      02-10-2011, 10:55 PM   #1
crfine88
crfine88's Avatar
438
Drives: E86M
DIY APR Splitter install
DIY INTRO:
This is a five part DIY for Z4M APR splitter installation. PART IV IS OPTIONAL. Part IV adds strength, rigidity and adjustability that will be useful for track applications. Part IV may be overkill for street use. In part IV the lower engine cover is permanently altered. This is the only step that would prevent you from taking you car back to stock without buying any new parts. The lower engine cover price is $157.00
Part I:
-Hardware list & photos
-Tool list & photo
-Bumper removal instructions from 2007 BMW TIS
-Photo headlight washer line that need to be disabled
Part II:
-Splitter preparations
-Attaching the splitter to the bumper cover.
Part III:
-Splitter support rod installation
Part IV:
-Option 2 install (This complicates things but adds rigidity and adjustability that is useful for track applications. May be overkill for street use)
Part V:
-Complete installation
PART I
Hardware:
1. (8) stainless 1/4 20 x 1 machine screws
2. (3) stainless 1/4 20 x 2.25 machine screws
3. (22) stainless 1/4x1 fender washers
4. (11) stainless 1/4 20 lock nuts
5. (3) 1/4 20 nuts (temporarily hold the bumper in place while marking hardware locations)
6. (3) 1/4x3/8x1 spacers
7. (6) 1/4x1/2 washers or 1/4x1/2x1/8 spacers
8. (2) 3/16x2 molly bolt style anchors
9. (2) stainless 10mm splitter support rods
10. (2) stainless 3/16x1 fender washers
11. (8) OEM plastic expanding rivets (BMW # 51118174185)
12. [option 2 install only, see part IV] (3) additional stainless 1/4 x 1 fender washers
13. [option 2 install only, see part IV] (2) additional stainless 10mm splitter support rods
14. [option 2 install only, see part IV] (2) additional stainless 3/16x1 fender washers
Tools:
Prep:
1. Goof Off (decal removal)
2. 50/50 spray
3. Meguiar’s NXT 2.0 tech wax
4. Meguiar’s Ultimate Detailer
5. 3” blue painters tape
Human support:
1. Safety glasses
2. Nitrile gloves
3. Headlight
4. Caffeine
Measurement:
1. 72” ruler
2. 48” adjustable drywall square
3. 12” square
4. 6” rafter square
5. Digital caliper
6. Magnetic protractor
7. Sharpies
8. 1.5” blue painters tape
Wrenching:
1. 1/2 ratchet wrench (wheel removal)
2. 1/2 17mm deep
3. 1/2 2” extension
4. 1/2 Torque wrench (wheel installation)
5. 3/8 ratchet wrench
6. 3/8 T30 male (for engine bay bumper hardware)
7. 3/8 11mm standard
8. 3/8 2” extension
9. 1/4 ratchet wrench
10. 1/4 7mm standard
11. 1/4 8mm standard
12. 1/4 10mm standard
13. 1/4 11mm standard
14. 1/4 3” extension
15. 1/4 5” flexible extension
16. 8mm ratcheting combo wrench
17. 10mm ratcheting combo wrench
18. 11mm ratcheting combo wrench
Power Drivers:
1. 1/2 18V drill driver
2. 3/8 12V drill driver
3. 3/8 12V compact driver
4. 3/8 12V right angle drill driver
5. Drill bit set
Cutting:
1. Jig saw w/ fine blade (only for option 2 install. See part IV)
2. Mini hack saw
3. Exacto knife
Miscellaneous:
1. Needle nose pliers
2. Screwdriver set
3. Zip ties
4. Blue thread locker
Bumper
      02-10-2011, 10:55 PM   #2
crfine88
crfine88's Avatar
438
Drives: E86M
PART II
      02-10-2011, 10:56 PM   #3
crfine88
crfine88's Avatar
438
Drives: E86M
PART III
      02-10-2011, 10:57 PM   #4
crfine88
crfine88's Avatar
438
Drives: E86M
PART IV
      02-10-2011, 10:57 PM   #5
crfine88
crfine88's Avatar
438
Drives: E86M
PART V
      02-10-2011, 11:30 PM   #6
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
Wow, that's a great DIY man.
Thank You for the help to the community!
      02-10-2011, 11:36 PM   #7
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
heh, thats exactly as far as I got with my install today (part 2)
      02-10-2011, 11:41 PM   #8
Thisisdudewhoru
Thisisdudewhoru's Avatar
Drives: 16 BSM 340i
You da bomb. I <3's chris.
edit. Add the hardware list to the top too
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake.:.H&R Sport.:.
      02-11-2011, 10:13 AM   #9
ARISIN
ARISIN's Avatar
Drives: BMW Z4M Roadster - Silver Grey
Thanks for this article. Great write up and your attention to detail is outstanding.
I drive - 2007 BMW ///M Roadster
      02-11-2011, 01:38 PM   #10
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
2006 Z4MC - #LL93158
      02-11-2011, 01:54 PM   #11
bhoch
SSGT USMC - '78 - '86
bhoch's Avatar
Drives: Z4 3.0si
2007 BMW Z4  [7.33]
Great write-up! Thanks for all of the details! Excellent work and documentation!
Thanks,
Bill
2007 3.0si Roadster Black/Red, sport, Piano Black F14 Forgestar's
      02-11-2011, 02:38 PM   #12
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
If one were to ever remove the splitter in order to resell vehicle, how obvious will the holes be in the bumper? I can see using the bolts to fill the holes but can they be seen by the naked eye while looking at the car on a level plane? Mostly worried about the outer bolts on the outside front edge and the front leading edge of the fangs. This is my biggest worry if I ever remove the splitter. Don't want to kill resale value if I install.
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      02-11-2011, 03:10 PM   #13
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Here's the hardware list that I compiled (excluding the two extra moly bolts that Chris personally used):
You can pretty much get whatever nuts, bolts, and washers you'd like, but I went with what Chris used, which I'm going to list off the top of my head as follows:
- Ten 1/4-inch diameter by 1-inch length machine screws/bolts (with 20 pitch threading) for mounting of sides of bumper/splitter
- Ten 1/4-inch diameter (with 20 pitch threading) lock nuts for locking the bolts in place
- Twenty 1/4-inch diameter inner hole by 1-inch outter diameter washers; one washer on the bumper side and one on the splitter side
- Three 1/4-inch diameter by 2-inch length machine screws/bolts (with 20 pitch threading) for the center mounts in between the fangs
- Three 1/4-inch diameter by 1-inch length metal spacer to help keep a healthy distance between bumper bottom and splitter top
- Three 1/4-inch diameter (with 20 pitch threading) lock nuts for locking bolts in place
- Twelve 1/4-inch diameter inner hole by 1-inch outter diameter washers; one washer on bumper side and one on the splitter side. And one on each side of the metal spacers as well.
This allowed me a total of 13 mounting locations excluding the two support rods which I don't particularly want to use. Will see how the splitter behaves prior to tracking it, and see if they're absolutely mandatory.
      02-11-2011, 03:11 PM   #14
mfanatic325
///M-fanatic
Taiwan
193
The drilled holes will only be visible if you look up at the car from underneath.
      02-11-2011, 07:32 PM   #15
Shipkiller
Shipkiller's Avatar
Drives: Me
Chris,
A question:
How did you ensure that the middle of the splitter fit flat against the plastic undertray and not start to ride down the hump?
Edit: disregard.
      02-11-2011, 09:41 PM   #16
VinnieAces
VinnieAces's Avatar
Drives: Imola Red Z4MC
2006 Z4 M Coupe  [8.00]
Excellent DIY Chris! Really appreciate how much time and effort you put into these kind of things.
It just occurred to me that I may as well just lift the cover off my car, remove my bumper and install my lip over the cold months so she is ready to go by spring...
One thing though, I've never removed the front bumper off of our cars, is it hard, easy? Anything i should look out for or be careful about?
///M - Some Mods 'N Stuff
      02-11-2011, 10:25 PM   #17
mfanatic325
///M-fanatic
Taiwan
193
I don't know how experienced you are with hands-on work, but honestly the hardest part about the bumper removal is pounding in the little rivets in the wheel well, and actually pulling the sides off from the headlight area (as previously stated, the plastic mounting tabs are very fragile). Other than that, it's just the seven torx bolts up top, accessed judt under the hood.
      02-11-2011, 10:53 PM   #18
l4zy
l4zy's Avatar
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
2017 BMW M3  [0.00]
2015 BMW i3 REX  [0.00]
1995 BMW M3  [10.00]
2013 BMW X3 xDrive35i  [7.00]
great start! thanks for all the hard work!
      02-11-2011, 11:00 PM   #19
VinnieAces
VinnieAces's Avatar
not THE most skilled person in the world but i'm pretty handy i'll take a look at it prolly this sunday, then proceed with removal over the week if i have time and thanks for the fragile tip,
size of torx wrench needed?
      02-12-2011, 02:52 AM   #20
mfanatic325
///M-fanatic
Taiwan
193
I don't remember the size of the torx, since I had access to my shop's tools and was sure they had the socket/bit I needed
If it were up to me, I'd just buy all-new fender liner push-pin tabs because they're a pain to remove sometimes and it's quicker to just yank them out, possibly destroying them. The bumper removal DIY can be found here:
http://www.zpost.com/forums/showthread.php?t=79994
The part that I'm referring to is step 1 in the DIY. These push-pin tabs are annoying. And so are the bumper's side mounts.
Oh, and I forgot the few 8mm hex screws at the bottom which also serve to hold the bumper in place a bit.
      02-12-2011, 03:02 AM   #21
crfine88
crfine88's Avatar
438
Drives: E86M
Now it's a Real DIY. Updated part one through five with complete hardware, tool, and instructions
      02-12-2011, 09:26 AM   #22
crfine88
crfine88's Avatar
438
Drives: E86M
Thanks man
Nice! DIY complete now. Sorry for the delay; This tool way longer than I had anticipated.
Thanks
Hardware added (along with a ton of other info/photos)
Thank you
Originally Posted by Caddyshk View Post
no problem, check it out now that it's complete
No issue going back to stock unless you elect to do Part IV of the install, then you would need to buy a new lower engine cover for $157 to bring the car back to stock.
Originally Posted by Shipkiller View Post
Chris,
A question:
Edit: disregard.
Let me know if any other questions come up
Thanks man,
I added a ton of info including the BMW TIS bumper removal instructions in part I
Thank you,
All done now
Thanks for all your help, I have been swamped and I appreciate you helping out witht the early installs.
The DIY is complete now. Hardware, parts, & installation have all been updated.
For the fender liners I ended up using a re-usable plastic fastener from BMW. I also had a hard time with the original plastic rivets
Thanks again
