      03-29-2011, 04:01 AM   #45
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
Originally Posted by Finnegan View Post
Vorshlag are a bolt through design with 80 durometer poly right? How's the NVH with those? Did you go with the Vorshlag motor mounts too? (Lots on their website about motor and transmission movement leading to a denial of gears on downshifts with stock BMW mounts.)
Yup, using the Vorshlag red motor mounts (had UUC motor and transmission mounts before but much happier with these). NVH is considerable - radio is almost pointless
I noticed a big improvement especially at one of the tighter corners on the track where I used to have trouble gettting into second gear.
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
      03-29-2011, 03:11 PM   #46
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
I'm thinking this is primarily your track car though given the mods you have, yes? Just as I suspected the more we resolve the problem with stiffer mounts the more the noise goes along with it--something that must be considered in a mostly street car that sees 5-10 track days/year.
I'm going to see how the UUC reds non-bolt through w/o enforcer do on the noise/control spectrum.
Thank you for offering up this data point as I think we should have a pretty good spectrum to work from: Stock - Black Neoprene Trans - Black Poly Trans - Red Poly UCC - Re Poly UUC + Enforcer - Vorshlag Orange Bolt Through/UUC Red Bolt Through - Vorshlag Orange Bolt Through/UUC Red Bolt Through + Motor Mounts. At least that's how the spectrum from least noise/control to max noise/control looks like it will pan out.
I'll start a new thread in the technical section in the next week or two and try to pull comprehensive listing together based on prior threads, this thread, and any other input folks have.
      03-29-2011, 04:13 PM   #47
Incompatible
Drives: 07 AW Z4C 3.0Si
....I'll start a new thread in the technical section in the next week or two and try to pull comprehensive listing together based on prior threads, this thread, and any other input folks have.
Thanks for doing this, I'm sure there are a number of interested people in this to include myself.
      03-30-2011, 03:37 PM   #48
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
Took a few pictures of the Vorshlag mounts while the car is on the lift for the header install.
Tags
ssk
