      03-04-2007, 05:44 PM   #1
2IFBYZ
Drives: 2003 BMW Z4 Convertible 3.0
Unhappy Z4 Convertible Top won't go down
Convertible top won't open. Indicator light comes on when button is pressed. Nothing happens. HELP!!!
      03-06-2007, 03:54 PM   #2
2Intense
2Intense's Avatar
Drives: 2010 Z4 sDrive 3.5i (Red)
I had the same problem with my 2004 after I had completed a Bluetooth installation...basically I had drained the battery to the point that it did not have the umph to open my top....albeit everything else worked fine.
So, a short drive down the road ( a mile or so) I pulled over and tried again...worked like a charm. The battery just needed some rejuvination from the alternator.
Give it a shot....hope it works!
      03-06-2007, 04:56 PM   #3
SMOKE EM IF U GOT EM!!
SMOKE EM IF U GOT EM!!'s Avatar
Drives: 06 E90 330, 16 So/So F82 M4TMF
2006 330i SPORT  [3.67]
silly question because i m not familiar w the car, but does it have a luggage divider? maybe its supposed to be engaged??
LIVE FAST..DRIVE FASTER!!
      03-07-2007, 03:08 PM   #4
2Intense
2Intense's Avatar
Yes, it does...good point (I was going too far down the troublshooting tree).
As stated above...You may first want to ensure the convertable top stowage divider is in the correct position in the trunk....!!!
If you never come back and tell us what the problem was, we'll assume it was simply the divider (and you are forgiven... )
      03-07-2007, 03:35 PM   #5
lol good one.
      03-10-2007, 02:57 AM   #6
Magrafx
magrafx
Drives: 2005 Z4 2.5si
Top won't open
I jammed some stuff in my trunk and it pushed the space enhancer bar thing up and when I emptied the trunk it stayed up and that will not allow the top to open. Took some owners manualing to figure that one out.
      03-13-2007, 06:11 PM   #7
2Intense
2Intense's Avatar
yeah, like the 2 knobs in the trunk that you have to turn?
