      10-17-2010, 04:05 PM   #1
3002 tii
3002 tii's Avatar
2282
Lowest Offset on 9.5" Rear on Non-M Coupe?
Just like the title says, what's the lowest offset I can get away with on a 9.5" rim on the rear of my non-m Coupe? Stock sports suspension and don't want to roll the fenders.
I think I've seen non-M roadster owners report saying they were able to get the stock M wheels to fit, but wasn't sure if they still encountered rubbing on bumps. I believe stock M offset rear is 27?
And assuming I'm keeping to stock height, wheel diameter (18" vs 19") should not matter as long as I choose the correct profile tire?
Follow for latest mods
      10-18-2010, 12:52 PM   #2
v3.0si
v3.0si's Avatar
Drives: '08 Z4C 3.0si
i'm sure others would agree...
for rear offsets on a non-M...
with stock sport suspension
w/out adding negative camber
w/out letting the tire stick out past the fender
w/out body modification
9.5" width = et42
9.0" width = et35
8.5" width = et29
basically, any offset that pushes the outer edge of the wheel a maximum of 21mm past stock (8.5 x et50).
Last edited by v3.0si; 10-18-2010 at 01:29 PM.. Reason: clarification on dimension.
      10-18-2010, 05:55 PM   #3
3002 tii
3002 tii's Avatar
2282
thanks, very helpful...
      10-18-2010, 06:16 PM   #4
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
I believe the lowest offset you can run on a 9.5" wheel is a 32 offset. I was able to run a 19X10 wheel with a 35 offset with 265/35/19 tire without any rubbing on a eibach/koni set up. Stock M wheels do have a low offset, however they're not that wide of a rim.
Are you planning on another set of wheels?
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover...
      10-18-2010, 06:39 PM   #5
v3.0si
v3.0si's Avatar
out of curiosity, and it could be my "newb" factor ... when a car is lowered, does it increase the amount of negative camber? i ask this because i saw on your website that your car has un unbelieveable amount of camber in the rear. (by the way, your car is absolutely stunning!) but i'm not sure the OP is looking to do that. :
      10-19-2010, 10:12 AM   #6
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
Yes, lowering your car will increase the negative camber. The amount of camber varies and for some reason the amount of negative camber I had resulted me having to buy new tires every 12-14 months
      10-19-2010, 10:37 AM   #7
3002 tii
3002 tii's Avatar
2282
just toying with idea of either a 2nd set or new one all together...
      10-19-2010, 12:20 PM   #8
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
LOL, in the back of mind, me too...once I get rid of my 2nd set.
      10-19-2010, 12:46 PM   #9
3002 tii
3002 tii's Avatar
2282
9.5" width = et42
9.0" width = et35
8.5" width = et29
btw - would you happen to know how much space I have to work with for the fronts, using the same 3 widths as above? wonder if i can get away with a 18x9 et35 on the front...
      10-19-2010, 01:31 PM   #10
v3.0si
v3.0si's Avatar
9 x et35 is a gain of 25mm on the outside edge of the rim over the stock 8 x et47. that would absolutely be past flush unless you plan on putting in some serious negative camber up there.
i'm measuring flush at front to be...
9.0" width = et42 (may have suspension clearance issues
8.5" width = et35
8.0" width = et29
also... i've read on this forum, several posters are having clearance issues with the 8.5" x et35 using 235 tread width. since all of the above measurements use a gain of 18mm over stock, all of these may have the same rubbing issues. my personal plan is a set of front at 8.0" x et35 and a rear of 9.0" x et35. this way i'll be able to go the stock ///M tires.
      10-19-2010, 01:47 PM   #11
3002 tii
3002 tii's Avatar
2282
8.5" width = et35
8.0" width = et29
I used to have SSR Comp H on the front which were 8.5 and I believe that was 35 offset as well but I ran a 225, thought the 235 would be too tall. Thanks again for the numbers.
