      02-26-2011, 09:41 PM   #45
Shipkiller
Shipkiller's Avatar
Drives: Me
I only have about a 1/2 inch of overhang on the sides. I did not want to stretch the fender-liners to get a flush fit. I personally think it looks better than flush.
I did do a single high speed lap (pushed it faster than I normally go) and I went up the S's at 135MPH..
On a different note, what was really surprising is on one session, I had a E90 M3 on my tail but he never got close enough to warrant me giving a point by, and he could NOT out run me on the straights..... and I could out run him in the turns...
      03-04-2011, 07:06 PM   #46
flat_out
Drives: Z4MC
how long should one allow for this install?
      03-04-2011, 07:22 PM   #47
ZStig
took me about 3 hours total. I took my time though
      03-04-2011, 07:27 PM   #48
flat_out
Drives: Z4MC
did you include stage IV of the install as it looks like there are additional rods i don't have in my kit - can't recall if these were optional extras...
      03-04-2011, 07:29 PM   #49
ZStig
no, but you could try to use the front rods in the back. If you could get a good splitter angle by using the rods in the back, you'll have a much cleaner install. I'm not sure if they're long enough though. the DIY states 10mm rods, which I think he meant 10cm rods
      03-04-2011, 07:40 PM   #50
flat_out
Drives: Z4MC
Originally Posted by Roffle Waffle View Post
.... 10mm rods, which I think he meant 10cm rods
Thanks.
Parts 9 and 13 seem to be the same 10cm, so i guess you could swap over. However, am not sure what the best option is, having the support rods at the rear gives more angle while being up front gives more rigidity.. Not sure if there's a way of getting the desired angle naturally by tightening the rear bolts more...
      03-18-2011, 10:53 PM   #51
Daemonblitz
Commander
Daemonblitz's Avatar
Romania
94
Drives: Z4MC/335i/330xi/S1000RR
2006 Z4M Coupe  [4.45]
2010 BMW S1000RR  [5.00]
Has anyone had any luck finding the spacers for the middle 3 mounting points in Canada ? Namely no.6 and 7 on the parts list ? I have tried Home depot, Home Hardware, Canadian Tire and Brofasco with no luck. If you haven't found them either what did you use instead for the install ?
E90 335i - Space Gray/Black
E90 330xi - Titanium Silver/Black
K46 S1000RR - Matte Red
      03-18-2011, 11:37 PM   #52
Shipkiller
Shipkiller's Avatar
Drives: Me
I used plastic spacers from HomeDepo and painted them. I now have bought a aluminum rod that I will cut to exact length and then paint. HomeDepo also.
Just one caveat on painting. I needed to remove my lower plastic engine bay cover so the three front spacers/bolts needed to come out. The 'normal' paint I used is abrading off... I think that the only paint that will work is an epoxy paint or have them powder coated.
      03-19-2011, 01:26 PM   #53
wrose
Drives: 2007 Z4MC
2006 Z4M Roadster  [5.00]
2007 Z4MC  [0.00]
2005 X3  [0.00]
I only looked quickly and at CDN Tire there was fuel line that looked like it would work.
I ordered 2 more adjuster rods from APR.
Have not done the install yet.
      03-19-2011, 01:36 PM   #54
Daemonblitz
Commander
Romania
94
Darn, i could have sold you mine, I don't think ill be putting them on.
I guess i won't have any luck finding the right spacers, so im probably looking at finding something similar and will end up having to cut it to size.
      03-19-2011, 02:05 PM   #55
inTgr8r
inTgr8r's Avatar
Drives: E86 Z4MC; E92 M3
what about using some heat shrink tube over the alum rod instead of paint.
I still haven't settled on the support spacers for this area yet, but I'm working on something
      03-19-2011, 02:46 PM   #56
Shipkiller
Shipkiller's Avatar
Drives: Me
Never thought of that. That might work.
      03-19-2011, 03:27 PM   #57
ZStig
I put electrical tape over my 3 support rods, this way they won't chip from rocks
      03-19-2011, 06:09 PM   #58
inTgr8r
inTgr8r's Avatar
Also...
For the rear support, there is no need for the expensive turnbuckle.
I'm going to use SS threaded rod & couplers.
      03-20-2011, 09:58 PM   #59
crfine88
crfine88's Avatar
350
Drives: E86M
Working on a plastic spacer to span the gap
Hey guys,
I am almost done with a plastic spacer that spans the entire distance between the fangs.
Here is what I have so far.
I have a buddy that works in the plastics industry and he can get this matl in black too.
      03-20-2011, 10:12 PM   #60
Shipkiller
Shipkiller's Avatar
Drives: Me
I have been looking for something to cover that up. I was thinking of a large purpose cut piece of rubber, but that looks better.
      03-21-2011, 02:44 AM   #61
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
149
Drives: '01 911 Turbo
hmm...I was thinking that the splitter might actually work better with that hole/gap there. I figure the air that passes through that hole would provide more downforce rather than not? Since the air would travel along the length of the rest of the CF board, all the way to the black plastic under-tray/cover
Also, I'm finally going to take the splitter for test runs on the track in another week. We'll see if it actually has any performance benefits =P
      03-21-2011, 02:47 PM   #62
ZStig
Im selling my barely used one for $250 + shipping if anyone's interested. Comes with the install hardware
      03-21-2011, 03:03 PM   #63
Shereef_Osman
Drives: 06 Z4MC & 89 325is
In talking with a very knowledgable guy who owns his own race shop, he actually said the opposite. Filling the gap would provide MORE downforce, as you would be reducing the amount of air that could possibly leak through the underside.
crfine, very interested if you are able to make more of these pieces. Keep us posted. Always providing us with top notch work! Thanks!
      03-21-2011, 04:29 PM   #64
inTgr8r
inTgr8r's Avatar
I agree.
Unless you add some rear down force, I don't think closing the gap is necessarily a good thing.
      03-21-2011, 09:05 PM   #65
crfine88
crfine88's Avatar
350
Drives: E86M
Spacer complete
Short version:
1. Cut the plastic using a compound miter saw ( working with tow angles at once in each cut)
2. Formed into bumper curve then mounted between fangs overnight to set curve
3. Used drill press to for 5 mounting holes
4. Wrapped plastic in gloss black 3M
5. Installed spacer
Overall I am happy with how this turned out. The inside angles are perfect and the gloss black sort of ties into the CF finish. The spacer also gives the center of the bumper substantial support. A word of caution though, this will likely add more front end down force.
      03-22-2011, 09:46 AM   #66
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
GB?
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 *
'14 Jeep Grand Cherokee Overland Hemi... No more snow for the M!
