04-04-2011, 08:27 AM | #1 |
Rep 49
Z4 Door Panel Removal DIY
I've searched around and cannot seem to find a 'DIY' for removing the door panel on the passenger side. The window in my wife's car seems to be off track or loose, heck I can even raise it up in the channel, it goes down and then binds up when coming back up.
Is this likely a bad, regulator or could it be possible I could just get the panel off and see if perhaps the assembly has come loose and tighten it all back up, is this a common problem? If this is a dealer fix any idea what the going rate is? Any help would be appreciated. |
04-04-2011, 09:19 AM | #2 |
Bad Lieutenant
232
Rep 3,517
Ron Styger has a DIY over on Bimmerfest, search on "damplifier pro" and you'll see his DIY for removing the door and insulating them.
http://www.bimmerfest.com/forums/sho...d.php?t=210510
04-04-2011, 10:08 AM | #3 |
Rep 822
I would start looking for a indy shop to have work done on your car. They will be almost half the price. http://www.bimmershops.com/
SoCal Z Enthusiast contact me to get on the list. Events for like minded people and when you talk about your Z, we will know what you are saying. https://www.facebook.com/groups/ZSCCACalifornia/
04-04-2011, 10:21 AM | #4 |
instagram 997turbotom
279
Rep 7,377
From what I remember, you remove the door handle cover by sliding it down. Then there are 2 star bit bolts in the handle, and one behind the little airbag logo. After that, you pull on the bottom, and then up
04-04-2011, 11:12 AM | #5 | |
Rep 49
Thanks everybody for the help |
04-04-2011, 12:02 PM | #6 |
Bad Lieutenant
232
Rep 3,517
Definitely not for the timid to remove the door, and those clips in the door are really "one-time" use, plus, the new clips have rubber gaskets to eliminate noise and creaks, which I replaced all of them. The bear is finding that butyl tape for the lining of the door and you must have a trim removal kit, like the 6 piece from Bavauto, it's invaluable for removing the brittle plastic bits from the BMWs.
