Reply
      07-23-2010, 05:30 PM   #1
Diokaef
EMR
Diokaef's Avatar
Drives: 08 Z4MC IRed/09 328xi & 09 335
2008 Z4M Coupe  [4.50]
Send a message via MSN to Diokaef
Anyone interested on ceramic coating exhaust system
This would include headers, middle section pipe, X pipe, and maybe mufflers.
I can work a very good deal with JET-HOT for a 2000F flat black coating what would reduce 30% to 45% of engine bay radiant heat and speed the exhaust process significantly.
"JET-HOT will normally boost power when applied to headers for two reasons. First, the coating promotes denser, more potent fuel/air charges by insulating the engine bay from exhaust heat. At the same time, it accelerates the pulsed-vacuum effect on “tuned” headers, resulting in more effective scavenging of cylinders. The increased velocity of exhaust gases produced by higher exit inertia not only clears each cylinder more quickly; it also draws in the next fuel/air charge more efficiently."
I have experience with this before and I can tell you that does work very well, also since the diameter of our exhaust system is not of the best increasing speed of exhaust is a must.
The normal cost for something of this quality and proportion would be around 1200$ but I can have a good $ cut out of this price if 10 people would be interested.
Diokaef is offline   Brazil
      07-23-2010, 07:25 PM   #2
Diokaef
EMR
Diokaef's Avatar
http://www.jet-hot.com/
      07-23-2010, 10:01 PM   #3
Diokaef
EMR
Diokaef's Avatar
wow, no one? I really don't understand how people don't know how much this is important.
I will have prices by monday.
      07-23-2010, 11:20 PM   #4
crfine88
crfine88's Avatar
Drives: Z4 M Coupe
I have been thinking about doing this too. Just put my car back to gether and wish I had done this before hand.
Jet hot is doing my RPI axle back right now. I am suposed to pick it up next Thursday.
crfine88 is offline   Reply With Quote
      07-24-2010, 10:51 AM   #5
mousitch
Dark Sider
mousitch's Avatar
Drives: 2008 Space Gray Z4MC
Send a message via Yahoo to mousitch
+1. If I had it apart I would jump on this. If it was winter Id think about it also.
2008 Space Grey M Coupe-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap-H&R Sport springs-Zeck CDV-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Escort 9500ix-BMW CCA Member-ST Louis Chapter
mousitch is offline   United_States
      07-24-2010, 12:27 PM   #6
Blind32
Rennfahrer
Blind32's Avatar
Drives: '07 Z4MC
Send a message via AIM to Blind32 Send a message via Yahoo to Blind32
Jet hot is good stuff. I did it to my turbo exhaust manifold on my old car. Great stuff I will definitely have my headers jethotted once I find the funds...
Blind32 is offline   United_States
      07-24-2010, 03:02 PM   #7
Diokaef
EMR
Diokaef's Avatar
If it is a package they would make sure that would have a lower time frame to do it and ship it back, so that equal less time to have the car stopped. also the price would be in only one invoice from them to my company with a good discount to all, and I would share a copy of the invoice with everyone that got on the deal so everyone knows how much you are really paying for.
In my setup I will have AA headers, Custom SS modified middle section pipe and straight pipes to the muffler also modified race eissmann. what would increase even more the speed of the exhaust.
This all should give quite a boost in power.
      07-24-2010, 08:44 PM   #8
inTgr8r
inTgr8r's Avatar
Drives: 07 M Coupe
I've often thought about this.
Have you ever seen before & after dynos?
Alpinweiss '07 M Coupe •Eisenmann Sport-Ceramic Black•Diablo-X•Fabspeed Headers•VRS Hyper-Narrow rear wing•Autosolutions SSK•APR splitter•Tekarbon headlights•StrongStrut STB•KW Clubsport•Poly FCAB/RTAB•Volk Racing G2•Direzza ZII•Stoptech BBK c/w Cool Carbon pads
inTgr8r is offline   Canada
      07-24-2010, 09:29 PM   #9
Diokaef
EMR
Diokaef's Avatar
Yes, but the only good results came from exhaust with diameter under 2 1/2" for 6 cylinder. so the pressure inside the pipe is higher and speed is possible do to higher temperatures and higher pressure inside exhaust.
All the gains that I had opportunity to observe was a full exhaust including mufflers and no cats.
with Headers only I had not observed any improvement and also no much gains with the ones with straight pipes (no Mufflers).
and in my opinion after see the results (Bad results) a very bad idea if you have ceramic cats and or cats with more then 200 CEL what usually caused the exhaust to fail miserably.
A good gain would come from Headers, middle section, and x-pipes with mufflers.
The mufflers only will be done with exterior coating.
I don't have any copy of the results as I was only able to observe them live.
      07-24-2010, 09:35 PM   #10
Diokaef
EMR
Diokaef's Avatar
I will use a 100 CEL cats before the mufflers because it will be the only place with an acceptable temperature and that way I may be able to pass emissions when the car is driven above 6K rpm for a hour or so. (not guaranteed tho, but very possible).
I was able to pass with my 2008 Honda si modified that way in CA on 2008.
      07-24-2010, 10:42 PM   #11
Diokaef
EMR
Diokaef's Avatar
Just came across some reading material http://www.carcraft.com/techarticles...ngs/index.html
and it reenforce my observation that for the headers alone the hp gain is not noticeable but still offer advantage over not coated ones.
      07-24-2010, 10:49 PM   #12
Diokaef
EMR
Diokaef's Avatar
Also with my honda system I gained 34hp after the coating over before coating Total of 48Hp over stock system
      07-25-2010, 10:51 PM   #13
Diokaef
EMR
Diokaef's Avatar
So we need 10 people is anyone else that would be interested on this real improvement?
The cost will be very acceptable.
Reply
Tags
exhaust, headers, heat
Forum Jump
