoo to Blind32
Thread needs more pictures of people who received it!
      06-18-2011, 09:08 PM   #119
Steve335
Drives: BMW 335i Coupe
Hey Steve. How long do u think it'll take for me to get mine? I'm at spot 25 btw. TIA
2007 E92 335i - Delivered on 4/24/2007
Montego Blue, Sports Pkg, 6MT, Brushed Trim
      06-19-2011, 11:59 PM   #120
Composite Steve
It'll be at least another month. I can only build them after work in my spare time and on some weekends. I definitely appreciate everyone's patience.
Steve
REMAINING ORDERS:
1. Hdoan86 -Shipping Info/Payment requested
2. BookerM3 (in for 10+) -Shipping Info/Payment requested
3. Jumbosock with a 3 pointer to make it 10! -Shipping Info/Payment requested
4. wacaw325 (in for 10+)
5. JDN34
6. jair_onsa(in for 10+)
7.CobraR1339
8. Shec44 (in for 10+)
9. nofear
10. z4-villalona
11. MochaV
12. 850tgul
13. MPOWER78
14. Blind32
15. Steve335
16. johanness
17. Recklessz4
18. david_lm
19. Finnegan
____________
S54B32M
E86M C
      06-21-2011, 04:44 PM   #121
que4523
Recalc that...
Drives: Z4MR
Steve, I joined the forums recently and saw the MSTACHE Z4 M Front Lip Group Buy...can I join the list?
      06-24-2011, 07:07 PM   #122
Composite Steve
This GB is close. However, I may be making more after all the first orders have been filled. I'll notify you if that happens.
Thanks for asking,
Steve
REMAINING ORDERS:
3. JDN34
5.CobraR1339
7. nofear
8. z4-villalona
9. MochaV
10. 850tgul
11. MPOWER78
12. Blind32
13. Steve335
14. johanness
15. Recklessz4
16. david_lm
17. Finnegan
      06-24-2011, 08:11 PM   #123
Endless619
DHS
Endless619's Avatar
Spain
90
Drives: 2014 Range Rover Black Edition
Thanks for asking,
Steve
REMAINING ORDERS:
3. JDN34
5.CobraR1339
7. nofear
8. z4-villalona
9. MochaV
10. 850tgul
11. MPOWER78
12. Blind32
13. Steve335
14. johanness
15. Recklessz4
16. david_lm
17. Finnegan
Let me know as well. I am interested.
      07-03-2011, 05:39 PM   #124
S54B32m
Drives: 2006 z4 m Coupe, Silver/Gray
Steve don't forget me, I was included in GB.
      07-03-2011, 07:05 PM   #125
Twisted Six
Twisted Six's Avatar
Drives: Z4si-coupe
Steve, did you make your mold with Polyester resins ?
If so....and if there wasn't an added support frame bridge built on the mold backside, its possible your mold is heat cycling and warping as you make parts.
Either that, or you need to add less MEKP % to let the parts fully cure in the mold before de-molding.
Best bet is to post cure the part while still in the mold with heat lamps overnight. THEN de-mold .
Cheers,Vinny
      07-05-2011, 07:55 AM   #126
Pope
Drives: BMW Z4M Roadster
Hey all.
Is this still available, im based in london england and would be keen to get hold of this for my z.
Is it possible to ship to the UK and if so how much??
      07-06-2011, 07:01 PM   #127
Composite Steve
REMAINING ORDERS:
1. Jumbosock with a 3 pointer to make it 10! -- (x2) Payment/Shipping Info Requested
2. wacaw325 (in for 10+) -- Payment/Shipping Info Requested
3. JDN34 -- Payment/Shipping Info Requested
5.CobraR1339
7. nofear
8. z4-villalona
9. MochaV
10. 850tgul
11. MPOWER78
12. Blind32
13. Steve335
14. johanness
15. Recklessz4
16. david_lm
17. Finnegan
I didn't forget about you. You're on the second list.
Cheers,Vinny
Hi Vinny,
Sounds like you've worked with composites before. Two of the moulds were made using polyester resin and 10+ layers of fiberglass cloth. It's very strong and fully cured so I hope it's not distorting. I'll check them against the original plug.
I've switched to epoxy resin since so there's no need for MKEP catalyst or any issues related to it.
I give it a few days for the parts to cure before removing it from the moulds. I'll see if it needs to set in the mould for longer.
Thanks for the tips
Steve
Originally Posted by Pope View Post
Hey all.
I haven't been able to find a shipping company that can ship the lip at a reasonable cost. Shipping through UPS or Fedex to the UK cost more than the lip itself.
Let me know if there's a shipping company with reasonable rates if you know of one.
Thanks.
      07-06-2011, 07:48 PM   #128
Twisted Six
Drives: Z4si-coupe
Hi Vinny,
Thanks for the tips
Steve
25+ years with composites and still refining the craft.
You mentioned cure time on the mold. Most of us give up to 2-3 weeks for post cure WITH the assistance of heat....whether the solar heat or heat-lamps or heat blankets.
Even Epoxy manufacturers will require it if you ask them. Its a necessary evil in the craft.
Almost every mold will move if its receiving its cure cycles by molding parts instead of a post heat cure with the plug still in place.
You might be able to save the mold by re-inserting your plug or parent part and then adding glassed in beam supports to the mold backside and then placing it all out in the sun for a week or so.
Let me know if you need more help on the subject.
Cheers,Vinny
      07-07-2011, 05:34 PM   #129
AnalogDan
Drives: 2007 Z4 M Coupe
I'd like one of these. Let me know when you do your next batch!
      07-07-2011, 05:45 PM   #130
johanness
Drives: 2008 Z4MC
Can someone please confirm exactly how much this lowers the chin? (i.e. distance to ground) I'm on H&R springs and don't want to rip this thing off on the first pothole / speed bump I come across. Thanks!
      07-08-2011, 05:47 PM   #131
Little C
Drives: 07 Z4MC
Send a message via Yahoo to Little C
I dont have the measurment for you, but I also have H&R springs with this lip. I've had it on for about a month and I have very lightly scraped 2-3 times on steep driveways. For the most part I have not had any issues, you just have to be careful!
      07-11-2011, 02:47 PM   #132
Composite Steve
REMAINING ORDERS:
1. jair_onsa(in for 10+) -Shipping Info/Payment requested
2.CobraR1339
3. Shec44 (in for 10+)
4. nofear
5. z4-villalona
6. MochaV
7. 850tgul
8. MPOWER78
9. Blind32
10. Steve335
11. johanness
12. Recklessz4
13. david_lm
14. Finnegan
Cheers,Vinny
Thanks Vinny
Will do.
